S2C Link Accessory Kit
Datasheet
Part Number: NL-S2CK
NimbeLink Corp
Updated: May 2018
PN 30230 rev 3
NimbeLink Corp. All Rights Reserved
1
Table of Contents
Introduction
Overview
3
3
Technical Specifications
Block Diagram
Electrical Specifications
3
3
4
External Interfaces
USB Connector
RS232 Connector
Power Connector
Power Considerations
SIM Socket
RF Connectors
5
5
5
6
6
6
6
Indicator LEDs
8
Recommended Antennas
8
PN 30230 rev 3
2
1. Introduction
1.1 Overview
NimbeLink's S2C (serial-to-cellular) Link Accessory Kit consists of simple, user
assembled device allowing easy access to the serial ports for both the USB and
RS232 interfaces on the Skywire® modem. The Kit is compatible with any of the
wide range of cellular technologies and carrier certified modems in the Skywire
cellular modem family.
The S2C Link Accessory kit is tough, compact, and is able to handle extremes of
temperature. The kit offers a range of powering and mounting options and draw
relatively little power, which suits them for remote applications like kiosks, digital
signage, control panels, security panels, and surveillance equipment. Their
ruggedness, simplicity, and low cost make them ideal for large volume, low-touch
applications.
2. Technical Specifications
2.1 Block Diagram
PN 30230 rev 3
3
2.2 Electrical Specifications
2.2.1 Absolute Maximum Ratings
Parameter
Vin
VBUS
DB9 Inputs
DB9
Outputs
DB9 Date
Rate
USB Data
Operating
Temperatur
e
Min
4.5V
Max
-25V
32V
5.5V
25V
Description
Input voltage on barrel jack center pin
Input voltage on USB VBUS signal
RS232 Serial inputs
-13.2V
13.2V
RS232 Serial outputs
250kbps
RS232 Serial port Baud Rate
480 Mbit/s
-40C
+85C
USB Data Rate
Operating Temperature
2.2.2 Recommended Ratings
Parameter
Min
0.8V
2.4V
Description
pin
RS232 Serial inputs
-5.4V
5.4V
Vin
VBUS
DB9 Inputs
DB9
Outputs
Typical
5V
Max
30V
5V
Date Rate
PN 30230 rev 3
115.2K
bps
4
3. External Interfaces
3.1 USB Connector
The USB connector is a
USB Mini-AB style.
3.2 RS232 Connector
The RS232 connector is a DB9 female interface.
Pin
Number
1
2
3
4
5
6
7
8
9
Name
Direction
Description
DCD
RXD
TXD
DTR
GND
DSR
RTS
CTS
RI
Output
Output
Input
None
Input
Output
Input
Output
Output
Internally tied to V+ through 1K resistor
Receive
Transmit
No Internal Connection
Ground
Ready-To-Send
Clear-To-Send
PN 30230 rev 3
5
3.3 Power Connector
The power connector is a 2.1mm center pin positive barrel jack receptacle.
Parameter
Center Pin
Shell
Inside Diameter
Outside
Diameter
Description
Positive DC voltage input
Ground
2.1mm
5.5mm
3.3.1 Power Considerations
NimbeLink recommends having control over the power jack in order to reset the
Skywire if necessary
3.4 SIM Socket
The SIM card socket accepts Micro-SIM size 3FF SIM cards.
The SIM card socket is present on all LTE and GSM Skywire modems. The SIM
card socket is not present on the 2G 1XRTT nor 3G EVDO CDMA Skywire
modems.
3.5 RF Connectors
The S2C Link provides a primary and diversity antenna connection points. The
connectors are both standard SMA connectors, center pin: female. The primary
antenna connection must be used in all implementations. The diversity antenna
connection is not connected when used with a 2G 1xRTT, 2G GSM, 3G HSPA
Skywire.
PN 30230 rev 3
6
PN 30230 rev 3
7
3.6
Indicator LEDs
The S2C Link Accessory Kit has two external LED indicators. The POWER LED,
on the left of the enclosure, is illuminated when power is applied to the device.
The STATUS LED, on the right side of the enclosure, is a flexible use LED that is
often used as a status indicator by the Skywire modem to indicate the current
operating mode of the Skywire. It is driven by pin 13 from the Skywire and can
also be manually configured by sending AT commands to the modem. Please
refer to the user manual and AT command manual for the specific modem being
used.
4. Recommended Antennas
The following Antennas are recommended for use with the S2C Link Accessory
Kit.
Manufacturer
Taoglas
PowerTech
Antennas
PN 30230 rev 3
Part Number
TG.30.8113
MAG-212-12-SM
A-M
Antenna Type
Dipole, Wide Band Cellular Antenna
Omni directional, high gain cellular
antenna
8
很抱歉,暂时无法提供与“NL-S2CK”相匹配的价格&库存,您可以联系我们找货
