76000914
76000914
    DIGIINTERNATIONAL
    SERVER ETHERLITE 16PORT RJ45
76000914 数据手册
bec http://www.bobbintron.com BOBBINTRON ELECTRICAL CORPORATION SPECIFICATION FOR APPROVED APPROVED SIGNATURE DATE : CUSTOMER : DIGI PART NO : 24000115 DESCRIPTION : AC to DC 43Watt Converter PLEASE SIGN AND RETURN ONE COPY. ALL PRODUCTION UNITS WILL BE BUILT ACCORDING TO THIS SPECIFICATIONS. MODEL NO: AP0431-T12 -01 AGENCY APPROVAL: PRESENTED BY: Ben Yang CHECKED BY: JOHNSON LIN APPROVED BY: MICHAEL CHEN REV. A NO. DATE : 09/04/2012 19F, NO.102, HSIN TAI WU ROAD SEC.1, HSIH-JR CITY, TAIPEI HSIEN, TAIWAN. TEL# (886)2-2696-0007 WEBSITE: www.bobbintron.com FAX# (886)2-2696-8786 EMAIL: harry@bobbintron.com bec http://www.bobbintron.com BOBBINTRON ELECTRICAL CORPORATION BOBBINTRON ELECTRICAL CORPORATION SWITCHING POWER SUPPLY SPECIFICATION MODEL: AP0431-T12 -01 ISSUED : 09/04/2012 REV : A 1. Input 1.1 Rated input voltage range : 100Vac-240Vac (universal) 1.2 Input voltage rating : 90Vac-254Vac 1.3 Input Frequency : 47Hz to 63Hz 1.4 Rated input current : 1.2 A (rms) max. for 115VAC 0.6 A (rms) max. for 230VAC 1.5 MAX. In-rush current : 35 A MAX. @ 115VAC 70 A max. @ 230Vac at 25 ℃ am b ien t cold start 2. Output characteristics: 2.1 Output voltage : +5V , +12V , -12V 2.2 Max. load current : 5.0A , 1A , 0.5A 2.3 Min load current : 0A , 0A , 0A 2.4 Tolerance : -5% ~ +5% , -10% ~ +10% , -5% ~ +5% Combined load on +5V and +12V output must be 0.4A or higher. 2.5 Output Ripple & Noise : 50mV , 120mV , 200mV * Ripple & Noise test conditions : (1) Measured by-pass capacitors 0.1uF / 10uF at output connector terminal And oscilloscope set at 20 MHz. (tested by oscilloscope ) bec 3. http://www.bobbintron.com BOBBINTRON ELECTRICAL CORPORATION General characteristics : 3.1 Max. output power : 43 watts continuous. 3.2 Efficiency : 75% ( Minimum ) at Maximum load, 220Vac. 3.3 Turn on delay : 3 second max. at 100Vac 3.4 Hold up time : 10ms Min. at max load 120VAC 3.5 Transient response : output return within ±10% tolerance of nominal voltage within 1m sec. for 50% load change, 120Hz 50% duty cycle. 3.6 Over voltage protection : Auto recovery 3.7 Short circuit protection : protection against short circuit for output 3.7.1 (1) Any protect condition shall cause no damage and no component fail. (2) Automatic recovery when removal of protect condition. 4. Environmental : 4.1 Operating temperature : 0℃ to 40 ℃ 4.2 Storage temperature : -20℃ to 80℃ 4.3 Operating relative humidity : 10% to 85% 4.4 Storage relative humidity : 5% to 95% 5. Safety requirement : (1) UL 60950-1 (2) PSE (under certification) (3) CE 6. EMI requirement : CISPR EN55022 class B rules. bec http://www.bobbintron.com BOBBINTRON ELECTRICAL CORPORATION 7. Hi-pot test : 7.1 Primary to secondary : 4,242VDC for 1 sec. 10mA 8. Reliability 8.1 MTBF : 50K hours min. @ full load at 25℃ ambient temperature. 8.2 Altitude : up to 2000 meters above sea level 9. Mechanical : 9.1 Dimensions (Ref.) : 140 mm long 75 mm width 41 mm height 9.2 Weight (Ref.) : 500g 9.3 Input connector : IEC320 C14 Color : Black 9.4 Output connector : CABLE : Length: 1830mm PLUG : 6 PIN Molex Color : Black 9.5 Pin Out configuration : Location : bec http://www.bobbintron.com BOBBINTRON ELECTRICAL CORPORATION REVISION HISTORY Rev# A Date Was Is 9/4/12 None Initial release bec http://www.bobbintron.com BOBBINTRON ELECTRICAL CORPORATION bec http://www.bobbintron.com BOBBINTRON ELECTRICAL CORPORATION bec http://www.bobbintron.com BOBBINTRON ELECTRICAL CORPORATION bec http://www.bobbintron.com BOBBINTRON ELECTRICAL CORPORATION
76000914 价格&库存
很抱歉,暂时无法提供与“76000914”相匹配的价格&库存,您可以联系我们找货
