76000734
76000734
    DIGIINTERNATIONAL
    POWER SUPPLY 12VDC/240VAC
76000734 数据手册
AC Power Supply – 12VDC, 100240VAC, IEC320-C14 input plug, locking barrel, AC power cord not included. Compatibility: 9-30V Adapters PART NUMBERS North America: 76000734 International: 76000734 Input Specifications: Rated input voltage range: 120VAC - 240VAC Input frequency: 47Hz - 63Hz Rated input current: 1.0A Max. in-rush current: 50A Input Plug Type: IEC 60320 C14 Output Specifications: Output Voltage: 12VDC Max. load current: .5A Min. load current: 0A Output Power: 20W Output Plug: Connector Type: Locking barrel plug Outer Diameter: 5.5mm Inner Diameter: 2.1mm Environment: Operating Temperature: 0° C to 40° C Storage Temperature: -20° C to 85° C Dimensions: Size (LxHxW): 92 x 31 x 50mm Weight: 166g Cord Length: NA Certifications: UL, cUL, PSE, CE, CCC, TUV Contact a Digi expert and get started today! CONTACT US http://www.digi.com/products/model?mid=2264 5/27/2015
76000734 价格&库存
很抱歉,暂时无法提供与“76000734”相匹配的价格&库存,您可以联系我们找货
  • 1+402.682561+50.54766
库存:9
