DC Power Converter
(9-30V to 12/24V)
PART NUMBER:76000976
Input Specifications:
• DC input voltage range : 9V ~ 30V
• DC input voltage rating : 12V/24V
• DC input current : 2.0A max at 12VDC
Output Specifications:
• Output voltage : +5V
• Max. load current : 3A
• Min load current : 0A
• Tolerance : ± 5 %
General characteristics:
• Max. output power : 15 watts continuous.
• Efficiency : 70% ( Minimum ) at Maximum
load at 12VDC.
• Turn-on delay : 2 second max. at 12VDC
• Transient response : Output return
within ±10% tolerance of nominal
voltage within 1m sec. for 50% load
change, 120Hz 50% duty cycle.
• Over voltage protection : 6.2V reference
with output Zener Diode.
• Short circuit protection : Protection
against short circuit for output
Environmental:
• Operating temperature : -30°C to 70°C
• Storage temperature : -30°C to 80°C
• Operating relative humidity : 10% to
85%
• Storage relative humidity : 5% to 95%
Mechanical:
• Dimensions : 74.5 mm long x 49.5 mm
width x 40.5 mm height
• Input connector : Length: 4ft;
Conductor : XTW #20*2C; PLUG : Barewire (tinned)
• Color : Black
• Input Pin Configuration : Location :
Mark/RED : +12/24V DC; BLK : RTN
• Output connector : Length: 1ft;
Conductor : XTW #20*2C; PLUG : Barrel 5.5
x 2.5 x 9.5 mm
http://www.digi.com/products/models/76000976
9/15/2016
很抱歉,暂时无法提供与“76000976”相匹配的价格&库存,您可以联系我们找货
