76000752
76000752
    DIGIINTERNATIONAL
    PORTSEVER 12V UNIV LOCKING MEI
76000752 数据手册
76000752 - Digi International Page 1 of 2 AC Power Supply - 12VDC, extended temp. NEMA 5-15P (US) to 2.1mm locking barrel plug. Compatibility: Digi TransPort WR41 (locking power cord models), Digi Connect WAN, Digi Connect WAN 3G, ConnectPort WAN, PortServer TS H, Digi TransPort WR21. PART NUMBER: 76000752 Input Specifications: • Rated input voltage rating: 100VAC to 240VAC • Input frequency: 47 Hz to 63 Hz Page 2 of 2 • Rated input current: 0.4A (rms) max. for 115VAC, 0.2 A (rms) max. for 230VAC • Max. in-rush current: 25A MAX. @ 115VAC, 50A max. @ 230VAC  at 25° C ambient cold start. • Input Plug Type: NEMA 5-15P (NA) • Leakage current: 1.0 mA max @230Vac. Output Specifications: • Output Voltage: 12VDC • Load current: 1.0A • Output Plug: 9.5 x 5.5 x 2.1mm locking barrel plug • Max. output power: 12 watts continuous Environment: • Operating Temperature: -35° C to 74° C • Storage Temperature: -35° C to 85° C Dimensions: • Size: 93 x 57 x 34mm • Cord Length: 10ft Approvals: • Certifications: UL, cUL, CE http://www.digi.com/products/models/76000752 8/11/2015
76000752 价格&库存
很抱歉,暂时无法提供与“76000752”相匹配的价格&库存,您可以联系我们找货
