UNE315-1212(EU-LDC)
UNE315-1212(EU-LDC)
    ATOPTECHNOLOGIES(上尚)
    LOCKABLEDCJACK(5.5/2.1/9.5MM
UNE315-1212(EU-LDC) 数据手册
Power Adapter Model Name UV305-0510 (US-DC) UVE305-0510 (EU-DC) UN315-1212 (US-LDC) 50500051500003G 50500051500013G US EU UNE315-1212 (EU-LDC) Picture Part Number 150500151120004G 50500151120014G Input Plug Type Input Voltage Output Voltage Connector Type US EU 100 - 240VAC 5 VDC DC Jack 100-240 VAC 12 VDC Lockable DC Jack 3.5 mm 1.35 mm 7.5 mm 58.8 x 28 x 37.6 mm 1500 ±100 mm 5.5 mm 2.1 mm 9.5 mm 64.5 x 50.2 x 29.8 mm 1500 ±100 mm 98 g 103 g Physical Characteristics Jack Outer Diameter (mm) Jack Inner Diameter (mm) Jack/Plug Length (mm) Dimension w/o cord (LxWxH) Cord Length(mm) Weight (g) 60 g 64 g Environmental Limits Operating Temperature 0 ~ 40°C (32 ~ 104°F) 0 ~ 40°C (32 ~ 104°F) Regulatory Approvals Safety CEC Level TUV/PSE/CE/FCC 6 Model Name UN315-1212 (US-Y) CE/FCC 6 UNE315-1212 (EU-Y) UL/PSE/FCC 6 UN315-1212 (US) CE/FCC 6 UN315-1212 (EU) UN315-1212 (UK) Picture Part Number 50500151120003G 50500151120013G 50500151120208G 50500151120218G 50500151120228G Input Plug Type Input Voltage Output Voltage Connector Type US EU 100-240 VAC 12 VDC Y-Type (BT1-10V), include Terminal Block US EU 100-240 VAC 12 VDC DC Jack UK Physical Characteristics Jack Outer Diameter (mm) Jack Inner Diameter (mm) Jack/Plug Length (mm) Dimension w/o cord (LxWxH) Cord Length(mm) Weight (g) 10.5 mm 64.5 x 50.2 x 29.8 mm 1500 ±100 mm 121 g 130 g 110 g 5.5 mm 2.1 mm 10.5 mm 63.9 x 49.5 x 29.5 mm 1500 ±100 mm 106 g 114 g Environmental Limits Operating Temperature 0 ~ 40°C (32 ~ 104°F) 0 ~ 40°C (32 ~ 104°F) Regulatory Approvals Safety CEC Level UL/PSE/CE/FCC 6 CE/FCC 6 UL/PSE/CE/FCC 6 CE/FCC 6 CE/FCC 6 Atop Technologies, Inc. TEL : +886-3-5508137 FAX: +886-3-5508131 sales@atop.com.tw http://www.atop.com.tw Design and specification are subjected to change without notice. All product names referenced herein are registered trademarks of their respective companies. V0.3
UNE315-1212(EU-LDC)
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款红外遥控接收器。
2. 器件简介:EL817是一款集成电路,用于接收红外信号并解码,广泛应用于家用电器的遥控。
3. 引脚分配:共有10个引脚,包括Vcc、GND、Out、OSC1、OSC2等。
4. 参数特性:工作电压为3-6V,工作频率为30-60kHz,输出为TTL电平。
5. 功能详解:EL817能够接收红外信号并将其转换为对应的数字信号。
6. 应用信息:主要用于电视、空调等家用电器的遥控接收。
7. 封装信息:采用DIP16封装。
UNE315-1212(EU-LDC) 价格&库存
很抱歉,暂时无法提供与“UNE315-1212(EU-LDC)”相匹配的价格&库存,您可以联系我们找货
  • 1+158.861191+20.48028
