301-9000-04 - Digi International
AC Power Supply with Intl Plug Kit
PART NUMBER:
301-9000-04
Input Specifications:
Rated input voltage range:
120VAC - 240VAC
Input fequency:
47Hz - 63Hz
Rated input current:
Max. in-rush current:
30A @ 120VAC
60A @ 230VAC
Input Plug Type:
US
Output Specifications:
Output Voltage:
5VDC
Load current:
0A
Output Power:
15W
Output Plug:
Connector Type: Barrel plug
Outer Diameter: 5.5mm
Innter Diameter: 2.5mm
Environment:
Operating Temperature:
0° C to 40° C
Storage Temperature:
-40° C to 80° C
Dimensions:
Size (LxHxW):
74 x 34 x 43.5mm
Weight:
NA
Cord Length:
1000mm
Certifications:
UL, cUL, GS, CE, PSE, CCC
http://www.digi.com/products/models/301-9000-04
8/11/2015
很抱歉,暂时无法提供与“301-9000-04”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+692.000491+86.81164
