EIS-RACK-PS
EIS-RACK-PS
    B+BSMARTWORX
    POWER SUPPLY FOR EIS-RACK-16, 84
EIS-RACK-PS 数据手册
B&B ELECTRONICS EIS-EXTEND-C-5009-ds - 1/4 ©2009 B&B Electronics. All rights reserved EIS-EXTEND-C Ethernet Coaxial Extender for 10/100 Networks Extend Ethernet Coaxial Connections Up to 8530 Feet Features 9 One 10/100Base TX (TX) Ethernet port with RJ-45 connector 9 Auto negotiation of speed and duplex mode on TX port 9 Auto MDI/MDIX on Ethernet port 9 IEEE 802.3 10BaseT and IEEE 802.3u 100BaseTX compliant 9 Line port uses BNC connector or F-Type connector 9 Line port link is full-duplex up to 85Mbps over existing coaxial cable 9 One DIP switch for configuring local or remote mode 9 Status LED’s for monitoring and connection status 9 External AC to DC power adapter included 9 Used as a stand-alone device or with a 19 inch rack chassis 9 Hot-swappable when used in 19 inch rack chassis PRODUCT INFORMATION Functional Description The model EIS-EXTEND-C allows your existing coaxial cable to be used to extend Ethernet connections up to 8530 feet. The Ethernet Extender fully complies with IEEE 802.3 10BaseT and IEEE 802.3u 100BaseTX standards. Two EISEXTEND-C models are required for the Ethernet extension, (one at each end of your extension points). This product can be used with included power supply or in the EIS-RACK-16, 19 inch rack mount chassis, which can house up to 16 EIS-EXTEND-C units or EIS Media Converters. Ordering Information Model Number Description EIS-EXTEND-C 10/100-TX Ethernet Copper Extender w/USA Power Adaptor EIS-EXTEND-C-UK 10/100-TX Ethernet Copper Extender w/USA Power Adaptor EIS-EXTEND-C-EU 10/100-TX Ethernet Copper Extender w/EU Power Adaptor EIS-RACK-16 16-Slot Media Converter, 19" 2U Rack Chassis EIS-RACK-PS Power Supply for EIS-RACK-16, 84 Watts International Headquarters: 815-433-5100 www.bb-elec.com European Headquarters: +353 91 792444 www.bb-europe.com B&B ELECTRONICS EIS-EXTEND-C-5009-ds - 2/4 ©2009 B&B Electronics. All rights reserved Specifications Technology Standards: IEEE802.3 10Base-T, IEEE802.3u 100Base-TX, IEEE802.3x, Ethernet over VDSL Protocols: Transparent to higher layer protocols Processing Type: IEEE802.3x Full-duplex flow control Interface Ethernet Port: Speed: Distance: Cable: Extender Line Port: Speed: Distance: Cable: RJ-45, 10/100Base-TX Full/Half-duplex Auto-Negotiation, Auto-MDI/MDIX 10/100Mbps 328ft. (100meters) 10Base-T: UTP CAT. 3, 4, 5 (2-pair wire), 100Base-TX: UTP CAT. 5 (2-pair wire) BNC Coaxial 1/5/10/20/30/40/50/60/70/75Mbps 8,530ft. (2,600meters) Coaxial Cable (5C2V / RG6AU) Power Environmental Input Voltage: Power Consumption: 12 VDC Operating Temperature: -10°C to 60°C (14°F to 140°F) 5.76W Max. 0.48A@12VDC Storage Temperature: -20°C to 70°C (-4°F to 158°F) Humidity: 5% to 95% (non-condensing) MTBF: MTBF Calculation: 57,515 hours Parts count reliability prediction Mechanical Enclosure: Dimensions: Weight: Aluminum case 3.16" (W) x 4.30" (D) x 0.94" (H), 80.3mm (W) x 109.2mm (D) x 23.8mm (H) 0.33 lb., (150g) Regulatory Approvals RoHS - Yes Safety: UL60950-1, EN60950-1, IEC60950-1 EMI: FCC Part 15, Class A VCCI, Class A EN61000-6-3 EN55022, EN61000-3-2, EN61000-3-3 EMS: EN61000-6-2 PRODUCT INFORMATION EN61000-4-2 (ESD Standards) Contact: + / - 4KV; Criteria B Air: + / - 8KV; Criteria B EN61000-4-3 (Radiated RFI Standards) 10V/m, 80 to 1000MHz; 80% AM Criteria A EN61000-4-4 (Burst Standards) Signal Ports: + / 2KV; Criteria B D.C. Power Ports: + / 2KV; Criteria B EN61000-4-5 (Surge Standards) Signal Ports: + / - 1KV; Line-to-Line; Criteria B D.C. Power Ports: + / - 0.5KV; Line-to-earth; Criteria B EN61000-4-6 (Induced RFI Standards) Signal Ports: 10Vrms @ 0.15~80MHz; 80% AM Criteria A D.C. Power Ports: 10Vrms @ 0.15~80MHz; 80% AM Criteria A EN61000-4-8 (Magnetic Field Standards) 30A/m @ 50, 60Hz; Criteria A Environmental Test Compliance: IEC60068-2-6 Fc (Vibration Resistance) 5g @ 10~150KHz, Amplitude 0.35mm (Operation/Storage/Transport) IEC60068-2-27 Ea (Shock) 25g @ 11ms (Half-Sine Shock Pulse; Operation) 50g @ 11ms (Half-Sine Shock Pulse; Storage/Transport) IEC60068-2-32 Ed (Free Fall) 1M (3.281ft.) International Headquarters: 815-433-5100 www.bb-elec.com European Headquarters: +353 91 792444 www.bb-europe.com B&B ELECTRONICS EIS-EXTEND-C-5009-ds - 3/4 ©2009 B&B Electronics. All rights reserved LED Indicators Front Panel LEDs (Ethernet and Line Connections) Port Ethernet (RJ-45) LEDs Pwr Lnk/Act Status Steady Off Steady Flashing Off Fdx Steady Flashing Off Line (BNC) Description Power on (Pwr stands for POWER) Power off Valid Ethernet connection established (Lnk stands for LINK) Transmitting or receiving Ethernet data (Act stands for ACTIVITY) No valid Ethernet connection nor transmitting/receiving Ethernet data Ethernet connection in full duplex mode (Fdx stands for FULL-DUPLEX) Collision occurred Ethernet connection in half-duplex mode Rmt Steady The device operates in remote mode Loc Steady The device operates in local mode Err Steady Error occurred Lnk Steady A valid connection established between local & remote units Top LEDs (BNC Line Connections) LEDs Status Speed Distance 1 Green 1~ 5Mbps up to 2600M Amber 6~10Mbps up to 2400M Green 11~16Mbps up to 2000M Amber 17~20Mbps up to 1800M Green 21~29Mbps up to 1600M Amber 30~43Mbps up to 1400M Green 44~54Mbps up to 1200M Amber 55~63Mbps up to 1000M Green 64~74Mbps up to 600M Amber 75~85Mbps up to 200M 2 3 PRODUCT INFORMATION 4 5 International Headquarters: 815-433-5100 www.bb-elec.com European Headquarters: +353 91 792444 www.bb-europe.com B&B ELECTRONICS PRODUCT INFORMATION EIS-EXTEND-C-5009-ds - 4/4 ©2009 B&B Electronics. All rights reserved Diagrams International Headquarters: 815-433-5100 www.bb-elec.com European Headquarters: +353 91 792444 www.bb-europe.com Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: B&B Electronics: EIS-RACK-PS EIS-RACK-16
EIS-RACK-PS 价格&库存
很抱歉,暂时无法提供与“EIS-RACK-PS”相匹配的价格&库存,您可以联系我们找货
