232AMM1
232AMM1
    B+BSMARTWORX
    CONDUCTORCABLEM/M10FTDB25
232AMM1 数据手册
Ready-to-use cabling – call for custom lengths! 232AMF5 232NM9 9PSMF 232CAMS Features • Fully molded backshell with strain relief for added protection • 26 AWG stranded conductors for flexibility • Thumbscrews for tool-less termination • All wired straight through except as noted 1-9 10-19 20-49 50-99 100+ DB9 to DB9 – All pins terminated Male to Female Male to Male 9PAMF6 9PAMM6 9PAMF10 9PAMM10 9PAMF15 — 9PAMF25 9PAMM25 Length 1.8 m (6 ft) 3.0 m (10 ft) 4.6 m (15 ft) 7.9 m (26 ft) 1-9 10-19 20-49 50-99 100+ 10-19 20-49 50-99 100+ 10-19 20-49 50-99 100+ 10-19 20-49 50-99 100+ 50-99 100+ Standard & USB Length 1.8 m (6 ft) 3.0 m (10 ft) 4.6 m (15 ft) 7.9 m (26 ft) 7.9 m (26 ft) DB9 to DB25 adapter cable – 15.2 cm (6 in) cable converts 25-pin serial port to a 9-pin AT serial port DB9 Female to DB25 Male 232CAMS 1-9 DB9 female to DB25 male modem DB25 Male to DB9 Female 232CAM 232CAM10 cable – 9-wire, all pins terminated– PC-AT modem Cable Length 1-9 1.8 m (6 ft) 3.0 m (10 ft) Null Modems, Reversers, Testers 9-pin null modem cable – Pins 2 and 3 crossed for RS-232 compliance – DB9 connectors on both ends Female to Female Male to Female Length 1-9 232NM9FF6 232NM9MF6 1.8 m (6 ft) 232NM9 232NM9MF10 3.0 m (10 ft) 232NM9FF25 232NM9MF25 7.9 m (26 ft) Fiber Optic DB9 Male to DB25 Female 232CAMR Category 5e & 6 Male to Male 232AMM5 232AMM1 — 232AMM2 — Industrial DB25 to DB25 – All pins terminated Male to Female 232AMF5 232AMF1 232AMF15 — 232AMF2 Cables & Connectors D-subminiature parallel and serial cables Port saver – Protect a highly used port from mechanical damage – Saves you from replacing an expensive card due to port damage Model No. 9PSMF 232PSMF Description Male to female DB9 port saver Male to female DB25 port saver 1-9 10-19 20-49 USB Cables High performance USB connectivity and USB extension Features – USB cables • Connect your PC or device to any cable-less USB peripheral • Type A male to Type B male • Fully rated USB 2.0 peripheral cables Model No. USBAMBM-3F USBAMBM-6F USBAMBM-15F Length 3 ft (1m) 6 ft (2m) 15 ft (5m) 1-9 10-19 20-49 50-99 100+ Model No. Length USBAMAF-10F 10 ft (3m) 1-9 10-19 20-49 50-99 100+ Features – USB extension cable • This 3 meter extension cable extends a short cable on a USB peripheral to the full 5 meters length allowed (total cable length must not exceed 5 meters) • Type A male to type A female www.bb-elec.com 815.433.5100 139
232AMM1 价格&库存
很抱歉,暂时无法提供与“232AMM1”相匹配的价格&库存,您可以联系我们找货
