780000
780000
    SCS
    TAPECLEARESD1/2''X36YDS
780000 数据手册
ESD Cellulose Tape For general purpose applications • Meets ANSI/ESD S20.20 and packaging standard ANSI/ESD S541 • Film Thickness: 1.9 mil 0.0019", (0.06 mm) • Adhesive: Rubber based - non staining, absorbs moisture • Film surface resistance: 1 x 109 to < 1 x 1011 ohms per ANSI/ESD STM11.11 • Temperature Range -10°C to 71°C (14°F to 160°F) 100°C for 10 min max • Available in clear, and clear with ESD symbols. Marking is approved symbols of Mil STD-1285** and ANSI/ESD S8.1. • Symbols printed in between film and adhesive; will not rub off. • Manufactured in North America Antistatic Clear Cellulose Antistatic Clear Cellulose with Symbols Tape is wound on a low-sloughing plastic core. Wescorp Tape Storage and Limited Warranty: Users shall determine the suitability of the product for its intended use. For best results, tape inventory should be continually replenished. It is recommended that rolls of tape be stored flat and rotated (flipped over to the other side) periodically. Tapes should be stored in a dry, well ventilated room with a reasonably consistent temperature of 68°F (20°C) and be protected from exposure to direct sunlight. Tape should not be stored in ultraviolet sunlight, moisture, or heat. Tape over one year old should be evaluated by the user to determine acceptability for the user’s application. Desco Industries, Inc. recommends those tracking useful life of product to use shipping/invoice date as Desco Industries, Inc. expressly warrants that for a period of one (1) year from the date of purchase, our Wescorp Brand ESD Tape will be free of defects in material (parts) and workmanship (labor). See details of Limited Warranty online at StaticControl.com/Warranty.aspx *Wescorp is a Desco Industries brand. Note: Tape rolls may vary slightly in color. **Military organizations sometimes use MIL-STD-1285 for hardware marking and that document once required the use of the “three arrows in a circle” symbol. That symbol has been changed for consistency with industry marking to the “hand in triangle” ESD Susceptibility symbol.“ (Ref: ESD TR20.20 section 5.3.14.1) Tape 0.5" Core Length 780000 780001 1" 36 yds 780002 780003 780004 3" 72 yds Antistatic Clear Cellulose 780005 780006 780007 with Symbols 3" 72 yds Antistatic Clear Cellulose Employee Owned 1" Width tolerance ±1/32" Tape widths are nominal metric ±0.8 mm (±1/32"). 1/2" is 12 mm nominal or 0.472" 3/4" is 18 mm nominal or 0.709" 1" is 24 mm nominal or 0.945" Antistatic Tape Imprint on Clear Cellulose with Symbols RoHS 2, REACH, and Conflict Minerals Statement None of the RoHS 2 restricted materials or REACH substances of very high concern as of 2014/12/17, or Conflict Minerals are intentionally added in manufacturing this product. Ref: European Union Directive 2011/65/EU and Regulation (EC) No. 1907/2006/CE. See SCS Warranty, Limitation of Liability and Remedies Specifications and procedures subject to change without notice. WESCORP* ESD CELLULOSE TAPE, PLASTIC CORE 926 JR Industrial Drive, Sanford, NC 27332 WEB SITE: StaticControl.com PHONE (919) 718-0000 © 2015 DESCO INDUSTRIES INC. 0.75" DRAWING NUMBER 780000 DATE July 2015
780000 价格&库存
很抱歉,暂时无法提供与“780000”相匹配的价格&库存,您可以联系我们找货
