Antistatic Cellulose Tape
For general purpose applications
• 2.4 mil (0.06 mm) total thickness
• Cellulose film resistance 10E10 - 10E11 ohms
• Rubber based adhesive absorbs moisture
• Adhesive surface resistance 10E10 - 10E11 ohms
• Temperature Range -10°C - 71°C (14°F - 160°F);
meets MIL-B-81705 of 100°C for 10 min max
• Available in clear, clear with ESD symbols, and clear with ESD symbols with yellow
stripe. Marking is approved symbols of Mil STD-1285* and ESD Association.
• Symbols printed in between film and adhesive; will not rub off.
46927
46926
Tape
Tape is wound on
a paper core.
RoHS Compliance Statement
None of the following materials are intentionally added in manufacturing this
product: lead, mercury, cadmium, hexavalent chromium, polybrominated biphenyls
(PBB) or polybrominated diphenyl ethers (PBDE) as outlined in the Directive
2002/95/EC Article 4.1. See Protektive Pak letter on-line at ProtektivePak.com.
No sulfur, surfactants or silicone based material (adhesive, film backing, release
material) is used in the manufacture of our cellulose tape.
Wescorp Tape Storage and Limited Warranty:
The user must determine the suitability for use of an antistatic tape for his particular
application. For best results, tape inventory should be continually replenished. It
is recommended that rolls of tape be stored flat and rotated (flipped over to the
other side) periodically. Tapes should be stored in a dry, well ventilated room with a
reasonably consistent temperature of 68°F (20°C) and be protected from exposure to
direct sunlight. Tape should not be stored in ultraviolet sunlight, moisture, or heat.Tape
over one year old should be evaluated by the user to determine acceptability for the
user’s application. Protektive Pak recommends those tracking useful life of product to
use shipping/invoice date as Protektive Pak expressly warrants that for a period of one
(1) year from the date of purchase, our Wescorp Brand Antistatic Tape will be free of
defects in material (parts) and workmanship (labor). See details of Limited Warranty
online at http://www.protektivepak.com/warranty.aspx
*Wescorp is a Desco Industries brand.
0.5”
.75”
Employee Owned
2”
Core Length
Antistatic Clear Cellulose 46920 46921 46922
1"
46923 46924 46925 46926
3"
46927 46928 46929 46930
3"
with Symbols
36 yds
72 yds
72 yds
Width tolerance ±1/32”
Tape widths are nominal
metric ±0.8 mm (±1/32”)
1/4"
1/2"
3/4"
1"
2"
is 6 mm
is 12 mm
is 18 mm
is 24 mm
is 48 mm
nominal
nominal
nominal
nominal
nominal
or
or
or
or
or
0.236"
0.472"
0.709"
0.945"
1.890"
Antistatic Tape
Imprint on Clear Cellulose
with Symbols
*Military organizations sometimes use MIL-STD-1285 for hardware marking and
that document once required the use of the “three arrows in a circle” symbol. That
symbol has been changed for consistency with industry marking to the “hand in
triangle” ESD Susceptibility symbol. (Ref: TR20.20 section 5.3.14.1)
Made in America
WESCORP* ANTISTATIC CELLULOSE TAPE ON PAPER CORE
PROTEKTIVE PAK
13520 MONTE VISTA AVENUE, CHINO, CA 91710
PHONE (909) 627-2578, FAX (909) 363-7331
ProtektivePak.com
© 2010 Desco Industries Inc.
Width
1”
DRAWING NUMBER
46920
DATE:
March
2010
很抱歉,暂时无法提供与“46921”相匹配的价格&库存,您可以联系我们找货
