ESD Cellulose Tape
For general purpose applications
• Meets ANSI/ESD S20.20 and packaging standard ANSI/ESD S541
• Film Thickness: 1.9 mil 0.0019", (0.06 mm)
• Adhesive: Rubber based - non staining, absorbs moisture
• Film surface resistance: 1 x 109 to < 1 x 1011 ohms per ANSI/ESD
STM11.11
• Temperature Range -10°C to 71°C (14°F to 160°F)
100°C for 10 min max
• Available in clear, and clear with ESD symbols. Marking is approved
symbols of Mil STD-1285** and ANSI/ESD S8.1.
• Symbols printed in between film and adhesive; will not rub off.
• Manufactured in North America
Antistatic Clear Cellulose
with Symbols
Tape is wound on a low-sloughing plastic core.
Wescorp Tape Storage and Limited Warranty:
Users shall determine the suitability of the product for its intended use. For best
results, tape inventory should be continually replenished. It is recommended that
rolls of tape be stored flat and rotated (flipped over to the other side) periodically.
Tapes should be stored in a dry, well ventilated room with a reasonably consistent
temperature of 68°F (20°C) and be protected from exposure to direct sunlight. Tape
should not be stored in ultraviolet sunlight, moisture, or heat. Tape over one year old
should be evaluated by the user to determine acceptability for the user’s application.
Desco Industries, Inc. recommends those tracking useful life of product to use
shipping/invoice date as Desco Industries, Inc. expressly warrants that for a period of
one (1) year from the date of purchase, our Wescorp Brand ESD Tape will be free of
defects in material (parts) and workmanship (labor). See details of Limited Warranty
online at StaticControl.com/Warranty.aspx
*Wescorp is a Desco Industries brand.
Note: Tape rolls may vary slightly in color.
**Military organizations sometimes use MIL-STD-1285 for hardware marking and that document
once required the use of the “three arrows in a circle” symbol. That symbol has been changed for
consistency with industry marking to the “hand in triangle” ESD Susceptibility symbol.“ (Ref: ESD
TR20.20 section 5.3.14.1)
Tape
0.5"
Core
Length
780000 780001
1"
36 yds
780002 780003 780004
3"
72 yds
780005 780006 780007
with Symbols
3"
72 yds
Employee Owned
1"
Width tolerance ±1/32"
Tape widths are nominal
metric ±0.8 mm (±1/32").
1/2" is 12 mm nominal or 0.472"
3/4" is 18 mm nominal or 0.709"
1" is 24 mm nominal or 0.945"
Antistatic Tape
Imprint on Clear Cellulose
with Symbols
RoHS 2, REACH, and Conflict Minerals Statement
None of the RoHS 2 restricted materials or REACH substances of very high concern as of 2014/12/17,
or Conflict Minerals are intentionally added in manufacturing this product. Ref: European Union
Directive 2011/65/EU and Regulation (EC) No. 1907/2006/CE. See SCS Warranty, Limitation of
Liability and Remedies
Specifications and procedures subject to change without notice.
WESCORP* ESD CELLULOSE TAPE, PLASTIC CORE
926 JR Industrial Drive, Sanford, NC 27332
WEB SITE: StaticControl.com
PHONE (919) 718-0000
© 2015 DESCO INDUSTRIES INC.
0.75"
DRAWING
NUMBER
780000
DATE
July
2015
很抱歉,暂时无法提供与“780005”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+58.149351+7.52794
