79204
79204
    DESCO
    TAPE CLEAR ANTISTATIC 72YDS 3/4
79204 数据手册
Specifications Standard Document ANSI/ESD S20.20 Electrical Properties Rs Resistance: Meets Requirements of: Packaging Typical Values 1 x 109 to < 1 x 1011 ohms Test Procedures/Method ANSI/ESD STM11.11 Physical Properties Antistatic Tape Antistatic Tape Imprint on Clear Cellulose with Symbols Imprint on Clear Cellulose w/ Symbols w/Yellow Stripe RoHS, REACH, and Conflict Minerals Statement See the Desco Industries RoHS, REACH, and Conflict Minerals Statement: Descoindustries.com/ROHS.aspx See the Desco Limited Warranty: Desco.Descoindustries.com/Limited-Warranty.aspx See the Desco Disclaimer: Desco.Descoindustries.com/Disclaimer.aspx No sulfur, surfactants, amines, or silicone based material (adhesive, film backing, release material) is used in the manufacture of our cellulose tape. Wescorp Tape Storage and Limited Warranty: The user must determine the suitability for use of an ESD tape for his particular application. For best results, tape inventory should be continually replenished. It is recommended that rolls of tape be stored flat and rotated (flipped over to the other side) periodically. Tapes should be stored in a dry, well ventilated room with a reasonably consistent temperature of 68°F (20°C) and be protected from exposure to direct sunlight. Tape should not be stored in ultraviolet sunlight, moisture, or heat. Tape over one year old should be evaluated by the user to determine acceptability for the user’s application. Desco Industries, Inc. recommends those tracking useful life of product to use shipping/invoice date as Desco Industries, Inc. expressly warrants that for a period of one (1) year from the date of purchase, our Wescorp Brand ESDTape will be free of defects in material (parts) and workmanship (labor). See details of Limited Warranty online at Desco.com/Warranty.aspx *Wescorp is a Desco Industries brand. Construction: Thickness: Color:* Temperature Range: Cellulose film tape coated with a high tack, non-staining, rubber adhesive system on plastic core 1.9mil (0.048mm) Clear, with ESD Symbols -10°C to +71°C (+14°F -to +160°F) 100°C for 10 min max Sulfur Content: No Sulfur Backing: Cellulose Adhesive: Synthetic Rubber Tensile: 22 LBS./IN Adhesion: 59oz/in2 Elongation: 22.5% Tape 0.5" 0.75" Clear 79200 79203 79201 79204 79209 79275 Clear with Symbols Clear w/ Symbols and Yellow Stripe 1" 2" Core Length 79202 79205 79206 1" 3" 36 yds 72 yds 79210 79211 79212 3" 72 yds 79276 79277 79278 3" 72 yds Width tolerance ±1/32" *Military organizations sometimes use MIL-STD-1285 for hardware marking and that document once required the use of the “three arrows in a circle” symbol. That symbol has been changed for consistency with industry marking to the “hand in triangle” ESD Susceptibility symbol.“ (Ref: ESD TR20.20 section 5.3.14.1) Specifications and procedures subject to change without notice Tape widths are nominal metric ±0.8 mm (±1/32") 1/4" 1/2" 3/4" 1" 2" is 6 mm is 12 mm is 18 mm is 24 mm is 48 mm nominal nominal nominal nominal nominal or or or or or 0.236" 0.472" 0.709" 0.945" 1.890" Note: Tape rolls may vary slightly in color. WESCORP* ESD CELLULOSE TAPE, PLASTIC CORE DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com PHONE (909) 627-8178 DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407 WEB SITE: Desco.com PHONE (781) 821-8370 © 2018 DESCO INDUSTRIES INC Employee Owned DRAWING NUMBER 79200 DATE: April 2018
79204 价格&库存
很抱歉,暂时无法提供与“79204”相匹配的价格&库存,您可以联系我们找货
