46929
46929
    DESCO
    TPCLRW/SYMBLS1INX72YDS
46929 数据手册
Antistatic Cellulose Tape For general purpose applications • 2.4 mil (0.06 mm) total thickness • Cellulose film resistance 10E10 - 10E11 ohms • Rubber based adhesive absorbs moisture • Adhesive surface resistance 10E10 - 10E11 ohms • Temperature Range -10°C - 71°C (14°F - 160°F); meets MIL-B-81705 of 100°C for 10 min max • Available in clear, clear with ESD symbols, and clear with ESD symbols with yellow stripe. Marking is approved symbols of Mil STD-1285* and ESD Association. • Symbols printed in between film and adhesive; will not rub off. 46927 46926 Tape Tape is wound on a paper core. RoHS Compliance Statement None of the following materials are intentionally added in manufacturing this product: lead, mercury, cadmium, hexavalent chromium, polybrominated biphenyls (PBB) or polybrominated diphenyl ethers (PBDE) as outlined in the Directive 2002/95/EC Article 4.1. See Protektive Pak letter on-line at ProtektivePak.com. No sulfur, surfactants or silicone based material (adhesive, film backing, release material) is used in the manufacture of our cellulose tape. Wescorp Tape Storage and Limited Warranty: The user must determine the suitability for use of an antistatic tape for his particular application. For best results, tape inventory should be continually replenished. It is recommended that rolls of tape be stored flat and rotated (flipped over to the other side) periodically. Tapes should be stored in a dry, well ventilated room with a reasonably consistent temperature of 68°F (20°C) and be protected from exposure to direct sunlight. Tape should not be stored in ultraviolet sunlight, moisture, or heat.Tape over one year old should be evaluated by the user to determine acceptability for the user’s application. Protektive Pak recommends those tracking useful life of product to use shipping/invoice date as Protektive Pak expressly warrants that for a period of one (1) year from the date of purchase, our Wescorp Brand Antistatic Tape will be free of defects in material (parts) and workmanship (labor). See details of Limited Warranty online at http://www.protektivepak.com/warranty.aspx *Wescorp is a Desco Industries brand. 0.5” .75” Employee Owned 2” Core Length Antistatic Clear Cellulose 46920 46921 46922 1" 46923 46924 46925 46926 3" Antistatic Clear Cellulose 46927 46928 46929 46930 3" with Symbols 36 yds 72 yds 72 yds Width tolerance ±1/32” Tape widths are nominal metric ±0.8 mm (±1/32”) 1/4" 1/2" 3/4" 1" 2" is 6 mm is 12 mm is 18 mm is 24 mm is 48 mm nominal nominal nominal nominal nominal or or or or or 0.236" 0.472" 0.709" 0.945" 1.890" Antistatic Tape Imprint on Clear Cellulose with Symbols *Military organizations sometimes use MIL-STD-1285 for hardware marking and that document once required the use of the “three arrows in a circle” symbol. That symbol has been changed for consistency with industry marking to the “hand in triangle” ESD Susceptibility symbol. (Ref: TR20.20 section 5.3.14.1) Made in America WESCORP* ANTISTATIC CELLULOSE TAPE ON PAPER CORE PROTEKTIVE PAK 13520 MONTE VISTA AVENUE, CHINO, CA 91710 PHONE (909) 627-2578, FAX (909) 363-7331 ProtektivePak.com © 2010 Desco Industries Inc. Width 1” DRAWING NUMBER 46920 DATE: March 2010
46929 价格&库存
很抱歉,暂时无法提供与“46929”相匹配的价格&库存,您可以联系我们找货
