TY2001GR270
TY2001GR270
    ALPHAWIRE(阿尔法电线)
    LACINGTAPEGREEN14'
TY2001GR270 数据手册
FIT® Wire Management Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 481 FIT® Wire Management Better wire management means better harnesses B ringing order to wire harnesses and cable routing means a system that is more reliable, easier to fabricate, and simpler to maintain. Our woven sleeves are tough and flexible. For additional resistance to chemicals, oils, and solvents, our flexible tubing offers exceptional performance and operates at temperatures as high as 260°C. Our braided shields are effective and easy to use for additional EMI protection or a ground connection. Neatness counts As a leader in premium products, Alpha Wire knows wire and cable. And we know the challenges you face in creating harnesses, routing, and combating noise. Our FIT wire management products are designed to tame the most unruly applications. Harnessing Make any wire harness organized, manageable, and neat with our tubing, sleeving, spiral wrap tubing, zipper tubing, and lacing tape. Our unique ZIP-GRP expandable, enclosure sleeving allows easy re-entry and unlimited wire and cable break outs with its hook and loop fastener system. Shielding Add shielding easily and quickly. We offer flat, round, and oval braided shielding for additional protection against EMI and for grounding protection. Our copper foil shielding tape is backed with a highly conductive, pressuresensitive adhesive for use in a wide variety of EMI/RFI shielding applications in cable and connector assemblies. Routing Get the advantages of conduit in a flexible non-metallic, liquid-tight tubing and connection system that protects wire, copper cable, and fiber-optic cable in factories, offices, or underground installations. Use our watertight tubing to replace rigid raceways where flexibility, re-entry, or re-usability is required. Additionally, Alpha offers split looms to provide a convenient solution for your routing needs. 482 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT® Wire Management Better wire management means better harnesses PVC-105 PVC tubing is the workhorse choice for protecting, organizing, and routing cables. Convoluted Slit Loom Tubing and Tee Connector Fittings Type 492 Tubing Type 493 Fittings Flexible polyethylene loom material permits fast, easy installations and protection of harness and cable assemblies. The loom is slit full length so that it slides over the completed wire assembly easily, but closes after installation to protect the wire bundle. The slit allows for the wires to break out at any point along the cable length for custom installation. Companion snap-on connectors provide simple, clean cable junctions. Zipper Tubing™ ZIP-41 Protect wire, cables, and harnesses. Alpha Zipper Tubing provides a professional finish to wiring installations by eliminating exposed wiring and providing added protection against flame, chemicals, and abrasion. With Zipper Tubing, it’s possible to isolate any group of wires or cables quickly and easily, without the bother of tape wrapping. Zipper Tubing is an ideal jacketing material for use in harsh environments for production or repair of harness assemblies. Each package contains two plastic sliders. Flexible Liquid-Tight PVC Tubing and Nylon Connectors FNT Tubing SLC and RLC Connectors FNT PVC tubing system of wire management products for electronic and electrical wire protection provides maximum flexibility and can be used in extremely tight quarters. The tubing is excellent for general applications where maximum flexibility is required or in areas where movement, vibration, or flexing is a problem. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 483 FIT® Wire Management Better wire management means better harnesses Flexible PTFE Tubing TFT-200 Thin-Wall Tubing TFT-250 Standard-Wall Tubing To improve the reliability of cable harnesses, PTFE tubing provides a heat and abrasion resistant wire insulator under the most adverse conditions. With an unmatched temperature range, exceptional abrasion resistance, and excellent dielectric properties, it maintains flexibility over its entire temperature range. PVC-Coated Fiberglass Sleeving PIF-130 Uncoated Fiberglass Sleeving PIF-240 PIF-130 sleeving is a woven fiberglass braid impregnated with a heat-resistant, extremely tough, abrasion-resistant and flexible plastic insulation. The fiberglass is treated to remove all organic matter and resist fraying. The sleeving is completely compatible with all insulation and conductor types. PIF-240 sleeving is extremely flexible and abrasion resistant. It is ideal for applications requiring operation up to 648°C. It is heat treated to remove all organic matter, and it is completely compatible with all insulation and conductor types. CST Series Acrylic-Coated Fiberglass Sleeving AF-155 AF-155 is a specially designed fiberglass sleeving coated with a thermally stable, flexible, acrylic resin for wire and cable protection in electrical equipment. The most economical and versatile of all coated sleeving products, it offers high heat resistance, extreme flexibility, and resistance to cracking, abrasion, cut-though, and chemicals. 484 Silicone-Coated Fiberglass Sleeving PIF-200, SF-200 PIF-200 and SF-200 sleeving offers high heat and superior electrical characteristics in a closely woven, braided fiberglass, uniformly coated with silicone rubber. It provides low temperature flexibility to -70°C and heat protection to 200°C. The fiberglass sleeving material is heat-set, cuts cleanly, and will not fray. It is easy to “pushback” and form over components, connections, and cables. The pressure-sensitive adhesive contains a uniform dispersion of unique oxidation-resistant conductive particles that produce very low resistance through the tape. This feature results in shielding performance approximately 5 dB better than other metal foil shielding tapes. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT® Wire Management Better wire management means better harnesses Self-Fusing Silicone Tape Where a masking wrap or permanently resilient insulation seal is necessary, self-adhering silicone tape is made of special unsupported silicone rubber compound that readily adheres to itself when wrapped under tension and fuses to form a homogenous mass within 24 hours at room temperature or 4 hours at 177°C. The self-adhering silicone is protected with a polyester or polyethylene liner to prevent contamination and blocking. Spiral Wrap Tubing SW Spiral wrap tubing simplifies wire harnessing, cabling, and bundling. Alpha’s SW tubing wraps tightly to the wire and cable being bundled, yet is flexible and simple to apply. All types maintain flexibility even when bent around sharp edges. Breakouts or tapoff connections may be made through the openings of the wrap. SW spiral wrap is constructed from several semirigid tubing materials and then cut on a continual spiral. Expandable Braided Polyester Sleeving GRP-110, GRP-120 GRP-110/120 is a lightweight, expandable woven polyester sleeving that offers high flexibility with high resistance to abrasion and cut-through. The open weave allows for a great range of expansion of the sleeving diameter, thus ensuring ease of installation and gripping action over a wide range of shapes and sizes. GRP sleeving is an ideal protective sleeve for wire bundles, harnesses, pneumatic hoses, hydraulic lines, and highly polished or threaded machine parts. To prevent fraying of ends, GRP-110 and GRP-120 should be cut/sealed with a hot knife. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 485 FIT® Wire Management Better wire management means better harnesses Non-Fraying, Expandable Braid Sleeving GRP-110NF, GRP-120NF GRP-110NF/120NF sleeving cuts cleanly and fray-free with scissors, with no hot knife required. It is a lightweight, expandable woven polyester sleeving that offers high flexibility with high resistance to abrasion and cut-through. The open weave allows for a great range of expansion of the sleeving diameter, thus ensuring ease of installation and gripping action over a wide range of shapes and sizes. GRP sleeving is an ideal protective sleeve for wire bundles, harnesses, pneumatic hoses, hydraulic lines and highly polished or threaded machine parts. Wrappable Sleeving GRP-130 and GRP-130NF A unique split, semirigid braided construction allows GRP-130 and GRP-130NF sleeving to be installed quickly and easily. The lateral split opens up to accommodate a wide variety of bundling requirements, and then closes around the entire installation without the need for any additional fasteners. The sleeving bends to a tight radius without distorting or splitting open and, unlike full rigid tubing, will not impair or affect the flexibility of harnesses. Advanced Protection Expandable Sleeving GRP-160 This heavy-duty, flexible sleeving is extremely versatile in any industrial application requiring abrasion protection without sacrificing flexibility or durability. GRP-160 sleeving is economical and easy to use, cutting cleanly with a hot knife, and expanding up to 50% for easy installation over plugs and connectors. It resists fuels, UV, solvents, salt water, and most chemicals. Advanced Chemical-Resistant Expandable Sleeving GRP-170 GRP-170 is lightweight sleeving, resistant to high temperatures and virtually impervious to solvents. The sleeving resists all known solvents below 200°C chemical resistance, is inert to steam, strong bases, fuels, and acids, and offers high temperature stability, low moisture absorption, excellent dimensional stability and ultra-low wear. 486 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT® Wire Management Better wire management means better harnesses Maximum Protection Expandable Sleeving GRP-180 Expandable Polyester Braided Sleeving XS-100HD Abrasion-Resistant Nylon Sleeving XS-300 For a thick abrasion guard offering extreme protection against abrasion and cut-through on hoses and cables exposed to harsh conditions. GRP-180 provides fuller coverage for increased resistance to abrasion and penetration, and still expands for easy installation over long lengths. The braided construction allows moisture dissipate quickly to prevent rot and fungus. Spirally cut sleeving simplifies wiring, cabling, harnessing, and bundling where breakout or re-entry is required. Tightly woven nylon, with a 45mil wall thickness, makes XS3000 sleeving the perfect solution for protecting cables, hoses and ropes from weather, sunlight and abrasion damage. The sleeving is resistant to chemicals, UV damage and rot, making it suitable for continuous outdoor use under all weather conditions. The flexible sleeving cuts with a scissor and slides easily over any application. Braided Sleeving XS-200N Extreme Performance Expandable Sleeving GRP-200 GRP-200 sleeving uses PTFE to allow the highest levels of performance, including resistance to chemicals, flame, and high temperatures. Thermal stability and low outgassing make it suited to aerospace, military, and hightech applications. GRP-2000 sleeving is suitable for plenum applications. Durable overbraiding for military and commercial cable assemblies protects against abrasion, mildew, and aging. Type XS-200N nylon braided self-fitting cable sleeving has been designed to cover and protect both round and flat cable assemblies. The variety of sizes and self-fitting features make selection easy for solving many of the cable assembly design problems found in electronic, electrical, aerospace, process control, and robotic-automation equipment. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 487 FIT® Wire Management Better wire management means better harnesses Expandable Polyester Webbed Sleeving ZIP-GRP ZIP-GRP expandable webbing offers superb flexibility and high tensile strength while providing added protection against flame, chemicals, and abrasion. With its hook and loop fastening, wires, cable assemblies, and wire harnesses are always accessible and can be easily opened for any number of breakouts. To prevent fraying of ends, ZIP-GRP should be cut/sealed with a hot knife. Lacing Tape Alpha lacing tapes offer high tensile strength and knot retention. Designed to allow a wider contact area with the insulation so that it remains in place, lacing tape is flexible and easy on the assembler’s hands. Once knotted, tape resists slipping and does not increase diameter of harness. Nylon has excellent tensile strength and resists acids, abrasion, flame, and fungus. Polyester has all the characteristics of nylon, but has better resistance to acids, and no appreciable discoloration. Tinned and Silver-Plated Copper Braid A tight weave of multistrand, soft drawn copper wire, either tinned or silver plated, copper braid is an ideal shielding material for shortrun cables providing easy radial termination. In retrofit applications, provides additional shielding efficiency. Tinned copper flat braid, used as a ground strap, provides an excellent, low-resistance ground path. 488 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT > FIT Wire Management > PVC Tubing FIT® Wire Management Multipurpose PVC Tubing PVC-105 Part No. UL 224 VW-1 CSA 198 MIL-I-631D Type F, Form U, Subform Ua, Grade C ASTM D922 • F  lexible wire protection for harnesses and ground straps • Resistance to heat, oil, and abrasion Operating Temperature • -20°C to +105°C Colors • S  ize #24 to 1-1/2 inches: Black, clear • 2 Inches to 2-1/2 inches: Black Physical Properties • T  ensile strength: 2780 psi (19.17 N/mm2) • Elongation: 260% • Specific gravity: 1.32 • Flammability: UL 224 VW-1 Chemical Properties • • • • Corrosive effect: non-corrosive Fungus resistance: no growth UV stable Lead free PVC-105-24 PVC-105-22 PVC-105-20 PVC-105-19 PVC-105-18 PVC-105-17 PVC-105-16 PVC-105-15 PVC-105-14 PVC-105-13 PVC-105-12 PVC-105-11 PVC-105-10 PVC-105-9 PVC-105-8 PVC-105-7 PVC-105-6 PVC-105-5 PVC-105-4 PVC-105-3 PVC-105-2 PVC-105-1 PVC-105-5/16 PVC105-0 PVC-105-3/8 PVC-105-7/16 PVC-105-1/2A PVC-105-9/16 PVC-105-5/8 PVC-105-3/4 PVC-105-7/8 PVC-105-1IN PVC-105-1-1/8 PVC-105-1-1/4 PVC-105-1-1/2 PVC-105-2IN PVC-105-2-1/2 Inside Diameter, Min. Inch mm 0.022 0.56 0.025 0.64 0.032 0.81 0.036 0.91 0.040 1.02 0.045 1.14 0.051 1.30 0.057 1.45 0.064 1.63 0.072 1.83 0.081 2.06 0.091 2.31 0.102 2.59 0.114 2.90 0.129 3.28 0.144 3.66 0.162 4.11 0.183 4.65 0.204 5.18 0.229 5.82 0.258 6.55 0.289 7.34 0.313 7.95 0.325 8.26 0.375 9.53 0.438 11.13 0.500 12.70 0.562 14.27 0.625 15.88 0.750 19.05 0.875 22.23 1.000 25.40 1.125 28.58 1.250 31.75 1.500 38.10 2.000 50.80 2.500 63.50 Wall Thickness, Inside Nom. Diameter, Max. Inch mm Inch mm 0.027 0.69 0.012 0.30 0.032 0.81 0.012 0.30 0.039 0.99 0.016 0.41 0.044 1.12 0.016 0.41 0.049 1.24 0.016 0.41 0.054 1.37 0.016 0.41 0.061 1.55 0.016 0.41 0.067 1.70 0.016 0.41 0.072 1.83 0.016 0.41 0.08 2.03 0.016 0.41 0.089 2.26 0.016 0.41 0.101 2.57 0.016 0.41 0.112 2.84 0.016 0.41 0.124 3.15 0.020 0.51 0.141 3.58 0.020 0.51 0.158 4.01 0.020 0.51 0.178 4.52 0.020 0.51 0.198 5.03 0.020 0.51 0.224 5.69 0.020 0.51 0.249 6.32 0.020 0.51 0.278 7.06 0.020 0.51 0.311 7.90 0.020 0.51 0.334 8.48 0.025 0.64 0.347 8.81 0.020 0.51 0.399 10.13 0.025 0.64 0.462 11.73 0.025 0.64 0.524 13.31 0.025 0.64 0.592 15.04 0.030 0.76 0.655 16.64 0.030 0.76 0.786 19.96 0.035 0.89 0.911 23.14 0.035 0.89 1.036 26.31 0.035 0.89 1.161 29.49 0.010 0.25 1.29 32.77 0.040 1.02 1.55 39.37 0.045 1.14 2.07 52.58 0.060 1.52 2.53 64.26 0.070 1.78 Standard Put-Ups Ft 1000 100, 1000 1000 1000 100, 1000 100, 1000 100, 1000 100, 1000 100, 500 100, 500 500 100, 500 500 500 100, 500 100, 500 100, 500 100, 500 100, 250 100, 250 250 100, 250 100, 250 100, 250 100, 250 100 100 100 100 50 50 50 50 50 50 50 50 m 305 30.5, 305 305 305 30.5, 305 30.5, 305 30.5, 305 30.5, 305 30.5, 152 30.5, 152 152 30.5, 152 152 152 30.5, 152 30.5, 152 30.5, 152 30.5, 152 30.5, 76 30.5, 76 76 30.5, 76 30.5, 76 30.5, 76 30.5, 76 30.5 30.5 30.5 30.5 15.2 15.2 15.2 15.2 15.2 15.2 15.2 15.2 Electrical Properties • D  ielectric strength: 870 V/mil (343 kV/cm) • Volume resistivity: 2 x 1014 ohm-cm • UL voltage rating Sizes #24 to #1: UL rated 300 V 5/16 to 2 inches: UL rated 600 V Availability • See table • PVC-105-24 to PVC-105-1 are available air spooled on the largest put-ups only Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 489 FIT > FIT Wire Management > Flexible Liquid-Tight PVC Tubing FIT® Wire Management Flexible Liquid-Tight PVC Tubing FNT Tubing PVC Tubing UL 1696 CSA C22.2 No. 227.3-05 Part No. Trade Size FNT-1/4* FNT-3/8 FNT-1/2 FNT-3/4 FNT-1 1/4 3/8 1/2 3/4 1 Inside Diameter, Min. Inch mm 0.385 9.78 0.484 12.29 0.622 15.80 0.820 20.83 1.041 26.44 Inside Diameter, Max. Inch mm 0.405 10.29 0.504 12.80 0.642 16.31 0.840 21.34 1.066 27.08 Outside Diameter, Min. Inch mm 0.560 14.22 0.690 17.53 0.820 20.83 1.030 26.16 1.290 32.77 Outside Diameter, Max. Inch mm 0.575 14.61 0.710 18.03 0.840 21.34 1.050 26.67 1.315 33.40 *Not CSA certified Operating Temperature • -18°C to +50°C Color • Black Materials • Liquid-tight PVC tubing Chemical Properties • • • • Corrosive effect: none Fungus resistance: no growth Resists oil and water Lead free Availability 25 ft (7.5 m) 100 ft (30.5 m) 490 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT > FIT Wire Management > Liquid-Tight Nylon Connectors FIT® Wire Management Liquid-Tight Nylon Connectors SLC or RLC Part No. Straight SLC-1/4* SLC-3/8 SLC-1/2 SLC-3/4 SLC-1 90° — RLC-3/8 RLC-1/2 RLC-3/4 RLC-1 Trade Size Thread Size 1/4 3/8 1/2 3/4 1 — 1/2 NPT 1/2 NPT 3/4 NPT 1 NPT *Snap-on connector, not CSA certified Operating Temperature • +125°C Color • Black Materials • Nylon connector • Supplied with o-ring and steel locking nut Properties • R  esists salt water, weak acids, gasoline, alcohol, oil, grease, and common solvents • Flammability rating: UL 94V-2 Availability 10-piece packages 100-piece packages Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 491 FIT > FIT Wire Management > Slit Loom Tubing FIT® Wire Management Convoluted Slit Loom Tubing Type 492 Part No. • Abrasion and fluid resistant • Light weight • Easy, flexible cable breakouts 492250 492350 492413 492500 492625 492750 492100 492150 492200 Inside Diameter, Min. Inch mm 0.256 6.50 0.341 8.66 0.399 10.13 0.473 12.01 0.603 15.32 0.707 17.96 1.020 25.91 1.566 39.78 1.969 50.01 Inside Diameter, Max. Inch mm 0.276 7.01 0.38 9.65 0.437 11.10 0.516 13.11 0.639 16.23 0.759 19.28 1.069 27.15 1.647 41.83 2.038 51.77 Outside Diameter, Min. Inch mm 0.373 9.47 0.496 12.60 0.569 14.45 0.664 16.87 0.802 20.37 0.95 24.13 1.251 31.78 1.867 47.42 2.285 58.04 Outside Diameter, Max. Inch mm 0.398 10.11 0.526 13.36 0.597 15.16 0.70 17.78 0.837 21.26 0.989 25.12 1.304 33.12 1.947 49.45 2.388 60.66 Operating Temperature • -40°C to +93°C Color • Black Material • Polyethylene Chemical Properties • Corrosive effect: none • Fungus resistance: no growth • Lead free Electrical Properties • Volume resistivity: 1015 ohm-cm Availability 100 ft (30.5 m) 492 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT > FIT Wire Management > Loom Tee Connector Fittings FIT® Wire Management Loom Tee Connector Fittings Type 493 Part No. 493100 Operating Temperature • -40°C to +90°C 493101 493102 493103 493110 493118 Left Inch 0.413 or 0.500 0.500 0.500 0.750 0.413 1.000 mm 10.49 or 12.70 12.70 12.70 19.05 10.49 25.40 Mating Loom Size Center Inch mm 0.413 or 10.49 or 0.500 12.70 0.350 8.89 0.413 10.49 0.500 12.70 0.350 8.89 0.625 15.88 Right Inch 0.413 or 0.500 0.750 0.750 0.750 0.350 0.100 mm 10.49 or 12.70 19.05 19.05 19.05 8.89 2.54 Color • Black Material • Polypropylene Chemical Properties • Corrosive effect: none • Fungus resistance: no growth • Lead free Availability Single pieces Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 493 FIT > FIT Wire Management > Zipper Tubing FIT® Wire Management Zipper Tubing™ ZIP-41 Operating Temperature Chemical Properties • -20°C to +105°C • Fungus resistance: no growth • Lead free Color Electrical Properties • Black • D  ielectric strength: 700 V/mil (275.8 kV/cm) • Volume resistivity: 1010 ohms/cm Material • PVC MIL-I-631 UL 224 VW-1 Physical Properties • T  ensile strength: 1800 psi (12.4 N/mm2) • Elongation: 200% min. • Flammability: UL VW-1 Loc-Trac® provides an effective closure that is ideal for use where the assembly will be subjected to random flexing. Protection against flame, chemicals, and abrasion. 494 Part No. ZIP-41-1/2 ZIP-41-5/8 ZIP-41-3/4 ZIP-41-7/8 ZIP-41-1IN ZIP-41-1-1/4 ZIP-41-1-1/2 ZIP-41-1-3/4 ZIP-41-2IN ZIP-41-2-1/4 ZIP-41-3IN Inside Diameter, Nom. Inch mm 0.500 12.70 0.625 15.88 0.750 19.05 0.875 22.23 1.000 25.40 1.250 31.75 1.500 38.10 1.750 44.45 2.000 50.80 2.250 57.15 3.000 76.20 Availability 25 ft (30.5 m) 100 ft (30.5 m) Each spool comes with two Loc-Trac fasteners and installation instructions. Wall Thickness, Nom. Inch mm 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 Flat Width, Nom. Inch mm 2.000 50.80 2.375 60.33 2.750 69.85 3.125 79.38 3.562 90.47 4.125 104.78 4.875 123.83 5.625 142.88 6.375 161.93 7.500 190.50 10.000 254.00 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT > FIT Wire Management > Spiral Wrap Tubing FIT® Wire Management Spiral Wrap Tubing SW • Flexible cable bundling • Easy breakouts See table for specifications Material Colors Temperature Range (°C) Abrasion Resistance (Taber) Flame Rating Tensile Strength (psi (N/mm2) Water Absorption (%) Dielectric Constant (Max.) Effects of Alkalis and Acids Weather Resistance Specs SW-1 to SW-6 Natural Polyethylene Natural SW-10 to SW-14 Flame-Retardant Polyethylene White SW-20 to SW-25 SW-30 to SW-35 SW-50 to SW-53 Natural, Black SW-40 to SW-45 UV-Resistant Polyethylene Black Nylon PTFE Natural -66 to +88 -20 to +80 -40 to +121 -268 to +260 -66 to +88 -20 to +80 22 27 6-8 7 20 Excellent Not rated UL 1441 Self-extinguishing Self-extinguishing UL VW-1 Not rated Self-extinguishing 1800 (12.41) 1300 (8.96) 12,000 (82.74) 3000 (20.68) 2000 (13.79) 3000 (20.68) 0.014 0.02 1.5 0.005 0.03 — — 2.58 4.0 2.1 — — None None None None None Satisfactory* N/A N/A N/A Excellent N/A N/A UL UZKX2 ASTM-D-4066, Group 2, Class 1 UL UZKX2 ASTM-D-3295-01, Group 4 A-A-59602, Type 3, Class 1 (as noted) UL UZKX2 MIL-I-631D, Type A, Form U MIL-P-21922B, Type 1 Class L A-A-59602, Type 1, Class 2 — UL UZKX2 MIL-I-631D, Type A, Form U MIL-P-21922B ASTM 1248-65T Type 1 Class A, Grade 3 A-A-59602, Type 1, Class 1 UL UZKX2 A-A-59602, Type 1, Class 3 PVC Black *Satisfactory except for high concentrations; not recommended for organic solvents. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 495 FIT > FIT Wire Management > Spiral Wrap Tubing FIT® Wire Management Spiral Wrap Tubing SW • Flexible cable bundling • Easy breakouts See table for specifications Part No. Material Trade Size SW-1 SW-2 SW-3 SW-4 SW-5 SW-6 Natural PE Natural PE Natural PE Natural PE Natural PE Natural PE 1/8 1/4 3/8 1/2 3/4 1 Outside Diameter, Nom. Inch mm 0.125 3.18 0.250 6.35 0.375 9.53 0.500 12.70 0.750 19.05 1.000 25.40 Wall Thickness, Nom. Inch mm 0.032 0.81 0.045 1.14 0.052 1.32 0.062 1.57 0.065 1.65 0.080 2.03 Right-Hand Pitch, Nom. Inch mm 0.187 4.75 0.375 9.53 0.438 11.13 0.563 14.30 0.750 19.05 1.000 25.40 Ft 25, 100, 500 25, 100, 500 25, 100 25, 100 25, 100, 500 25, 100, 500 m 7.6, 30.5, 152 7.6, 30.5, 152 7.6, 30.5 7.6, 30.5 7.6, 30.5, 152 7.6, 30.5, 152 SW-10 SW-11 SW-12 SW-13 SW-14 FR PE FR PE FR PE FR PE FR PE 1/8 1/4 3/8 1/2 3/4 0.125 0.250 0.375 0.500 0.750 3.18 6.35 9.53 12.70 19.05 0.032 0.045 0.052 0.062 0.065 0.81 1.14 1.32 1.57 1.65 0.187 0.375 0.438 0.563 0.750 4.75 9.53 11.13 14.30 19.05 25, 100, 500 25, 100, 500 25, 100 25, 100 25, 100 7.6, 30.5, 152 7.6, 30.5, 152 7.6, 30.5 7.6, 30.5 7.6, 30.5 SW-20 SW-21 SW-22 SW-23 SW-24 SW-25 Nylon Nylon Nylon Nylon Nylon Nylon 1/8 1/4 3/8 1/2 3/4 1 0.125 0.250 0.375 0.500 0.750 1.000 3.18 6.35 9.53 12.70 19.05 25.40 0.015 0.025 0.035 0.035 0.032 0.032 0.38 0.64 0.89 0.89 0.81 0.81 0.187 0.375 0.438 0.500 0.750 1.000 4.75 9.53 11.13 12.70 19.05 25.40 25, 100, 500 25, 100, 500 25, 100 25, 100 25, 100, 500 25, 100 7.6, 30.5, 152 7.6, 30.5, 152 7.6, 30.5 7.6, 30.5 7.6, 30.5, 152 7.6, 30.5 SW-30 SW-31 SW-32** SW-33** SW-34** SW-35 PTFE PTFE PTFE PTFE PTFE PTFE 1/8 1/4 3/8 1/2 3/4 1 0.125 0.250 0.375 0.500 0.750 1.000 3.18 6.35 9.53 12.70 19.05 25.40 0.030 0.030 0.030 0.030 0.032 0.040 0.76 0.76 0.76 0.76 0.81 1.02 0.187 0.375 0.438 0.500 0.750 1.000 4.75 9.53 11.13 12.70 19.05 25.40 25, 100 25, 100 25, 100 25, 100 25, 100 25, 100 7.6, 30.5 7.6, 30.5 7.6, 30.5 7.6, 30.5 7.6, 30.5 7.6, 30.5 SW-40 SW-41 SW-42 SW-43 SW-44 SW-45 UV-Res. PE UV-Res. PE UV-Res. PE UV-Res. PE UV-Res. PE UV-Res. PE 1/8 1/4 3/8 1/2 3/4 1 0.125 0.250 0.375 0.500 0.750 1.000 3.18 6.35 9.53 12.70 19.05 25.40 0.032 0.045 0.052 0.062 0.065 0.080 0.81 1.14 1.32 1.57 1.65 2.03 0.187 0.375 0.438 0.500 0.750 1.000 4.75 9.53 11.13 12.70 19.05 25.40 25, 100, 500 25, 100, 500 25, 100 25, 100 25, 100, 500 25, 100, 500 7.6, 30.5, 152 7.6, 30.5, 152 7.6, 30.5 7.6, 30.5 7.6, 30.5, 152 7.6, 30.5, 152 SW-50 SW-51 SW-52 SW-53 PVC PVC PVC PVC 1/8 1/4 3/8 1/2 0.125 0.250 0.375 0.500 3.18 6.35 9.53 12.70 0.032 0.045 0.052 0.062 0.81 1.14 1.32 1.57 0.187 0.375 0.438 0.500 4.75 9.53 11.13 12.70 25, 100 25, 100 25, 100 25, 100 7.6, 30.5 7.6, 30.5 7.6, 30.5 7.6, 30.5 Standard Put-Ups* *May contain multiple lengths. **Does not meet A-A-59602 Type 3 Class 1 496 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT > FIT Wire Management > Flexible PTFE Thin-Wall Tubing FIT® Wire Management Flexible PTFE Thin-Wall Tubing TFT-200 Operating Temperature Chemical Properties • -75°C to +260°C • Natural • • • • Material Electrical Properties • PTFE • D  ielectric strength: 1400 V/mil (55 kV/cm) • Volume resistivity: 1018 ohm-cm • Dielectric constant: 2.1 Color ASTM D 3295-81a Type I Class B AMS 3655 • F  lexible wire protection for harnesses and ground straps • Resistance to heat, oil, and abrasion Physical Properties • T  ensile strength: 2000 psi (13.7 N/mm2) • Elongation: 200% min. • Specific gravity: 2.18 • Flammability rating: UL 94V-0 Corrosive effect: none Fungus resistance: no growth Water absorption: 0.01% Lead free Availability See table Spools may contain multiple lengths TFT-200-7 and larger supplied as coils Part No. TFT-200-30 TFT-200-28 TFT-200-26 TFT-200-24 TFT-200-22 TFT-200-20 TFT-200-19 TFT-200-18 TFT-200-17 TFT-200-16 TFT-200-15 TFT-200-14 TFT-200-13 TFT-200-12 TFT-200-11 TFT-200-10 TFT-200-9 TFT-200-8 TFT-200-7 TFT-200-6 TFT-200-5 TFT-200-4 TFT-200-3 TFT-200-2 TFT-200-1 TFT-200-0 Inside Diameter, Min. Inch mm 0.010 0.25 0.013 0.33 0.016 0.41 0.020 0.51 0.026 0.66 0.032 0.81 0.036 0.91 0.040 1.02 0.045 1.14 0.051 1.30 0.057 1.45 0.064 1.63 0.072 1.83 0.081 2.06 0.091 2.31 0.102 2.59 0.114 2.90 0.129 3.28 0.144 3.66 0.162 4.11 0.182 4.62 0.204 5.18 0.229 5.82 0.258 6.55 0.289 7.34 0.325 8.26 Inside Diameter, Max. Inch mm 0.015 0.38 0.018 0.46 0.021 0.53 0.026 0.66 0.032 0.81 0.04 1.02 0.042 1.07 0.046 1.17 0.052 1.32 0.058 1.47 0.065 1.65 0.072 1.83 0.081 2.06 0.091 2.31 0.101 2.57 0.112 2.84 0.124 3.15 0.139 3.53 0.155 3.94 0.174 4.42 0.195 4.95 0.218 5.54 0.244 6.20 0.273 6.93 0.305 7.75 0.342 8.69 Wall Thickness, Min. Inch mm 0.009 0.23 0.009 0.23 0.009 0.23 0.010 0.25 0.010 0.25 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.015 0.38 0.015 0.38 0.015 0.38 0.015 0.38 0.015 0.38 0.015 0.38 0.015 0.38 0.015 0.38 0.015 0.38 Standard Put-Ups Ft m 100, 500, 1000 30.5, 152, 305 100, 500, 1000 30.5, 152, 305 100, 500, 1000 30.5, 152, 305 100, 500, 1000 30.5, 152, 305 100, 500, 1000 30.5, 152, 305 100, 500, 1000 30.5, 152, 305 100, 1000 30.5, 305 100, 500, 1000 30.5, 152, 305 100, 500, 1000 30.5, 152, 305 100, 1000 30.5, 305 100, 1000 30.5, 305 100, 500 30.5, 152 100, 500 30.5, 152 100, 500 30.5, 152 100, 500 30.5, 152 100, 500 30.5, 152 100, 500 30.5, 152 100 30.5 100 30.5 100* 30.5* 100* 30.5* 100* 30.5* 100* 30.5* 100* 30.5* 100* 30.5* 100* 30.5* *Supplied as coils. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 497 FIT > FIT Wire Management > Flexible PTFE Standard-Wall Tubing FIT® Wire Management Flexible PTFE Standard-Wall Tubing TFT-250 Operating Temperature Chemical Properties • -75°C to +260°C • Natural • • • • Material Electrical Properties • PTFE • D  ielectric strength: 1400 V/mil (551 kV/cm) • Volume resistivity: 1018 ohm-cm • Dielectric constant: 2.1 Color ASTM D 3295-81a Type I Class C MIL-I-22129 • E  xcellent heat and chemical resistance • Flexible wire protection for harnesses and ground straps • Resistance to heat, oil, and abrasion Part No. TFT-250-24 TFT-250-22 TFT-250-20 TFT-250-19 TFT-250-18 TFT-250-17 TFT-250-16 TFT-250-15 TFT-250-14 TFT-250-13 TFT-250-12 TFT-250-11 TFT-250-10 TFT-250-9 TFT-250-8 TFT-250-7 TFT-250-6 TFT-250-5 TFT-250-4 TFT-250-3 TFT-250-2 TFT-250-1 TFT-250-0 Inside Diameter, Min. Inch mm 0.020 0.51 0.025 0.64 0.032 0.81 0.036 0.91 0.040 1.02 0.045 1.14 0.051 1.30 0.057 1.45 0.064 1.63 0.072 1.83 0.081 2.06 0.091 2.31 0.102 2.59 0.114 2.90 0.129 3.28 0.144 3.66 0.162 4.11 0.182 4.62 0.204 5.18 0.229 5.82 0.258 6.55 0.289 7.34 0.325 8.26 Physical Properties • T  ensile strength: 2000 psi (13.7 N/mm2) • Elongation: 200% min. • Specific gravity: 2.18 • Flammability rating: UL 94V-0 Corrosive effect: none Fungus resistance: no growth Water absorption: 0.01% Lead free Availability See table Spools may contain multiple lengths TFT-200-7 and larger supplied as coils Inside Diameter, Max. Inch mm 0.026 0.66 0.032 0.81 0.040 1.02 0.044 1.12 0.049 1.24 0.054 1.37 0.061 1.55 0.067 1.70 0.074 1.88 0.082 2.08 0.091 2.31 0.101 2.57 0.112 2.84 0.124 3.15 0.141 3.58 0.158 4.01 0.178 4.52 0.196 4.98 0.224 5.69 0.249 6.32 0.278 7.06 0.311 7.90 0.342 8.69 Wall Thickness, Min. Inch mm 0.012 0.30 0.012 0.30 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 Standard Put-Ups Ft m 100, 500, 1000 30.5, 152, 305 100, 500, 1000 30.5, 152, 305 100, 500, 1000 30.5, 152, 305 100, 500, 1000 30.5, 152, 305 100, 500, 1000 30.5, 152, 305 100, 1000 30.5, 305 100, 500, 1000 30.5, 152, 305 100, 500 30.5, 152 100, 500 30.5, 152 100 30.5 100 30.5 100, 500 30.5, 152 100, 500 30.5, 152 100, 500 30.5, 152 100 30.5 100 30.5 100* 30.5* 100* 30.5* 100* 30.5* 100* 30.5* 100* 30.5* 100* 30.5* 100* 30.5* *Supplied as coils. 498 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT > FIT Wire Management > Acrylic-Coated Fiberglass Sleeving FIT® Wire Management Acrylic-Coated Fiberglass Sleeving AF-155 MIL-I-3190/3 Grade C1 NEMA TF-1 Chemical Properties • Corrosive effect: none • Fungus resistance: no growth • Lead free Operating Temperature • -30°C to +155°C Electrical Properties Color • D  ielectric strength: 2500 V/mil (984 kV/cm) • Dielectric constant: 2.5 • Volume resistivity: 1010 ohm-cm • Natural Material • Acrylic-coated fiberglass braid Physical Properties See table • Elongation: 150% min. • Low-temperature (-10°C) flexing: no cracking Part No. AF-155-24 AF-155-22 AF-155-20 AF-155-18 AF-155-16 AF-155-15 AF-155-14 AF-155-13 AF-155-12 AF-155-11 AF-155-10 AF-155-9 AF-155-8 AF-155-7 AF-155-6 AF-155-5 AF-155-4 AF-155-3 AF-155-2 AF-155-1 AF-155-0 AF-155-3/8 AF-155-7/16 AF-155-1/2 AF-155-5/8 AF-155-3/4 AF-155-7/8 AF-155-1IN Inside Diameter, Min. Inch mm 0.020 0.51 0.025 0.64 0.032 0.81 0.040 1.02 0.051 1.30 0.057 1.45 0.064 1.63 0.072 1.83 0.081 2.06 0.091 2.31 0.102 2.59 0.114 2.90 0.129 3.28 0.144 3.66 0.162 4.11 0.182 4.62 0.204 5.18 0.229 5.82 0.258 6.55 0.289 7.34 0.325 8.26 0.375 9.53 0.438 11.13 0.500 12.70 0.625 15.88 0.750 19.05 0.875 22.23 1.000 25.40 Inside Diameter, Max. Inch mm 0.027 0.69 0.032 0.81 0.039 0.99 0.049 1.24 0.061 1.55 0.067 1.70 0.074 1.88 0.082 2.08 0.091 2.31 0.101 2.57 0.112 2.84 0.124 3.15 0.141 3.58 0.158 4.01 0.178 4.52 0.198 5.03 0.224 5.69 0.249 6.32 0.278 7.06 0.311 7.90 0.347 8.81 0.399 10.13 0.462 11.73 0.524 13.31 0.655 16.64 0.786 19.96 0.911 23.14 1.036 26.31 Availability Spools may contain multiple lengths Wall Thickness, Min. Inch mm 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Standard Put-Ups Ft m 100, 500 30.5, 152 100, 500 30.5, 152 100, 500 30.5, 152 100, 500 30.5, 152 100, 500 30.5, 152 100, 500 30.5, 152 100, 500 30.5, 152 100, 250 30.5, 76 100, 250 30.5, 76 100, 250 30.5, 76 100, 250 30.5, 76 100, 250 30.5, 76 100, 250 30.5, 76 100, 250 30.5, 76 100, 250 30.5, 76 100, 250 30.5, 76 100, 250 30.5, 76 100, 250 30.5, 76 100, 250 30.5, 76 100, 125 30.5, 38 100, 125 30.5, 38 125, 250 38, 76 125 38 100 30.5 100 30.5 100 30.5 100 30.5 100 30.5 499 FIT > FIT Wire Management > PVC-Coated Fiberglass Sleeving FIT® Wire Management PVC-Coated Fiberglass Sleeving PIF-130 • H  igh temperature, abrasion, and oil resistance • Resists fraying, bending, and knotting Operating Temperature Standard Wall Thickness Inside Diameter, Min. Part No. Inch mm PIF-130-20 0.032 0.81 PIF-130-18 0.040 1.02 PIF-130-16 0.051 1.30 PIF-130-14 0.064 1.63 PIF-130-12 0.081 2.06 PIF-130-10 0.102 2.59 PIF-130-8 0.129 3.28 PIF-130-6 0.162 4.11 PIF-130-4 0.204 5.18 PIF-130-2 0.258 6.55 PIF-130-0 0.325 8.26 PIF-130-3/8 0.375 9.53 PIF-130-7/16 0.438 11.13 PIF-130-1/2A 0.500 12.70 PIF-130-5/8 0.625 15.88 PIF-130-3/4 0.750 19.05 PIF-130-7/8 0.875 22.23 PIF-130-1IN 1.000 25.40 500 • D  ielectric strength: 5000 V/mil (1968 kV/cm) • Volume resistivity: 109 ohm-cm Color • Black Availability Material • PVC-coated fiberglass braid Inside Diameter, Max. Inch mm 0.039 0.99 0.049 1.24 0.061 1.55 0.074 1.88 0.091 2.31 0.112 2.84 0.141 3.58 0.178 4.52 0.224 5.69 0.278 7.06 0.347 8.81 0.399 10.13 0.462 11.73 0.524 13.31 0.655 16.64 0.786 19.96 0.911 23.14 1.036 26.31 • Corrosive effect: non-corrosive • Fungus resistance: no growth • Lead free Electrical Properties • -20°C to +130°C UL 1441 (600 VRMS) UL VW-1 MIL-I-3190/2 Class 130 Type B Category b NEMA TF-1 Grade A Chemical Properties See tables Spools may contain multiple lengths Wall Thickness, Min. Inch mm 0.013 0.33 0.015 0.38 0.015 0.38 0.015 0.38 0.015 0.38 0.018 0.46 0.018 0.46 0.020 0.51 0.020 0.51 0.020 0.51 0.025 0.64 0.025 0.64 0.025 0.64 0.025 0.64 0.025 0.64 0.025 0.64 0.025 0.64 0.025 0.64 Standard Put-Ups Ft m 100, 500, 1000 30.5, 152, 305 100, 500, 1000 30.5, 152, 305 100, 1000 30.5, 305 100 30.5 100, 500 30.5, 152 100, 500 30.5, 152 100, 500 30.5, 152 100, 250 30.5, 76 100, 250 30.5, 76 100, 250 30.5, 76 100 30.5 100 30.5 100 30.5 100 30.5 100 30.5 100 30.5 100 30.5 100 30.5 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT > FIT Wire Management > Silicone-Coated Fiberglass Sleeving FIT® Wire Management Silicone-Coated Fiberglass Sleeving PIF-200, SF-200 Operating Temperature Chemical Properties • -70°C to +200°C • Corrosive effect: none • Fungus resistance: no growth • Lead free Color • Natural Electrical Properties Material UL 1441 (600 VRMS) MIL-I-3190/6 Class 20 Type D Category C NEMA TF-1 Grade A • Highly flexible routing • Extreme abrasion resistance • Superior electrical properties Part No. PIF-200-24 PIF-200-22 PIF-200-20 PIF-200-18 PIF-200-17 PIF-200-16 PIF-200-15 PIF-200-14 PIF-200-13 PIF-200-12 PIF-200-11 PIF-200-10 PIF-200-9 PIF-200-8 PIF-200-7 PIF-200-6 PIF-200-5 PIF-200-4 PIF-200-3 PIF-200-2 PIF-200-1 PIF-200-0 PIF-200-3/8 PIF-200-7/16 PIF-200-1/2A PIF-200-5/8 SF-200-3/4 SF-200-7/8 SF-200-1IN Inside Diameter, Min. Inch mm 0.020 0.51 0.025 0.64 0.032 0.81 0.040 1.02 0.045 1.14 0.051 1.30 0.057 1.45 0.064 1.63 0.072 1.83 0.081 2.06 0.091 2.31 0.102 2.59 0.114 2.90 0.129 3.28 0.144 3.66 0.162 4.11 0.182 4.62 0.204 5.18 0.229 5.82 0.258 6.55 0.289 7.34 0.313 7.95 0.375 9.53 0.438 11.13 0.500 12.70 0.625 15.88 0.750 19.05 0.875 22.23 1.000 25.40 • D  ielectric strength: 15,000 V/mil (5905 kV/cm) • Volume resistivity: 6 x 1013 ohm-cm • Dielectric constant: 2.8 • S  ilicone rubber-coated fiberglass braid Physical Properties • T  ensile strength: 1200 psi (8.2 N/mm2) • Elongation: 420% min. Availability See table Spools may contain multiple lengths Inside Diameter, Max. Inch mm 0.027 0.69 0.032 0.81 0.039 0.99 0.049 1.24 0.054 1.37 0.061 1.55 0.067 1.70 0.074 1.88 0.082 2.08 0.091 2.31 0.101 2.57 0.112 2.84 0.124 3.15 0.141 3.58 0.158 4.01 0.178 4.52 0.198 5.03 0.224 5.69 0.249 6.32 0.278 7.06 0.311 7.90 0.347 8.81 0.398 10.11 0.462 11.73 0.524 13.31 0.655 16.64 0.786 19.96 0.911 23.14 1.036 26.31 Wall Thickness, Min. Inch mm 0.011 0.28 0.013 0.33 0.013 0.33 0.015 0.38 0.015 0.38 0.015 0.38 0.015 0.38 0.015 0.38 0.015 0.38 0.015 0.38 0.018 0.46 0.018 0.46 0.018 0.46 0.018 0.46 0.018 0.46 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.025 0.64 0.025 0.64 0.025 0.64 0.025 0.64 0.025 0.64 0.025 0.64 0.025 0.64 Standard Put-Ups Ft m 100, 500, 1000 30.5, 152, 305 100, 500, 1000 30.5, 152, 305 100, 500, 1000 30.5, 152, 305 100, 500, 1000 30.5, 152, 305 500, 1000 152, 305 100, 500, 1000 30.5, 152, 305 100, 1000 30.5, 305 100, 500 30.5, 152 100, 500 30.5, 152 100, 500 30.5, 152 500 152 100, 500 30.5, 152 100, 500 30.5, 152 100, 500 30.5, 152 100, 500 30.5, 152 25, 100 7.6, 30.5 25, 100 7.6, 30.5 100 30.5 25, 100 7.6, 30.5 25, 100 7.6, 30.5 100 30.5 100 30.5 25, 100 7.6, 30.5 25, 100 7.6, 30.5 25, 100 7.6, 30.5 25, 100 7.6, 30.5 100 30.5 100 30.5 100 30.5 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 501 FIT > FIT Wire Management > Uncoated Fiberglass Sleeving FIT® Wire Management Uncoated Fiberglass Sleeving PIF-240 UL 1441 (500 VRMS) UL VW-1 MIL-Y-1140 ASTM D 350/372 Class C Chemical Properties • Extreme flexibility • Extreme heat environments Electrical Properties Operating Temperature • -60°C to +648°C • Corrosive effect: none • Fungus resistance: no growth • Lead free • Volume resistivity: 1015 ohm-cm Availability 100 ft (30.5 m) Spools may contain multiple lengths Color • Natural Material • H  eat-annealed braided fiberglass Part No. PIF-240-20 PIF-240-18 PIF-240-16 PIF-240-15 PIF-240-14 PIF-240-12 PIF-240-11 PIF-240-10 PIF-240-9 PIF-240-8 PIF-240-7 PIF-240-6 PIF-240-5 PIF-240-4 PIF-240-3 PIF-240-2 PIF-240-1 PIF-240-0 PIF-240-3/8 PIF-240-7/16 PIF-240-1/2A PIF-240-5/8 PIF-240-3/4 PIF-240-7/8 PIF-240-1IN 502 Inside Diameter, Min. Inch mm 0.032 0.81 0.040 1.02 0.051 1.30 0.057 1.45 0.064 1.63 0.081 2.06 0.091 2.31 0.102 2.59 0.114 2.90 0.129 3.28 0.144 3.66 0.162 4.11 0.182 4.62 0.204 5.18 0.229 5.82 0.258 6.55 0.289 7.34 0.325 8.26 0.375 9.53 0.438 11.13 0.500 12.70 0.625 15.88 0.750 19.05 0.875 22.23 1.000 25.40 Inside Diameter, Max. Inch mm 0.039 0.99 0.049 1.24 0.061 1.55 0.067 1.70 0.074 1.88 0.091 2.31 0.101 2.57 0.112 2.84 0.124 3.15 0.141 3.58 0.158 4.01 0.178 4.52 0.198 5.03 0.224 5.69 0.249 6.32 0.278 7.06 0.311 7.90 0.347 8.81 0.399 10.13 0.462 11.73 0.524 13.31 0.655 16.64 0.783 19.89 0.991 25.17 1.026 26.06 Wall Thickness, Min. Inch mm 0.009 0.23 0.011 0.28 0.011 0.28 0.011 0.28 0.011 0.28 0.011 0.28 0.011 0.28 0.011 0.28 0.011 0.28 0.011 0.28 0.013 0.33 0.013 0.33 0.013 0.33 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 0.018 0.46 0.018 0.46 0.018 0.46 0.018 0.46 0.018 0.46 0.018 0.46 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT > FIT Wire Management > Copper EMI Shielding Tape FIT® Wire Management Copper EMI Shielding Tape CST Series UL 510 ASTM D 1000, Method 303 MIL-STD-202C Physical Properties • -40°C to +205°C • T  ensile strength: 21 lb/inch (0.145 N/mm2) • Adhesion: 40 oz/inch • Foil thickness: 0.0014 inch (0.04 mm) • Adhesive thickness: 0.00015 inch (0.004 mm) • Flammability: flame resistant per UL 510 Color Electrical Properties • Copper • E  lectrical resistance through tape: Self-Fusing Silicone Tape FIT® Wire Management Self-Fusing Silicone Tape A-A-59163 Material • C  ures within 48 hours at room temperature or 4 hours at 177°C • No adhesive required • L  ow-cost seal for electrical insulation, cables harnesses, splices, hot air ducting, and electrical wire wrap • C  onforms to irregular shapes to protect, secure, insulate, mask • Resists outside weathering Physical Properties • T  ensile strength: 700 psi (4.8 N/mm2) min. • Elongation: 300% min. • Water absorption: 3% max. • Bond strength: 20 lbf (25 kgf) • Shelf life: 1 year at 37.3°C for unopened container Electrical Properties Operating Temperature • -90°C to +260°C (continuous) • D  ielectric strength: 400 V/mil (157 kV/cm) • Volume resistivity: 1 x 1013 ohm-cm Availability Colors • 14-ft put-ups (all colors) • 35-ft put-ups (black, red) • R  ed, black, blue, yellow, white, green Part No. TY2001 504 • Silicone Width Thickness Inch mm Inch mm 1.000 25.40 0.020 0.51 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT > FIT Wire Management > Expandable Braided Sleeving FIT® Wire Management Expandable Braided Sleeving GRP-110, GRP-120 Operating Temperature Chemical Properties • -75°C to +125°C • 250°C melt temperature • • • • • Color UL UZKX2 UL VW-1 (GRP-120) MIL-I-631 • Light weight, flexible routing • High abrasion and cut-through resistance • GRP-110: Black or natural • GRP-120: Black with white tracer thread or white with black tracer thread Corrosive effect: noncorrosive Fungus resistance: no growth GRP-120: flame retardant Halogen free Lead free Availability See tables Spools may contain multiple lengths Material • Braided polyester • Should be cut with hot knife Physical Properties • T  ensile strength: GRP-110: 85,000 psi (586 N/mm2) GRP-120: 55,000 psi (379 N/mm2) General-Purpose Sleeving Inside Diameter, Min. Part No. Inch mm GRP-110-1/8 0.093 2.36 GRP-110-1/4 0.125 3.18 GRP-110-1/2 0.250 6.35 GRP-110-3/4 0.500 12.70 GRP-110-1-1/4 0.750 19.05 GRP-110-1-3/4 1.250 31.75 GRP-110-2IN 1.500 38.10 Expanded Inside Diameter, Max. Inch mm 0.250 6.35 0.375 9.53 0.750 19.05 1.250 31.75 1.750 44.45 2.750 69.85 3.500 88.90 Wall Thickness Inch mm 0.025 0.64 0.025 0.64 0.025 0.64 0.025 0.64 0.025 0.64 0.025 0.64 0.025 0.64 Expanded Inside Diameter, Max. Inch mm 0.250 6.35 0.375 9.53 0.750 19.05 1.250 31.75 1.750 44.45 2.750 69.85 3.500 88.90 Wall Thickness Inch mm 0.025 0.64 0.025 0.64 0.025 0.64 0.025 0.64 0.025 0.64 0.025 0.64 0.025 0.64 Standard Put-Ups Construction Carriers 32 24 48 72 96 120 120 Yarns 1 3 3 3 3 4 4 Total 32 72 144 216 288 480 480 Ft 100, 500 100, 500 100, 500 100, 500 50, 250 50, 250 50, 250 m 30.5, 152 30.5, 152 30.5, 152 30.5, 152 15.2, 76 15.2, 76 15.2, 76 Flame-Retardant Sleeving Part No. GRP-120-1/8 GRP-120-1/4 GRP-120-1/2 GRP-120-3/4 GRP-120-1-1/4 GRP-120-1-3/4 GRP-120-2IN Inside Diameter, Min. Inch mm 0.093 2.36 0.125 3.18 0.250 6.35 0.500 12.70 0.750 19.05 1.250 31.75 1.500 38.10 Standard Put-Ups Construction Carriers 32 24 48 72 96 120 120 Yarns 1 3 3 3 3 4 4 Total 32 72 144 216 288 480 480 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Ft 100, 500 100, 500 100, 500 100, 500 50, 250 50, 250 50, 250 m 30.5, 152 30.5, 152 30.5, 152 30.5, 152 15.2, 76 15.2, 76 15.2, 76 505 FIT > FIT Wire Management > Non-Fraying, Expandable Braided Sleeving FIT® Wire Management Non-Fraying, Expandable Braided Sleeving GRP-110NF, GRP-120NF Physical Properties • Light weight, flexible routing • Frayless: cuts without a hot knife • Compatible with automatic cutting machines • -75°C to +125°C • Tensile  strength: GRP-110NF: 85,000 psi (586 N/mm2) GRP-120NF: 55,000 psi (379 N/mm2) XS-100/100FR: 100,000 psi (689 N/mm2) Color Chemical Properties Operating Temperature UL UZKX2 UL VW-1 (GRP-120NF, XS-100FR) CSA 5836 01 MIL-I-631 • G  RP-110NF, XS-100: Black or natural • GRP-120NF: Black with white tracer thread • XS-100FR: Black or white • Corrosive effect: none • Fungus resistance: no growth Availability See tables Spools may contain multiple lengths Material • Braided PET General-Purpose Sleeving Inside Diameter, Min. Part No. Inch mm GRP-110NF18 0.125 3.18 GRP-110NF14 0.156 3.96 GRP-110NF12 0.250 6.35 GRP-110NF34 0.625 15.88 GRP-110NF114 1.000 25.40 GRP-110NF112 1.250 31.75 XS-100-2-1/2 2.000 50.80 Flame-Retardant Sleeving Inside Diameter, Min. Part No. Inch mm GRP-120NF18 0.125 3.18 GRP-120NF14 0.156 3.96 GRP-120NF12 0.250 6.35 GRP-120NF34 0.625 15.88 GRP-120NF114 1.000 25.40 GRP-120NF112 1.250 31.75 XS-100FR-2-1/2 2.000 50.80 506 Expanded Inside Diameter, Max. Inch mm 0.250 6.35 0.438 11.13 0.750 19.05 1.000 25.40 1.500 38.10 2.000 50.80 3.500 88.90 Expanded Inside Diameter, Max. Inch mm 0.250 6.35 0.438 11.13 0.750 19.05 1.000 25.40 1.500 38.10 2.000 50.80 3.500 88.90 Wall Thickness Inch mm 0.024 0.61 0.024 0.61 0.024 0.61 0.024 0.61 0.024 0.61 0.024 0.61 0.025 0.64 Wall Thickness Inch mm 0.024 0.61 0.024 0.61 0.024 0.61 0.024 0.61 0.024 0.61 0.024 0.61 0.025 0.64 Standard Put-Ups Construction Carriers 32 40 64 80 120 120 144 Yarns 3 3 3 3 3 4 5 Total 96 120 192 240 360 480 720 Yarns 3 3 3 3 3 4 5 m 30.5, 152 30.5, 152 30.5, 152 30.5, 152 15.2, 76 15.2, 76 30.5 Standard Put-Ups Construction Carriers 32 40 64 80 120 120 144 Ft 100, 500 100, 500 100, 500 100, 500 50, 250 50, 250 100 Total 96 120 192 240 360 480 720 Ft 100, 500 100, 500 100, 500 100, 500 50, 250 50, 250 100 m 30.5, 152 30.5, 152 30.5, 152 30.5, 152 15.2, 76 15.2, 76 30.5 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT > FIT Wire Management > Flexible, Semirigid Wrappable Sleeving FIT® Wire Management Flexible, Semirigid Wrappable Sleeving GRP-130 and GRP-130NF The choice for a wide variety of bundling applications without the need for additional fasteners Black w/ Tracer GRP-130NF-18 GRP-130NF-14 GRP-130NF-38 GRP-130NF-12 GRP-130NF-34 GRP-130NF-1IN GRP-130NF-1-14 GRP-130NF-1-12 GRP-130NF-2IN See table Reels may contain multiple lengths Color The GRP-130 installation tool makes installing long length of GRP-130 sleeving fast and easy. Simply insert your wire bundle into the tool’s shank and slide the tool along the split in the sleeving. The tool deposits the wires and allows the split to close correctly. Materials • 10-mil PET braid • Cuts with hot knife Physical Properties • T  ensile strength: GRP-130: 6 psi (0.04 N/mm2) GRP-130NF: 4 psi (0.02 N/mm2) • Specific gravity: 1.38 max • B  ends tightly without distorting or opening • 25% edge overlap to accommodate connectors and splices • Fast, easy wrap-around installation • More flexible than spiral wrap or split convoluted tubing Black GRP-130-1/8 GRP-130-1/4 GRP-130-3/8 GRP-130-1/2 GRP-130-3/4 GRP-130-1IN GRP-130-1-1/4 GRP-130-1-1/2 GRP-130-2IN Availability • -70°C to +125°C • GRP-130: 230°C melt temperature • GRP-130NF: 250°C melt temperature • GRP-130: Black or orange • GRP-130NF: Black with white tracer UL UZKX2 UL 94V-0 (GRP-130) UL VW1 (GRP-130NF) CSA 5836 01 FT2 FAR 25 (GRP-130NR) Part No. Operating Temperature Chemical Properties • • • • • • Corrosive effects: noncorrosive Fungus resistance: no growth Water absorption: 0.10% max UV resistant Halogen free Lead free Size Inch 0.125 0.250 0.375 0.500 0.750 1.000 1.250 1.500 2.000 mm 3.18 6.35 9.53 12.70 19.05 25.40 31.75 38.10 50.80 Wall Thickness (Min) Inch mm 0.024 3.18 0.025 6.35 0.025 9.53 0.025 12.70 0.025 19.05 0.038 25.40 0.038 31.75 0.038 38.10 0.038 50.80 Ends per Carrier Alternating 1/3 1/3 1/3 1/3 1/3 1/3 1/3 1/3 2/3 Standard Put-Ups Ft 50, 200 50, 200 50, 100 50, 100 50, 100 50, 100 25 25 25 m 15.2, 71 15.2, 71 15.2, 30.5 15.2, 30.5 15.2, 30.5 15.2, 30.5 7.6 7.6 7.6 Installation Tool Part No. GRP-130T-1/4 GRP-130T-1/4 GRP-130T-1/2 GRP-130T-1/2 GRP-130T-3/4 GRP-130T-1IN GRP-130T-1-1/4 GRP-130T-1-1/4 GRP-130T-1-1/4* *Designed for up to 1.22” cable diameter Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 507 FIT > FIT Wire Management > Advanced Protection Expandable Sleeving FIT® Wire Management Advanced Protection Expandable Sleeving GRP-160 Color • Black Materials • 2  0-mil nylon polyamide monofilament An economical, easy-to-use choice for advanced abrasion and cut-through protection • E  xtreme abrasion resistance without losing flexibility or durability • Cuts cleanly with hot knife • Resists fuels, solvents, salt water, chemicals, and UV • Expandable to 150% Operating Temperature • -45°C to +150°C • 256°C melt temperature Part No. GRP-160-1/4 GRP-160-1/2 GRP-160-3/4 GRP-160-1IN GRP-160-1-1/4 GRP-160-1-3/4 GRP-160-2-1/4 508 Nominal Size Inch mm 1/4 6.35 1/2 12.70 3/4 19.05 1 25.40 1-1/4 31.75 1-3/4 44.45 2-1/4 57.15 Physical Properties • T  ensile strength: 19 psi (0.13 N/mm2) • Specific gravity: 1.14 max Chemical Properties • • • • • • Corrosive effects: noncorrosive Fungus resistance: no growth Water absorption: 2.50% max UV resistant Halogen free Lead free Availability See table Reels may contain multiple lengths Expansion Range Inch mm 0.250 – 0.500 6.35 – 12.70 0.500 – 1.000 12.70 – 25.40 0.750 – 1.250 19.05 – 31.75 1.000 – 1.500 25.40 – 38.10 1.250 – 2.000 31.75 – 50.80 1.750 – 2.750 44.45 – 69.85 2.250 – 3.000 57.15 – 76.20 Construction Carriers Yarns 20 3 36 3 40 3 48 3 56 3 72 3 96 3 Total 60 108 120 144 168 216 288 Standard Put-Ups Ft m 50, 250 15.2, 76 50, 250 15.2, 76 50, 250 15.2, 76 50, 250 15.2, 76 50, 250 15.2, 76 50, 250 15.2, 76 25, 100 7.6, 30.5 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT > FIT Wire Management > Advanced Chemical Resistance Expandable Sleeving FIT® Wire Management Advanced Chemical Resistance Expandable Sleeving GRP-170 Color • Black Materials • 8  -mil-diameter polyphenylene sulfide (PPS) monofilaments • Cuts with hot knife The extremely lightweight sleeving that is impervious to virtually all chemicals UL 94V-0 FAR 25 Operating Temperature • -70°C to +200°C • 285°C melt temperature GRP-170-1/8 GRP-170-1/4 GRP-170-1/2 GRP-170-3/4 GRP-170-1-1/4 GRP-170-1-3/4 • Specific gravity: 1.37 max • Flame resistant Chemical Properties • R  esists acids, bases, solvents, and fuels • Ultra-lightweight • High abrasion resistance • Expandable to 150% • Flame resistant • Cuts cleanly with hot knife Part No. Physical Properties Nominal Size Inch mm 1/8 3.18 1/4 6.35 1/2 12.70 3/4 19.05 1-1/4 31.75 1-3/4 44.45 • • • • • • • Corrosive effects: noncorrosive Fungus resistance: no growth Water absorption: 0.025% max Low outgassing UV resistant Halogen free Lead free Availability See table Reels may contain multiple lengths Expansion Range Inch mm 0.094 – 0.250 2.38 – 6.35 0.125 – 0.375 3.18 – 9.53 0.250 – 0.750 6.35 – 19.05 0.500 – 1.250 12.70 – 31.75 0.750 – 1.750 19.05 – 44.45 1.250 – 2.500 31.75 – 63.50 Construction Carriers Yarns 32 2 48 2 56 3 72 3 96 4 120 4 Total 64 96 168 216 384 480 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Standard Put-Ups Ft m 100, 500 30.5, 152 100, 500 30.5, 152 100, 500 30.5, 152 50, 250 15.2, 76 50, 250 15.2, 76 50, 250 15.2, 76 509 FIT > FIT Wire Management > Maximum Performance Expandable Sleeving FIT® Wire Management Maximum Performance Expandable Sleeving GRP-180 Color • Black Materials • Flat 20-mil nylon filaments • Cuts with hot knife Superior abrasion resistance, a wide operating temperature range, easy installation for industrial, solar, and high-abrasion applications Physical Properties • T  ensile strength: 19 psi (0.13 N/mm2) • Specific gravity: 1.12 max Chemical Properties • Superior abrasion resistance • Easy to install • Resists fuels, solvents, chemicals, salt water, and UV • Smooth inner wall to prevent internal abrasion damage • • • • • Operating Temperature See table Reels may contain multiple lengths • -60°C to +150°C • 265°C melt temperature Part No. GRP-180-1/2 GRP-180-3/4 GRP-180-1IN GRP-180-1-1/4 GRP-180-1-3/4 GRP-180-2IN 510 Nominal Size Inch mm 1/2 12.70 3/4 19.05 1 25.40 1-1/4 31.75 1-3/4 44.45 2 50.80 Corrosive effects: noncorrosive Fungus resistance: no growth Water absorption: 2.50% max UV resistant Lead free Availability Expansion Range Inch mm 0.375 – 0.625 9.53 – 15.88 0.625 – 1.000 15.88 – 25.40 0.875 – 1.250 22.22 – 31.75 1.000 – 1.500 25.40 – 38.10 1.500 – 2.000 38.10 – 50.80 1.750 – 2.750 44.45 – 69.85 Construction Carriers Yarns 24 1 36 1 44 1 48 1 80 1 96 1 Total 24 36 44 48 80 96 Standard Put-Ups Ft m 50, 250 15.2, 76 50, 250 15.2, 76 50, 250 15.2, 76 25, 100 7.6, 30.5 25, 100 7.6, 30.5 25, 100 7.6, 30.5 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT > FIT Wire Management > Extreme Performance Sleeving FIT® Wire Management Extreme Performance Sleeving GRP-200 Color • Natural Materials • 16-mil PTFE filaments • Cuts with hot knife or hot wire The high-temperature choice for aerospace, military, and high-tech applications where thermal stability and low outgassing are critical FAR 25 • Cut and abrasion resistant • Flame resistant • Resists virtually all chemicals and UV • Thermally stable • Low outgassing • Suitable for plenum use Physical Properties • Specific gravity: 2.15 max Chemical Properties • • • • • Corrosive effects: noncorrosive Fungus resistance: no growth Water absorption: 0.01% max Vacuum outgassing: 95.0% max Lead free Availability See table Spools may contain multiple lengths Operating Temperature • -70°C to +280°C • 310°C melt temperature Part No. GRP-200-1/8 GRP-200-1/4 GRP-200-3/8 GRP-200-1/2 GRP-200-3/4 GRP-200-1-1/4 GRP-200-1-3/4 GRP-200-2IN Nominal Size Inch mm 1/8 3.18 1/4 6.35 3/8 9.53 1/2 12.70 3/4 19.05 1-1/4 31.75 1-3/4 44.45 2 50.80 Expansion Range Inch mm 0.094 – 0.250 2.38 – 6.35 0.188 – 0.375 4.76 – 9.53 0.250 – 0.750 6.35 - 19.06 0.375 - 0.875 9.53 – 22.23 0.625 – 1.250 15.88 – 31.75 1.125 – 1.500 28.58 – 38.10 1.375 – 1.750 34.93 – 44.45 1.688 – 2.125 42.88 – 53.98 Carriers 24 32 40 48 64 72 80 96 Construction Yarns 1 1 3 3 3 3 4 3 Total 25 32 120 144 192 216 240 288 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Standard Put-Ups Ft m 50, 250 15.2, 76 50, 250 15.2, 76 50, 250 15.2, 76 50, 250 15.2, 76 50, 250 15.2, 76 25, 100 7.6, 30.5 25, 100 7.6, 30.5 25, 100 7.6, 30.5 511 FIT > FIT Wire Management > Expandable Braided Sleeving FIT® Wire Management Expandable Braided Sleeving XS-100HD Chemical Properties • Extremely flexible • Light weight • Easy to install Operating Temperature • -70°C to +125°C • 250°C melt temperature UL 224 UL UZKX2 CSA 5836 01 • • • • Corrosive effect: none Fungus resistance: no growth Halogen free Lead free Availability See table Color Spools may contain multiple lengths • Black Material • Heavy-duty braided PET Physical Properties • T  ensile strength: 90,000 psi (620 N/mm2) • Elongation: 25% min. • Specific gravity: 1.31 max. Part No. XHD3/8 XHD5/8 XHD1IN XHD1-1/2 XHD2IN 512 Inside Diameter, Min. Inch mm 0.188 4.78 0.313 7.95 0.500 12.70 1.000 25.40 1.500 38.10 Expanded Inside Diameter, Max. Inch mm 0.750 19.05 1.000 25.40 1.500 38.10 2.000 50.80 3.000 76.20 Wall Thickness Inch mm 0.042 1.07 0.042 1.07 0.042 1.07 0.042 1.07 0.042 1.07 Construction Carriers 24 32 48 72 93 Yarns 3 3 3 3 3 Total 72 96 144 216 288 Standard Put-Ups Ft m 500 152 500 152 250 76 200 61 100 30.5 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT > FIT Wire Management > Braided Sleeving FIT® Wire Management Braided Sleeving XS-200N Operating Temperature Chemical Properties • -45°C to +120°C • 250°C melt temperature • Black • • • • • Material Electrical Properties • Braided nylon • D  ielectric strength: 4 V/mil (1.57 kV/cm) Color MIL-S-47053 CID A-A-59301 • Extremely durable • Abrasion resistant • Tight weave with excellent flexibility Part No. XS-200N-1/8 XS-200N-1/4 XS-200N-3/8 XS-200N-1/2 XS-200N-3/4 XS-200N-1IN Inside Diameter, Min. Inch mm 0.125 3.18 0.250 6.35 0.375 9.53 0.500 12.70 0.750 19.05 1.000 25.40 Physical Properties • T  ensile strength: 80,000 psi (551 N/mm2) • Specific gravity: 1.14 Wall Thickness Inch 0.020 0.032 0.032 0.035 0.035 0.045 mm 0.51 0.81 0.81 0.89 0.89 1.14 Corrosive effect: none Fungus resistance: no growth Water absorption: 0.04%, max. Halogen free Lead free Availability See table Spools may contain multiple lengths Standard Put-Ups Construction Carriers 28 48 52 72 72 72 Yarns 3 4 5 6 9 16 Total 84 192 260 432 648 1152 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Ft 100, 1000 100, 500 100, 500 100 100, 250 100 m 30.5, 305 30.5, 152 30.5, 152 30.5 30.5, 76 30.5 513 FIT > FIT Wire Management > Abrasion-Resistant Nylon Sleeving FIT® Wire Management Abrasion-Resistant Nylon Sleeving XS300 Color • Black Materials • 4  5-mil-thick nylon • Cuts with scissors Professional-grade protection with smooth inner wall to prevent internal abrasion damage • • • • Excellent abrasion resistance Tightly woven, nonexpandable Cuts cleaning with scissors Deflects high-pressure hose ruptures • Resists fuels, chemicals, UV, rot, and vermin • ISO 6945 certified • MSHA approved “Accepted flame-resistant solid products taken into mines” Physical Properties • Specific gravity: 1.14 Chemical Properties • • • • • Corrosive effects: noncorrosive Fungus resistance: no growth Water absorption: 2.70% max Halogen free Lead free Availability 25 ft (7.6 m) 100 ft (304 m) for 0.71 through 1.59 sizes only Operating Temperature • -45°C to +120°C • 210°C melt temperature Part No. XS300071 XS300083 XS300092 XS300100 XS300113 XS300125 XS300134 XS300159 XS300175 XS300207 XS300238 XS300254 XS300286 XS300334 XS300366 514 Size Inch 0.71 0.83 0.92 1.00 1.13 1.25 1.34 1.59 1.75 2.07 2.38 2.54 2.86 3.34 3.66 mm 18.03 21.08 23.37 25.40 28.70 31.75 34.04 40.39 44.45 52.58 60.45 64.52 72.64 84.84 92.96 Wall Thickness (Min) Inch Mm 0.045 1.14 0.045 1.14 0.045 1.14 0.045 1.14 0.045 1.14 0.045 1.14 0.045 1.14 0.045 1.14 0.045 1.14 0.045 1.14 0.045 1.14 0.045 1.14 0.045 1.14 0.045 1.14 0.045 1.14 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT > FIT Wire Management > Expandable Braided Sleeving FIT® Wire Management Expandable Braided Sleeving ZIP-GRP Operating Temperature Chemical Properties • -70°C to +125°C • 230°C melt temperature • • • • • • • Color • Black Material UL UZKYZ UL 94V-0 CSA 5836 01 • B  raided PET with hook and loop closure • Cuts with hot knife • Unlimited breakouts • Abrasion and cut-through resistance • Oil and solvent resistance Part No. ZIP-GRP-7/8 ZIP-GRP-1-1/2 ZIP-GRP-2 Inside Diameter, Min. Inch mm 0.500 12.70 1.500 38.10 2.000 50.80 Availability 25 ft (7.6 m) 50 ft (15.2 m) Physical Properties Spools may contain multiple lengths • T  ensile strength: 85,000 psi (586 N/mm2) • Specific gravity: 1.38 Expanded Inside Diameter, Max. Inch mm 2.375 60.33 3.500 88.90 4.500 114.30 Corrosive effect: None Fungus resistance: no growth Water absorption: 0.15% max. Halogen free Lead free Chemically inert UV resistant Wall Thickness Inch 0.025 0.025 0.025 mm 0.64 0.64 0.64 Construction Carriers 88 105 137 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Yarns 4 4 4 Total 220 420 548 515 FIT > FIT Wire Management > Lacing Tape FIT® Wire Management Lacing Tape D: Glass/TFE: The glass/TFE combination has excellent tensile strength and abrasion resistance. Also resists fungus, acids and flames. Finishes A. Natural, No finish A-A-52080 Type 1 • • • •  igh tensile strength H Good chemical resistance Excellent abrasion resistance Excellent knot retention See table for specifications. B. Wax: A microcrystalline wax with a melting point above 54°C compounded with a fungicide that does not contain either copper or mercuric materials. Excellent knot retention, yet the finish does not have too great a “waxy” feel to the user. Microcrystalline wax is soft, pliable, and easy to tie. Operating temperature: • -55° C to +121°C Elongation: • 40% max Finish weight (impregnated % of material by weight) • Finish A (natural) • Finish B (wax): 15% – 32% • Finish C (synthetic rubber/ elastomer): 7% – 17% • Finish E (synthetic resin/vinyl): 15% – 30% 516 A thermoplastic synthetic resin with a melting point above 177°C for use where a “wax free” type is specified. It is a non-dusting or flaking, dry finish with good knot tying qualities. C. Synthetic Rubber or Elastomer: A special continuous coating of fungistatic synthetic rubber containing no corrosive compounding ingredients. Knots tied with this finish will not slip. This finish will not flake or dust. A-A-52080 (MIL-T-43435B Type I) • F  lat braid made from hightenacity continuous nylon yarn E. Synthetic Resin or Vinyl: Part No. Finish Color 801530W 801536B 801536W 802534B 802534W A B B B B LC-134 B 805032B 805032W 805036B 805036W 805040B 805040W E E B B C C LC-143 E 808036B 808036W B B Natural Black Natural Black Natural Black, White Black Natural Black Natural Black Natural Black, White Black White Width, Nom Inch mm 0.050 1.27 0.050 1.27 0.050 1.27 0.060 1.52 0.060 1.52 Thickness, Nom. Inch mm 0.010 0.25 0.010 0.25 0.010 0.25 0.012 0.30 0.012 0.30 0.060 1.52 0.012 0.30 25 11.3 500 457 0.085 0.085 0.085 0.085 0.085 0.085 2.16 2.16 2.16 2.16 2.16 2.16 0.014 0.014 0.014 0.014 0.014 0.014 0.36 0.36 0.36 0.36 0.36 0.36 50 50 50 50 50 50 22.7 22.7 22.7 22.7 22.7 22.7 500 500 500 500 500 500 457 457 457 457 457 457 0.085 2.16 0.014 0.36 50 22.7 500 457 0.110 0.110 2.79 0.015 2.79 0.015 80 80 36.3 36.3 250 250 228 228 0.38 0.38 Break Strength, Min. Availability* lb kg Yd m 15 6.8 500 457 15 6.8 500 457 15 6.8 500 457 25 11.3 500 457 25 11.3 500 457 *Bobbins/tubes may contain multiple lengths. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT > FIT Wire Management > Lacing Tape FIT® Wire Management Lacing Tape A-A-52081 (formerly MIL-T-43435B Type II) • F  lat braid made from high-tenacity continuous polyester yarn Operating temperature: • -73°C to +177°C Elongation: • 40% max Finish weight (impregnated % of material by weight) • Finish A (natural) • Finish B (wax): 15% – 32% • Finish C (synthetic rubber/ elastomer): 7% – 17% • Finish E (synthetic resin/vinyl): 15% – 30% A-A-52083 (formerly MIL-T43435B Type IV) • F  lat braid made from continuous filament glass yarn coated with PTFE before braiding Part No. Finish Color 801566B 802566B C C C164 B 805058B 805058W 805060B 805062B 805062W 805066W E E A B B C C162 B 808060W 808058B A E C160 B Black Black Black, White Black Natural Black Black Natural Natural Black, White Natural Black Black, White Width, Nom. Inch mm 0.050 1.27 0.060 1.52 Thickness, Nom. Inch mm 0.010 0.25 0.012 0.30 0.062 1.57 0.010 0.25 25 11.3 500 457 0.085 0.085 0.085 0.085 0.085 0.085 2.16 2.16 2.16 2.16 2.16 2.16 0.014 0.014 0.014 0.014 0.014 0.014 0.36 0.36 0.36 0.36 0.36 0.36 50 50 50 50 50 50 22.7 22.7 22.7 22.7 22.7 22.7 500 500 500 500 500 500 457 457 457 457 457 457 0.085 2.16 0.014 0.36 50 22.7 500 457 0.110 0.110 2.79 2.79 0.015 0.38 0.015 0.38 80 80 36.3 36.3 500 250 457 228 135 61.2 250 228 0.200 5.08 0.016 Break Strength, Min. Availability* lb kg Yd m 15 6.8 500 457 25 11.3 500 457 0.41 *Bobbins/tubes may contain multiple lengths. Part No. Finish Color 807510W 810010W D D Natural Natural Width, Nom. Inch mm 0.085 2.16 0.110 2.79 Thickness, Nom. Inch mm 0.016 0.41 0.016 0.41 Break Strength, Min. lb kg 75 34.0 100 45.3 Availability* Yd 500 250 m 457 228 *Bobbins/tubes may contain multiple lengths. Operating temperature: • G  lass maintain strength and stability to 427°C Elongation: • 5% max Finish weight (impregnated % of material by weight) • Finish D (glass/TFE): 10% – 20% Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 517 FIT > FIT Wire Management > Lacing Tape FIT® Wire Management Lacing Tape A-A-52084 (formerly MIL-T43435B Type V) • Flat braid made from continuous filament aramid yarn Operating temperature: Part No. Finish 803554 C Width, Nom. Inch mm Natural 0.075 1.91 Color Thickness, Nom. Inch mm 0.012 0.30 Break Strength, Min. lb kg 35 15.9 Availability* Yd 500 m 457 *Bobbins/tubes may contain multiple lengths. • -55°C to +260°C Elongation: • 40% max Finish weight (impregnated % of material by weight) • Finish C (synthetic rubber/ elastomer): 7% – 17% MIL-DTL-713 Type P • Twisted nylon cord made from high-tenacity continuous filament yarn Operating temperature: • -55° C to +121°C Elongation: • 20% min. Finish weight (impregnated % of material by weight) • Finish B (wax): 20% – 32% Telecommunications-Grade Polyester Yarn • Round, twisted polyester cord made from high-tenacity industrial polyester fiber Melt temperature (approx.): Part No. Finish Color 803215B 803215W 804812W 804814B 804814W 807013B 807013W B B A B B B B Black Natural Natural Black Natural Black Natural Diameter, Nom. Inch mm 0.023 0.58 0.023 0.58 0.025 0.64 0.025 0.64 0.025 0.64 0.040 1.02 0.040 1.02 Break Strength, Min. lb kg 32 14.5 32 14.5 48 21.8 48 21.8 48 21.8 70 31.7 70 31.7 Availability* lb 1 1 1 1 1 1 1 kg 0.45 0.45 0.45 0.45 0.45 0.45 0.45 *Weight per spool; bobbins/tubes may contain multiple lengths. Part No. Finish Color 812030W 815040W Wax Wax Natural Natural Diameter, Nom. Inch mm 0.030 0.76 0.030 0.76 Break Strength, Min. lb kg 32 14.5 32 14.5 Plies 9 12 Availability* lb 0.5 0.5 kg 0.22 0.22 *Weight per tube; bobbins/tubes may contain multiple lengths. • 121°C Elongation: • 17% – 27% Finish weight (impregnated % of material by weight) • 9 ply: 7% – 17% • 12 ply: 35% 518 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT > FIT Wire Management > Tinned Copper Braid FIT® Wire Management Tinned Copper Braid Flat, Oval AA-59569A (as indicated) Availability See table Color Spools may contain multiple lengths • Silver Material • Tinned copper braid Part No. Flat Width, Nom. Thickness, Nom. Braid Construction AWG of Individ. Ends Carriers No. of Individ. Ends AWG Equivalent, Approx. CMA, Nom. Inch mm Inch mm 1221* 0.025 0.64 0.015 0.38 36 8 8 27 1222* 0.032 0.81 0.020 0.50 36 16 16 1223 0.047 1.19 0.020 0.50 36 24 1224* 0.094 2.39 0.020 0.50 36 1229 0.125 3.18 0.020 0.50 1230 0.187 4.75 0.020 1231 0.250 6.35 1232* 0.385 1233/2* 0.500 CurrentCarrying Capacity Standard Put-Ups Amps Ft m 200 4 24 400 6 24 22 600 7 16 48 19 1200 11 36 24 72 18 1800 16 0.50 36 24 120 15 3000 25 0.030 0.76 36 24 168 14 4200 32 9.78 0.030 0.76 36 48 288 12 7200 46 12.70 0.030 0.76 36 48 384 10 9600 53 100, 500, 1000 100, 500, 1000 100, 500, 1000 100, 500, 1000 100, 500, 1000 100, 500, 1000 100, 500, 1000 100, 500, 1000 100, 500, 1000 100, 500, 1000 100, 500, 1000 100, 500, 1000 100, 500, 1000 100 100 100 100 30.5, 152, 305 30.5, 152, 305 30.5, 152, 305 30.5, 152, 305 30.5, 152, 305 30.5, 152, 305 30.5, 152, 305 30.5, 152, 305 30.5, 152, 305 30.5, 152, 305 30.5, 152, 305 30.5, 152, 305 30.5, 152, 305 30.5 30.5 30.5 30.5 1233 0.625 15.88 0.030 0.76 36 48 384 10 9600 53 1234 0.750 19.05 0.040 1.02 36 48 864 7 20,800 85 1235* 1.000 25.40 0.045 1.14 36 48 864 7 20,800 85 1239 1.375 34.93 0.050 1.27 30 48 336 5 33,700 100 1240 1.500 38.10 0.060 1241* 1.750 44.45 0.080 1242* 2.000 50.80 0.120 1242/4* 3.000 76.20 0.200 1.52 2.03 3.05 5.08 30 30 30 30 48 48 48 48 528 1248 1436 2256 3 2/0 3/0 4/0 53,064 125,424 154,368 225,000 150 280 310 390 *Not A-A-59569A. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 519 FIT > FIT Wire Management > Tinned Copper Braid FIT® Wire Wire Management Tinned Copper Braid Flat, Oval A-A-59551 (as indicated) Availability See table Color Spools may contain multiple lengths • Silver Material • Tinned copper braid Part No. Inside Diameter, Nom. Braid Construction Carriers 1.59 AWG of Individ. Ends 34 16 No. of Individ. Ends 32 11/64 4.37 34 24 120 3/16 1/4 3/8 1/2 5/8 11/16 25/32 4.76 6.35 9.53 12.70 15.88 17.46 19.84 34 34 34 34 34 34 34 24 24 24 48 48 48 48 144 168 192 336 384 480 528 Inch mm 2132 1/16 2138 2140* 2142* 2144* 2146 2148* 2150* 2152 AWG Equivalent, Approx. CMA, Nom. 19 CurrentCarrying Capacity Standard Put-Ups Amps Ft m 1192 11 14 4770 32 13 12 11 9 8 7 7 5724 6678 7632 13,356 14,264 19,080 20,988 38 41 46 62 64 81 85 100, 500, 1000 100, 500, 1000 100, 500 100, 500 100, 500, 100 100 100 100 30.5, 152, 305 30.5, 152, 305 30.5, 152 30.5, 152 30.5, 152 30.5 30.5 30.5 30.5 *Not A-A-59551. Bare Copper Braid Flat Material • Bare copper braid Availability See table Spools may contain multiple lengths Part No. 95106 95079 520 Dimensions, Nom. Braid Construction Inch mm AWG of Individ. Ends Carriers No. of Individ. Ends 0.062 x 0.016 0.250 x 0.030 1.57 x 0.41 20 16 96 6.35 x 0.76 14 27 168 CMA, Nom. CurrentCarrying Capacity Standard Put-Ups Amps Ft m 949 10.2 4200 27.9 100, 500, 1000 100, 500, 1000 30.5, 152, 305 30.5, 152, 305 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT > FIT Wire Management > Tinned Copper Braid FIT® Wire Wire Management Tinned Copper Braid Tubular A-A-59569 Availability See tables Color Spools may contain multiple lengths • Silver Material • Tinned copper braid Tinned Copper Part No. 2160 2162 2163 2164 2166 2167 2168 2170 2171 2171/1 2172 2173 2174 2175 2175/1 2176 Inside Diameter, Nom. Inch mm 0.031 0.062 0.078 0.109 0.125 0.156 0.171 0.203 0.250 0.281 0.375 0.437 0.500 0.462 0.656 0.781 0.79 1.57 1.98 2.77 3.18 3.96 4.34 5.16 6.35 7.14 9.53 11.10 12.70 11.73 16.66 19.84 Braid Construction AWG of Indiv. Ends 36 36 36 36 36 36 36 34 36 30 36 30 36 30 30 36 Carriers 24 24 24 24 24 24 24 24 24 24 48 24 48 48 48 48 No. of Indiv. Ends 24 48 72 96 120 240 168 192 384 120 384 240 528 480 768 864 AWG Equivalent, Approx. CMA, Nom. 22 19 18 16 15 12 14 11 10 9 10 6 9 3 1 7 600 1200 1800 2400 3000 6000 4200 7630 9600 12,060 9600 24,120 13,200 48,240 77,180 21,600 AWG Equivalent, Approx. CMA, Nom. 5 4 4 3 3 2 33,700 38,600 43,330 48,150 53,000 57,775 CurrentCarrying Capacity Standard Put-Ups Amps Ft m 7 11 16 19 25 40 32 46 53 60 53 90 62 145 190 88 100, 250 100, 250 100, 250 100, 250 100, 250 100, 250 100, 250 100 100 100 100 100 100 100 100 100 30.6, 76 30.6, 76 30.6, 76 30.6, 76 30.6, 76 30.6, 76 30.6, 76 30.5 30.5 30.5 30.5 30.5 30.5 30.5 30.5 30.5 Extra-Large Tinned Copper Part No. 2177 2178 2179 2180* 2181 2182 Inside Diameter, Nom. Inch mm 0.875 1.000 1.125 1.250 1.375 1.500 22.23 25.40 28.58 31.75 34.93 38.10 Braid Construction AWG of Indiv. Ends 30 30 30 30 30 30 Carriers 48 48 48 48 48 48 No. of Indiv. Ends 336 384 432 480 528 576 CurrentCarrying Capacity Standard Put-Ups Amps Ft m 100 120 130 145 150 165 100 100 100 100 100 100 30.5 30.5 30.5 30.5 30.5 30.5 *Not A-A-59569. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 521 FIT > FIT Wire Management > Silver-Plated Copper Braid FIT® Wire Wire Management Silver-Plated Copper Braid Tubular A-A-59569 Availability See table Color Spools may contain multiple lengths • Silver Material • Silver-plated copper braid Silver-Plated Part No. 2191 2193 2194 2195 2196 2197 2198 522 Inside Diameter, Nom. Inch mm 1/16 7/64 1/8 5/32 11/64 13/64 1/4 1.59 2.78 3.18 3.97 4.37 5.16 6.35 Braid Construction AWG of Indiv. Ends 36 36 36 36 36 34 36 Carriers 24 24 24 24 24 24 24 No. of Indiv. Ends 48 96 120 240 168 192 384 AWG Equivalent, Approx. CMA, Nom. 19 16 15 12 14 11 10 1200 2400 3000 6000 4200 7640 9600 CurrentCarrying Capacity Standard Put-Ups Amps Ft m 11 19 25 40 32 46 53 100 100 100 100 100 100 100 30.5 30.5 30.5 30.5 30.5 30.5 30.5 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com.
TY2001GR270 价格&库存
很抱歉,暂时无法提供与“TY2001GR270”相匹配的价格&库存,您可以联系我们找货
