47100
47100
    DESCO
    TAPE PACK ESD PROTECTED AREA YEL
47100 数据手册
FEATURES • Identifies packages that should be opened only in ESD protected areas • For use in shipping of ESD sensitive items • Includes ESD Susceptibility symbol • Heavy-duty, reinforced shipping tape • Packaged 10 rolls per case • Made in America SPECIFICATIONS: ITEM DESCRIPTION 47100 CARTON SEALING TAPE, 10/CASE Use sealing tape with the ESD susceptibility symbol to identify packages that should be opened only in ESD protected areas. “The ESD susceptibility symbol incorporates a reaching hand in a triangle with a slash through it and is used to indicate that an electrical or electronic device or assembly is susceptible to damage from an ESD event.” (ANSI-ESD S8.1 Symbols) • 3" x 450' Non-Asphaltic Re-Enforced Tape • Core Size: No Core • Paper: 25# Top Sheet and 25# Bottom Sheet • Temp. Range: 32°F to 100°F • Package Quantity: 10 Rolls • Thickness: 5.8 mil • Adhesive: Water-activated modified starch • Tensile Strength: Machine Direction @ 55lbs and Cross Direction @ 25lbs • Recommmended for Carton Weight: up to 45 lbs Made in America CARTON SEALING TAPE PROTEKTIVE PAK 13520 MONTE VISTA AVENUE,CHINO, CA 91710 PHONE (909) 627-2578, FAX (909) 363-7331 www.protektivepak.com © 2005 DESCO INDUSTRIES INC. Employee Owned DRAWING NUMBER 47100 DATE: 11/05
47100 价格&库存
很抱歉,暂时无法提供与“47100”相匹配的价格&库存,您可以联系我们找货
