81201
81201
    DESCO
    TAPE CLEAR ANTISTATIC 36YDS 3/4"
81201 数据手册
Antistatic Cellulose Tape For general purpose applications • 2.4 mil (0.06 mm) total thickness • Cellulose film construction 109 - 1010 ohms • Rubber based adhesive absorbs moisture • Adhesive surface resistivity 109 - 1010 ohms • Temperature Range 10°C - 50°C (50°F - 122°F); meets MIL-B-81705 of 100°C for 10 min max • Available in clear Antistatic Tape Imprint on Clear Cellulose with Symbols Also availabe in clear with ESD sysmbols. Marking is approved symbols of Mil STD-1285*, JEDEC and ESD Association. Symbols printed in between film and adhesive; will not rub off. *Military organizations sometimes use MIL-STD-1285 for hardware marking and that document once required the use of the "three arrows in a circle" symbol. That symbol has been changed for consistency with industry marking to the "hand in triangle" ESD Susceptibility symbol. (Ref: TR20.20 section 5.3.14.1) Tape Tape is wound on a paper core. Antistatic Clear Cellulose Antistatic Clear Cellulose with Symbols 0.5" .75" Width 1" Core Length 81200 81201 81202 81203 81204 81205 81206 2" 1" 3" 36 yds 72 yds 81209 81210 81211 81212 3" 72 yds Width tolerance ±1/32" Tape widths are nominal metric ±0.8 mm (±1/32"). 1/4" 1/2" 3/4" 1" 2" is is is is is 6 mm 12 mm 18 mm 24 mm 48 mm nominal nominal nominal nominal nominal or or or or or 0.236" 0.472" 0.709" 0.945" 1.890" *Wescorp is a Desco Industries brand. The user must determine the suitability for use of an antistatic tape for his particular application. Made in America No silicone based material (adhesive, film backing, release material) is used in the manufacture of our cellulose tape. Note: For best results, tape inventory should be continually replenished. It is recommended that rolls of tape be stored flat and rotated (flipped over to the other side) periodically. Tapes should be stored in a dry, well ventilated room with a reasonably consistent temperature of 68°F (20°C) and be protected from exposure to direct sunlight. Tape should not be stored in ultraviolet sunlight, moisture, or heat. Tape over one year old should be evaluated by the user to determine acceptability for the user's application. Cartons are marked with date code information such as "2 38 05 - 4 125 03 M". In this example, the number after the hyphen "4" signifies the year 2004 and the following 3 digit number "125" signifies the Tape was manufactured of the 125th day of the year. WESCORP* ANTISTATIC CELLULOSE TAPE DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: www.desco.com PHONE (909) 627-8178 FAX (909) 627-7449 DESCO EAST: 90 HUDSON RD, CANTON, MA 02021-1407 PHONE (781) 821-8370 FAX (781) 575-0172 © 2005 DESCO INDUSTRIES INC. Employee Owned DRAWING NUMBER 81200 DATE: 03/05
81201 价格&库存
很抱歉,暂时无法提供与“81201”相匹配的价格&库存,您可以联系我们找货
