234323
234323
    LOCTITE(乐泰)
    LOCTITE NC RTV SIL CL 80ML
234323 数据手册
Technical Data Sheet LOCTITE® Superflex® Non-Corrosive RTV Silicone November-2004 PRODUCT DESCRIPTION LOCTITE® Superflex® Non-Corrosive RTV Silicone provides the following product characteristics: Technology Silicone Chemical Type Oxime silicone Appearance (uncured) Clear paste Components One component - requires no mixing Cure Room temperature vulcanizing (RTV) Application Sealing and Bonding Flexibility Enhances load bearing & shock absorbing characteristics of the bond area. Specific Benefit Non-corrosive Specific Application Sealing and bonding of electrical/electronic components LOCTITE® Superflex® Non-Corrosive RTV Silicone offers resistance to water, steam, chemicals, and UV ozone exposure. Also adheres to a wide range of substrates (glass, rubber, wood, ceramics, and painted surfaces). TYPICAL PROPERTIES OF UNCURED MATERIAL Specific Gravity @ 25 °C Flash Point - See MSDS 1.04 TYPICAL CURING PERFORMANCE Surface Cure Tack Free Time is the time required to achieve a tack free surface. Tack Free Time, minutes: Cured @ 25 °C / 50±5% RH Skin Over Time, minutes: Cured @ 25 °C / 50±5% RH ≤30LMS 15 to 20 TYPICAL PROPERTIES OF CURED MATERIAL Cured for 7 days @ 25 °C / 50±5% RH Physical Properties: Shore Hardness, ASTM D 2240, Durometer A Elongation, ASTM D 412, % Tensile Strength, ASTM D 412 N/mm² (psi) ≥20LMS ≥300LMS ≥1.2LMS (≥174) Electrical Properties: Dielectric Breakdown Strength, ASTM D 149, kV/mm 16 GENERAL INFORMATION This product is not recommended for use in pure oxygen and/or oxygen rich systems and should not be selected as a sealant for chlorine or other strong oxidizing materials. For safe handling information on this product, consult the Material Safety Data Sheet (MSDS). Directions for use 1. For best performance bond surfaces should be clean and free from grease. 2. Moisture curing begins immediately after the product is exposed to the atmosphere, therefore parts to be assembled should be mated within a few minutes after the product is dispensed. 3. The bond should be allowed to cure (e.g. seven days), before subjecting to heavy service loads. 4. Excess material can be easily wiped away with non-polar solvents. 5. Excess cured material can be removed with a knife or single edge razor blade.. Loctite Material SpecificationLMS LMS dated May-1, 2001. Test reports for each batch are available for the indicated properties. LMS test reports include selected QC test parameters considered appropriate to specifications for customer use. Additionally, comprehensive controls are in place to assure product quality and consistency. Special customer specification requirements may be coordinated through Henkel Quality. Storage Store product in the unopened container in a dry location. Storage information may be indicated on the product container labeling. Optimal Storage: 8 °C to 21 °C. Storage below 8 °C or greater than 28 °C can adversely affect product properties. Material removed from containers may be contaminated during use. Do not return product to the original container. Henkel Corporation cannot assume responsibility for product which has been contaminated or stored under conditions other than those previously indicated. If additional information is required, please contact your local Technical Service Center or Customer Service Representative. Conversions (°C x 1.8) + 32 = °F kV/mm x 25.4 = V/mil mm / 25.4 = inches N x 0.225 = lb N/mm x 5.71 = lb/in N/mm² x 145 = psi MPa x 145 = psi N·m x 8.851 = lb·in N·mm x 0.142 = oz·in mPa·s = cP TDS LOCTITE® Superflex® Non-Corrosive RTV Silicone, November-2004 Note The data contained herein are furnished for information only and are believed to be reliable. We cannot assume responsibility for the results obtained by others over whose methods we have no control. It is the user's responsibility to determine suitability for the user's purpose of any production methods mentioned herein and to adopt such precautions as may be advisable for the protection of property and of persons against any hazards that may be involved in the handling and use thereof. In light of the foregoing, Henkel Corporation specifically disclaims all warranties expressed or implied, including warranties of merchantability or fitness for a particular purpose, arising from sale or use of Henkel Corporation’s products. Henkel Corporation specifically disclaims any liability for consequential or incidental damages of any kind, including lost profits. The discussion herein of various processes or compositions is not to be interpreted as representation that they are free from domination of patents owned by others or as a license under any Henkel Corporation patents that may cover such processes or compositions. We recommend that each prospective user test his proposed application before repetitive use, using this data as a guide. This product may be covered by one or more United States or foreign patents or patent applications. Trademark usage Except as otherwise noted, all trademarks in this document are trademarks of Henkel Corporation in the U.S. and elsewhere. ® denotes a trademark registered in the U.S. Patent and Trademark Office. Reference 1 Henkel Loctite Americas +860.571.5100 Henkel Loctite Europe +49.89.9268.0 Henkel Loctite Asia Pacific +81.45.758.1810 For the most direct access to local sales and technical support visit: www.loctite.com
234323 价格&库存
很抱歉,暂时无法提供与“234323”相匹配的价格&库存,您可以联系我们找货
