RTV108-85ML
RTV108-85ML
    MGCHEMICALS
    ADHESIVE SEALANT SIL TRANSLUCENT
RTV108-85ML 数据手册
RTV Silicones >> One Part RTV Silicone Adhesive Sealant >> Clear, High Performance Assembly RTV Silicones by 1-Part Adhesive Sealant RTV108 RTV Number... Jump to Product Number Product Number... Accessories Adhesives Brushes 1-800-255-8886 Primary Characteristics Clear Paste High Strength High performance assembly Acetoxy cure Meets MIL-A-46106 UL File no. E-36952 FDA 21 CFR 177.2600 Cleaners / Degreasers Contact Cleaners Desoldering Braid Dusters & Circuit Coolers Excellent for insulating, sealing, bonding and formed-in-place gaskets. Can be applied to vertical and overhead surfaces. Not for use in delicate electrical and electronic applications in which corrosion of copper, brass, or other sensitive metals is undesirable. Can be used in food contact applications where FDA regulations apply. Reference CDS4319 "Food Contact Applications", "Silicone Rubber Compounds." EMI / RFI Shielding Epoxies Technical Support for RTV Silicones M.G. Chemicals Disclaimer for RTV Silicones > Locate Distributor > Quick Links MSDS Specifications Available Sizes Related products: Available Sizes RTV102 White Flux and Flux Remover Glass & Screen Cleaners Catalog No. Size Description Isopropyl Alcohol RTV108-85ML 2.8 oz Tube Lead Free Solder RTV108-300ML 10.1 oz Cartridge RTV103 Black RTV109 Aluminum Lubricants Potting & Encapsulating Selection Guide Specifications One Part Chart Protective Coatings Pens Prototyping Materials RTV Silicones Soldering/desoldering Two Part Chart Use Adhesive Sealant Special Feature High tensile strength Standards FDA 21CFR 177.2600 MIL-A-46106 Specialized Cleaners Swabs Thermal Management General Purpose UL Recognized Aerospace UL File No. E-36952 Marine Thermally Conductive Adhesives UL 94 HB High Performance Assembly NSN 8030-01-014-5369 Electronics Wipes Cross Reference RTV 102, DC 732 Uncured Properties High Temperature Consistency Paste Color Translucent Specific Gravity 1.05 Tack Free Time 20 min Cure Through Time ( 77°F / 50% relative humidity / 1/8" thick) 7 days Cure Time (@ 77°F /50% relative humidity) 3 days Useful Temp. Range -60°C to 205°C (-75°F to 400°F) Hardness 30 (Shore A) Tensile Strength 2.8 kg/cm2 (400 psi) Elongation 450% Tear Strength 8 kg/cm 45 lb/in http://www.mgchemicals.com/products/108.html (1 of 2)11/24/2008 7:54:11 AM Low Temperature Google Search MG Cured Properties - MECHANICAL Peel Strength Thermal Conductivity 7 kg/cm RTV Silicones >> One Part RTV Silicone Adhesive Sealant >> Clear, High Performance Assembly 40 lb/in Cured Properties - ELECTRICAL Volume Resistivity 3 x 1015 ohm · cm Dielectric Strength 20 kV/mm 500 V/mil Dielectric Constant 2.8 @ 60 Hz Cured Properties - THERMAL Thermal Conductivity 0.5 x 10-4 cal/sec/cm2 Brittle Point -60°C (-75°F) Thermal Expansion 7 x 10-5 (°C)-1 Other Viscosity (@ 25°C) 400 g/min Return to top ^ © 2000 - 2007 MG Chemicals. All rights reserved. Site Map Terms & Conditions Contact Us web site design by offbeat studio http://www.mgchemicals.com/products/108.html (2 of 2)11/24/2008 7:54:11 AM
RTV108-85ML 价格&库存
很抱歉,暂时无法提供与“RTV108-85ML”相匹配的价格&库存,您可以联系我们找货
