High performance miniature circular connectors
HR10 Series
Features
1. A simple, yet highly reliable design for
compact, high density applications
Although small in size, the HR10 series are full
featured connectors with a well integrated design.
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
2. Extremely easy mating/unmating
operations
Easy to operable, the single-action push-pull lock
structure allows for quick and efficient locking and
unlocking.
Product Specifications
Shell size
No. of contacts
Rated current
7
4
5
6
2A
10
10
12
2A
13
2A
Shell size
No. of contacts
Rated voltage
7
4
5
6
AC150V, DC200V
AC100V, DC140V
AC100V, DC140V
10
10
12
AC100V, DC140V
13
AC100V, DC140V
Ratings
Ratings
Ratings
Operation temperature range
-25 to +85ç
Storage temperature range
-10 to +60ç
Items
Specifications
Conditions
1. Contact resistance
10mø min.
Measured at DC 1A
2. Insulation resistance
1,000Mø min.
Measured at DC 100V
3. Withstanding voltage No flashover or dielectric breakdown.
AC 300V for one minute, 4 contacts : AC 500V for 1 minute
4. Vibration resistance
No electrical discontinuity of 10µs or greater
10 to 55Hz/cycle, amplitude : 0.75mm, 3 axis directions,
for 2 hours each
5. Shock resistance
Acceleration : 490m/s2, duration : 11ms 3 directions,
3 times each
6. Mating Cycles
Contact resistance : 15mø min.
1,000 times
7. Temperature cycle
Insulation resistance : 1,000Mø min.
-55ç : 30minutes➝Normal temperature : 10 to 15 minutes➝
85ç : 30minutes➝Normal temperature :
10 to 15minutes, left for 5 cycles.
8. Humidity resistance
5Mø min. (at high humidity)
50Mø min. (at dry)
Temperature : 40ç, relative humidity : 90 to 95%,
left for 96 hours
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2017.12y
1
HR10 Series●High performance miniature circular connectors
Materials / Finish
Items
Material
Finish
Remarks
Exterior
Zinc alloy, brass
Matte finished nickel plating
Insulator
Polyamide resin, PBT resin
Blue, Black
Contact
Copper alloy
HR10 : Gold plating
HR10A : Silver plating
Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
HR10A - 7 P - 3 P C (**)
q
w e
r t y
u
qModel name : Indicates the HR10A Series. The part type is identified as follows.
HR10A : Lower cost type
HR10G : Shield type
HR10B : Coaxial contact type
wShell size : The shell size is the outer shell diameter or the mating interface end of the plug.
eShell type
P : Plug
R : Receptacle
J : Jack
rNumber of contacts
tContact form
P : Male contact
S : Female contact
yContact termination method:
None : Solder termination
C
: Crimp termination
uOther specifications : A two-digit character is added to indicate other specifications as needed.
2
Diagrams of Connectors in Combination
Male Pin side
Female Pin side
(HR10 • HR10A
HR10G Type Receptacle)
(HR10 Type Plug)
(HR10 Type Jack)
(HR10A Type Plug)
(HR10A Type Jack)
(HR10B Type Receptacle)
(HR10B Type Plug)
(HR10A-[ ]T Type Receptacle)
(HR10A-[ ]T Type Plug)
(HR10A-[ ]T Type Jack)
Notes
1 : When using a plug with male terminal, be sure to use a receptacle or jack fitted with female terminal.
2 : Standard finish of the terminal is gold plating for the HR10, and silver plating for the HR10A and HR10G.
Be sure to use male and female connectors of the same plating.
3
HR10 type
HR10 type connectors, use a gold plated contact as the standard plating specification. Silver plating is used on the contacts
for other series such as HR10A and HR10G. To avoid mixing gold and silver contacts, please be sure to confirm the plating
specification when using HR10 type connectors with HR10A or HR10G connectors.
Plug
ØB
ØC
ØD
A Max
HR10-7P-6S(73)
(Representative example)
Unit : mm
Part No.
HRS No.
HR10-7P-4P(73)
110-0021-6 73
HR10-7P-4S(73)
110-0022-9 73
HR10-7P-6P(73)
110-0023-1 73
HR10-7P-6S(73)
110-0024-4 73
HR10-10P-12P(73)
110-0025-7 73
HR10-10P-12S(73)
110-0026-0 73
No. of Contacts
A
ØB
ØC
ØD
Weight
28.5
11
7
5.2
8g
32.5
14
9.5
7.2
15g
4
6
12
Receptacle
A
5.7
ØC
ØB
6.3
D
HR10-7R-6S(73)
E(HEX)
Unit : mm
Part No.
HRS No.
HR10-7R-4S(73)
110-0031-0 73
HR10-7R-4P(73)
110-0032-2 73
HR10-7R-6S(73)
110-0033-5 73
HR10-7R-6P(73)
110-0034-8 73
HR10-10R-12S(73)
110-0035-0 73
HR10-10R-12P(73)
110-0036-3 73
Remarks : For mounting holes, see page 20.
4
No. of Contacts
A
ØB
ØC
D
E
Weight
14
11
8.85
M8×0.5
10
3.5g
16
14
11.9
M11×0.75
13
6g
4
6
12
Receptacle (PCB dip type)
G
ØA
5.7
F
ØB
E
Dip post dia.
Ø0.55
C
D(HEX)
HR10-7R-6SA(73)
HRS No.
No. of Contacts
HR10-7R-4SA(73)
Part No.
110-0059-9 73
4
HR10-7R-6SA(73)
110-0050-4 73
HR10-7R-6PA(73)
110-0061-0 73
HR10-10R-12SA(73)
110-0049-5 73
HR10-10R-12PA(73)
110-0055-8 73
6
ØA
ØB
C
D
11
8.85
M8×0.5
10
E
F
14
11.9
M11×0.75
Weight
3g
6.3
12
G
0.5
13
15.5
5g
Remarks : 1. For mounting holes, see page 20.
2. For dip post arrangement, see page 16.
Jack
A Max
ØD
ØB
5.5
ØC
Unit : mm
HR10-7J-6S(73)
Unit : mm
Part No.
HRS No.
HR10-7J-4S(73)
110-0027-2 73
HR10-7J-4P(73)
110-0028-5 73
HR10-7J-6S(73)
110-0029-8 73
HR10-7J-6P(73)
110-0030-7 73
HR10-10J-12S(73)
110-0037-6 73
HR10-10J-12P(73)
110-0038-9 73
No. of Contacts
A
ØB
ØC
ØD
Weight
28.5
11
8.85
5.2
7g
32.5
14
11.9
7.2
14g
4
6
12
5
HR10A•10G Types
HR10A connectors are a lower-cost version, yet still provide a high "Value Add" while preserving the superior characteristics
of the HR10 connectors. Cable clamps are crimped using a special crimping tool, and the shells have a rubber boot which
provides a flexible design that helps to prevent cable twisting.
The HR10G connector is a shielded type connector which has an internal contacting structure between the plug shell and
receptacle shell.
Contacts in both HR10A and 10G connectors are silver plated as standard.
Plug (Solder type)
ØD
ØB
ØC
A
HR10A-7P-6P(73)
Unit : mm
Part No.
HR10A-7P-4P(73)
HR10A-7P-4S(73)
HR10A-7P-5P(73)
HR10A-7P-5S(73)
HR10A-7P-6P(73)
HR10A-7P-6S(73)
HR10A-10P-10P(73)
HR10A-10P-10S(73)
HR10A-10P-12P(73)
HR10A-10P-12S(73)
HR10A-13P-20P(73)
HR10A-13P-20S(73)
HRS No.
110-0301-2 73
110-0302-5 73
110-0318-5 73
110-0319-8 73
110-0303-8 73
110-0304-0 73
110-0407-3 73
110-0408-6 73
110-0401-7 73
110-0402-0 73
110-0713-0 73
110-0716-8 73
No. of Contacts
A
ØB
ØC
ØD
Weight
35
11.5
7
5
9g
43
14.7
9.5
4
5
6
10
16g
12
59
19
13
37g
Plug(Crimp type)
HR10A-7P-6PC(73)
ØD
ØC
ØB
A
Unit : mm
Part No.
HR10A-7P-4PC(73)
HR10A-7P-4SC(73)
HR10A-7P-6PC(73)
HR10A-7P-6SC(73)
HR10A-10P-10PC(73)
HR10A-10P-10SC(73)
HR10A-10P-12PC(73)
HR10A-10P-12SC(73)
HR10A-13P-20PC(73)
HR10A-13P-20SC(73)
6
HRS No.
110-0501-1 73
110-0502-4 73
110-0503-7 73
110-0504-0 73
110-0601-6 73
110-0602-9 73
110-0603-1 73
110-0604-4 73
110-0701-0 73
110-0702-3 73
No. of Contacts
A
ØB
ØC
ØD
Weight
35
11.5
7
5
9g
43
14.7
9.5
4
6
10
12
16g
7
59
19
13
37g
Receptacle (Solder type)
A
ØB
5.7
ØC
F
D
E(HEX)
Part No.
HR10A-7R-4S(73)
HR10A-7R-4P(73)
HR10A-7R-5S(73)
HR10A-7R-5P(73)
HR10A-7R-6S(73)
HR10A-7R-6P(73)
HR10A-10R-10S(71)
HR10A-10R-10P(73)
HR10A-10R-12S(71)
HR10A-10R-12P(73)
HR10A-13R-20S(73)
HR10A-13R-20P(73)
HR10G-7R-4S(73)
HR10G-7R-4P(73)
HR10G-7R-6S(73)
HR10G-7R-6P(73)
HR10G-10R-10S(71)
HR10G-10R-10P(73)
HR10G-10R-12S(71)
HR10G-10R-12P(73)
HRS No.
110-0305-3 73
110-0306-6 73
110-0320-7 73
110-0321-0 73
110-0307-9 73
110-0308-1 73
110-0409-9 71
110-0410-8 73
110-0403-2 71
110-0404-5 73
110-0714-2 73
110-0715-5 73
110-1601-1 73
110-1602-4 73
110-1605-2 73
110-1606-5 73
110-1607-8 71
110-1608-0 73
110-1609-3 71
110-1610-2 73
No. of Contacts
Unit : mm
A
ØB
ØC
D
E
14
11
8.85
M8×0.5
10
E
Weight
Remarks
4
5
3g
6.3
6
10
16
14
11.9
M11×0.75
13
19.2
20.2
18
15.4
M14×0.75
17
14
11
8.85
M8×0.5
10
5g
12
8g
4
3g
6
6.3
Shield type
10
16
14
11.9
M11×0.75
13
5g
12
Receptacle (Crimp type)
F
HR10A-10R-12SC(71)
Part No.
HR10A-7R-4SC(73)
HR10A-7R-4PC(73)
HR10A-7R-6SC(73)
HR10A-7R-6PC(73)
HR10A-10R-10SC(71)
HR10A-10R-10PC(71)
HR10A-10R-12SC(71)
HR10A-10R-12PC(71)
HR10A-13R-20SC(73)
HR10A-13R-20PC(73)
HR10G-7R-4SC(73)
HR10G-7R-4PC(73)
HR10G-7R-6SC(73)
HR10G-7R-6PC(73)
HR10G-10R-10SC(71)
HR10G-10R-10PC(71)
HR10G-10R-12SC(71)
HR10G-10R-12PC(71)
HR10G-13R-20SC(73)
HR10G-13R-20PC(73)
HRS No.
110-0506-5 73
110-0505-2 73
110-0508-0 73
110-0507-8 73
110-0606-0 71
110-0605-7 71
110-0608-5 71
110-0607-2 71
110-0703-6 73
110-0704-9 73
110-1701-6 73
110-1702-9 73
110-1705-7 73
110-1706-0 73
110-1707-2 71
110-1708-5 71
110-1709-8 71
110-1710-7 71
110-1711-0 73
110-1712-2 73
ØB
E
ØA
HR10A-7R-6S(73)
C
D(HEX)
No. of Contacts
ØA
ØB
C
D
11
8.85
M8×0.5
10
E
4
6
6.3
10
14
11.9
M11×0.75
13
18
15.4
M14×0.75
17
12
15
6.3
12
12.2
12
12.2
12
12.2
12
12.2
4
11
8.85
M8×0.5
10
6
10
14
11.9
M11×0.75
13
18
15.4
M14×0.75
17
12
F
Weight
12
12.2
3g
12
12.2
12
12.2
5g
12
12.2
9.3
15
Unit : mm
Remarks
8g
3g
Shield type
5g
8g
7
Receptacle (Dip type)
G
ØA
5.7
F
ØB
E
Dip post dia.
0.2∞0.5
C
HR10A-7R-6SB(73)
D(HEX)
Unit : mm
Part No.
HRS No.
No. of
Contacts
HR10A-7R-4SB(73)
110-0314-4 73
HR10A-7R-4PB(73)
110-0315-7 73
HR10A-7R-5SB(73)
110-0322-2 73
5
HR10A-7R-6SB(73)
HR10A-7R-6PB(73)
110-0316-0 73
110-0317-2 73
6
HR10A-10R-10SB(71)
110-0413-6 71
HR10A-10R-10PB(71)
110-0414-9 71
HR10A-10R-12SB(71)
110-0415-1 71
HR10A-10R-12PB(71)
110-0416-4 71
HR10A-13R-20SB(73)
110-0707-7 73
HR10A-13R-20PB(73)
110-0708-0 73
HR10G-7R-4SB(73)
110-1801-0 73
HR10G-7R-4PB(73)
110-1802-3 73
HR10G-7R-6SB(73)
110-1805-1 73
HR10G-7R-6PB(73)
110-1806-4 73
HR10G-10R-10SB(71)
HR10G-10R-10PB(71)
110-1807-7 71
110-1808-0 71
HR10G-10R-12SB(71)
110-1809-2 71
HR10G-10R-12PB(71)
110-1810-1 71
HR10G-13R-20SB(73)
110-1811-4 73
HR10G-13R-20PB(73)
110-1812-7 73
ØA
ØB
C
D
11
8.85
M8×0.5
10
E
F
G
Weight Remarks
4
3g
6.3
0.5
15.6
10
14
11.9
M11×0.75
13
18
15.4
M14×0.75
17
11
8.85
M8×0.5
10
5g
12
8g
4
3g
6
6.3
0.5
15.6
Shield
type
10
14
11.9
M11×0.75
13
18
15.4
M14×0.75
17
5g
12
8g
ØD
0.2
ØC
B
1
ØE
2
Dust cap
HR10-7R-C
ØA
Unit : mm
Part No.
HR10-7R-C
HR10-10R-C
HR10A-13R-C
8
HRS No.
110-0058-6 00
110-0052-0 00
110-0452-8 00
ØA
11
14
17.5
B
7
8.5
11.5
ØC
8
10.8
14
ØD
11.2
14.1
18.1
ØE
13
15
19
Jack (Solder type)
A
HR10A-7J-6S(73)
ØD
ØC
ØB
5.5
HRS No.
HR10A-7J-4S(73)
110-0309-4 73
HR10A-7J-4P(73)
110-0310-3 73
HR10A-7J-6S(73)
110-0311-6 73
HR10A-7J-6P(73)
110-0312-9 73
HR10A-10J-10S(73)
110-0411-0 73
HR10A-10J-10P(73)
110-0412-3 73
HR10A-10J-12S(73)
110-0405-8 73
HR10A-10J-12P(73)
110-0406-0 73
No. of Contacts
A
ØB
ØC
ØD
Weight
35.3
11
8.85
5
9g
43.5
14
11.9
7
16g
4
6
10
12
Jack (Crimp type)
A
HR10A-7J-6SC(73)
ØE
ØC
D
ØB
Unit : mm
Part No.
Unit : mm
HRS No.
No. of Contacts
HR10A-7J-4SC(73)
Part No.
110-0510-2 73
4
HR10A-7J-6SC(73)
110-0512-8 73
6
HR10A-10J-10SC(73)
110-0610-7 73
10
HR10A-10J-12SC(73)
110-0612-2 73
12
HR10A-13J-20SC(73)
110-0705-1 73
HR10A-13J-20PC(73)
110-0706-4 73
A
ØB
ØC
35.3
11
8.85
43.5
14
11.9
58.5
18
15.4
D
ØE
Weight
5
9g
5.5
16g
7
8.5
37g
9
HR10B Type Connector
The HR10B connector combines 10 signal lines and one coaxial contact in the standard number 10 shell. Performance
specifications for the coaxial contacts are on the 11 page.
ØB
Ø14.7
Plug
A
HR10B-10P-10PC(73)
Unit : mm
HRS No.
A
ØB
HR10B-10P-10PC(73)
Part No.
110-0901-0 73
50
5
HR10B-10PA-10PC(73)
110-0906-3 73
43
7
Applicable coaxial contact
HR10B-2.5CJ(73)
Ø11.9
Ø14
Receptacle
M11∞0.75
6.3
13(HEX)
12
HR10B-10R-10SC(71)
Unit : mm
Part No.
HR10B-10R-10SC(71)
10
HRS No.
110-0902-2 71
HR10B-2.5CP(73)
Coaxial contacts
The coaxial contacts shown here are for use with the HR10B connector.These contacts have locking barbs and are inserted
from the rear of connector.Please use the following information to select the correct terminals.
Materials / Finish
Part
Material
Plug shell
Finish
Brass
Jack shell
Gold plating
Insulator
Tetrafluoride resin
Male pin
Phosphor bronze
Female pin
Beryllium copper
Description
Test data
Impedance
50ø
1000Mø or more at DC250V
Contact resistance Center 6.5mø or less and outer 4mø or less at DC1A
Gold plating
AC250V r.m.s for 1minute
V.S.W.R
1.3 or less for 0 to 1000MHz
Pull force
4.9N (500gf) or more
Plug
3.6
5.2
4.1
(clamp)
18.05
HR10B-2.5CP(73)
Ø4.2
Ø3.8
Ø1.1
7.1
Unit : mm
Part No.
HR10B-2.5CP(73)
HRS No.
Applicable cable
Applicable connector
110-0904-8 73
0.8D-QEW-CW(By Fjikura wire)
HR10B-10R-10SC(71)
Jack
5.2
4.1
3.6
(clamp)
18.2
Ø1.1
7.25
HR10B-2.5CJ(73)
Ø4.2
Ø2.65
Performance
Unit : mm
Part No.
HR10B-2.5CJ(73)
HRS No.
110-0903-5 73
Applicable cable
HR10B-10P-10PC(73)
11
Cable connecting methods
HR10B-2.5CP(73)
HR10B-2.5CJ(73)
1. Cable end treatment
Fig.1
11±0.5
1. Dimensions for cable end treatment are shown in Fig 1.
2. Termination is described below.
(1) Strip cable outer jacket as indicated.
(2) Slit outer jacket on both sides per Fig.1.
(3) Fold back outer cover.
(4) Remove insulator from cable.
1.4±0.2
3.7±0.2
(2.5)
Slit cable outer jaket
2 pieces (180° reverse side)
2. Soldering male pin to cable center conductor
Fig.2
Male pin
1. Solder male pin to cable center conductor as indicated in Fig.2.
(1) Pre-solder the solder pot of pin with Ø0.5mm string solder.
(2) Male pin should fit flush against the cable insulator as
shown.
(3) Remove any excess solder from the pin with a knife.This
surface must be smooth.
(4) A properly soldered terminal will yield 500gf when stretched.
Soldering
Should fix flush
Contact fixing jig such as vise
3. Crimping cable outer conductor
Fig.3
15±0.2
Clamp
Connector
Remove excess insulator material
(remaining after clamping is complated)
with a knife or aimilarobject.
12
1. Insert the cable into the connector and make sure to push it
all the way in. To confirm that the cable is fully inserted,
make sure that the depth is 1.5 ± 0.2mm by measuring from
the end of the connector to the tip of the male contact by
using a vernier calipers or other suitable measuring device.
2. Use the HR10-TC-01 tool to crimp the metal fitting to the
cable.
HR10A-( )T Type (Threaded Coupling Type)
HR10A-( )T connector is a new product having a threaded coupling locking mechanism. Electric parformance is same as
HR10 and HR10A push-pull locking type connectors.
Plug (Solder type)
HR10A-10TP-12P(73)
Unit : mm
Part No.
HR10A-7TP-6P(73)
HR10A-7TP-6P(74)
HR10A-10TP-12P(73)
HR10A-10TPA-12S(73)
HR10A-10WTP-12P(73)
HR10A-10WTP-12S(73)
HR10A-13TPD-20P(73)
HRS No.
110-0331-3 73
110-0331-3 74
110-0432-0 73
110-0446-5 73
110-1101-9 73
110-1106-2 73
110-1015-9 73
No. of Contacts
ØA
B
ØC
D
ØE
6
12
M10×0.75
7
35
5
17
M13×0.75
43
7
45.8
6.5
56.5
7
12
Remarks
Gold plating
9.5
15
M12×0.75
M17×1
13
*Waterproof plug need resin filling inside when connector assembly.
When mated, the connector against water penetration.
Plug (Crimp type)
HR10A-10TP-12PC(73)
Ø7
Ø9.5
Ø17
43
M13∞0.75
ØA
B
ØC
ØE
D
Unit : mm
Part No.
HR10A-10TP-12PC(73)
HRS No.
No. of Contacts
110-0455-6 73
12
13
E
5.7
ØD
B
C
A
F(HEX)
HR10A-10TR-12S(73)
Unit : mm
Part No.
HRS No.
No. of Contacts
HR10-7TR-6S(73)
110-0089-0 73
6
HR10A-10TR-12S(73)
110-0453-0 73
HR10A-10WTR-12S(73) 110-1104-7 73
A
B
M10×0.75
M13×0.75
12
M12×0.75
6.3
6.8
C
ØD
E
F
Remarks
M8×0.5
11
14
10
Gold plating
14
16
13
M11×0.75
M10.5×0.75
Remarks : For mounting hole, see page 15(10TR,10WTR) 20(7TR).
B
ØA
C
E
HR10A-10TR-12SC(73)
D
F(HEX)
Unit : mm
Part No.
HR10A-10TR-12SC(73)
HR10A-13TR-20SC(73)
HRS No.
110-0456-9 73
110-1002-7 73
No. of Contacts
12
ØA
14
18
B
12
15
C
6.3
9.3
D
M13×0.75
M17×1
E
M11×0.75
M14×0.75
F
13
17
G
5.7
F
ØA
E
Dip post
H
C
B
HR10A-10TR-12PB(73)
D(HEX)
Unit : mm
Part No.
HR10A-7TR-6SA(73)
HRS No.
110-0330-0 73
HR10A-10TR-12SB(73)
110-0433-3 73
HR10A-10TR-12PB(73)
110-0457-1 73
HR10A-10TR-12PE(73)
110-0445-2 73
HR10A-10WTR-12SB(73) 110-1102-1 73
HR10A-13TR-20SB(73)
110-1014-6 73
No. of Contacts
6
ØA
11
12
14
B
M10×0.75
C
M8×0.5
M13×0.75
M11×0.75
M12×0.75 M10.5×0.75
M17×1
M14×0.75
D
10
E
F
6.3
0.5
13
6.8
17
9.3
Remarks : 1.For mounting holes, see page 15. However, 7TR size shell be referred to page 20 on the shell size 7.
2.For dip post arrangement, see page 16.
14
G
15.5
H
Ø0.55
15.6
15.5
14 0.2×0.5
15.6
17.8
Jack (Solder type)
ØA
ØC
B
D
HR10A-10TJ-12S(73)
Part No.
HRS No.
No. of Contacts
HR10A-10TJ-12S(73)
110-0436-1 73
HR10A-10TJ-12P(73)
110-0459-7 73
HR10A-10WTJ-12S(73)
110-1103-4 73
12
ØA
B
ØC
D
14.7
41.3
7
M13×0.75
14
46.5
6.5
M12×0.75
Remarks
*Waterproof jack need resin filling inside when connector assembly.
Panel mounting hole dimensions (Screw coupling)
The mounting hole dimensions shown below are for connectors to be tightened by a hexagonal nut from the back of the
panel. The dimensions below apply only to the HR10A-( )T and not the 7TR. For the dimensions of connectors of other
types, see page 20.
.1
+0 0
Ø10.6 +0.1
1
Ø1
8.6 +0.1
Type
Type HR10A-10TR
HR10A-10TR
(Panel thickness
thickness 11to
(Panel
to2mm)
2mm)
1
0.
+ 0
1
14
Ø
9.6 +0.1
Unit : mm
Type HR10A-10WTR
(Panel thickness 1 to 2mm)
Type HR10A-13TR
(Panel thickness 1 to 1.5mm)
15
Contact
Male contact
Unit : mm
1.2
Type
1
1.15
A
Part No.
HRS No.
Applicable
cable
Type of plating
Loose HR10-PC-111 110-0515 6 Partial gold plating
contact HR10-PC-112 110-0513 0
Silver plating
A
10
26 to 30
AWG
Reel HR10-PC-211 110-0516 9 Partial gold plating
contact HR10-PC-212 110-0514 3
Silver plating
Remarks : 1. Use cables with a coating outside diameter of 1mm or less.
2. Loose piece terminal are available in packs. Each pack
contains 100 terminals. Strip terminals are available in
reels. Each reel contains 10,000 terminals.
Female contact
Unit : mm
1.2
A
1
1.15
Type
Part No.
HRS No.
Applicable
cable
Type of plating
Loose HR12-SC-111 112-0410 0 Partial gold plating
contact HR12-SC-112 112-0411 3
Silver plating
A
10
26 to 30
AWG
HR12-SC-211 112-0407 6 Partial gold plating
Reel
contact HR12-SC-212 112-0408 9
Silver plating
Receptacle dip post arrangement dimensions
7
10
9
2
1
5
4
2
3
3
1
5
2.5
1.8 1.8
6
Ø0.8+0.1
(5 Places)
1
2.55
4
1
2.55
10-size 10 cores
1.8 1.8
1
9
8
1.77
2.71
3
12 11
6
5
1
5 6
2
10
7
2.85
0.95
1
1.1
8
4
1.77
2.71
10-size 12 cores
2 3
4
7
9 10
17 18 19 20
0.8
0.8
2.4
2.4
4
4
13-size 20 cores
7-size 5 cores
Remarks : 1.The above figures are views from the mating side and pin inserts from the wiring-connection side.
2.Dimensional tolerance of ±0.05 is recommended for the board arrangement.
16
8
11 12 13 14 15 16
2.85
0.95
7-size 6 cores
0.48
0.9
1.8
Ø0.8+0.1
(20 Places)
2.38
0.95
0.95
2.58
1.38
7-size 4 cores
0.9
1.8
3
2.11
0.55
1.13
1.13
4
1.56
1.13
2
Ø0.8+0.1
(12 Places)
Ø0.8+0.1
(10 Places) 2.38
2
2.75
5
3
Ø0.8+0.1
(6 Places)
1
1
1
6
2.5
4
1.56
1.13
Ø0.8+0.1
(4 Places)
Tools
Type
Item
Part No.
HRS No.
Manual
Manual crimping tool
HT802/HR12-SC-1
150-0400-3
CM-105C
901-0001-0
Automatic crimping
machine body
Applicable terminal
HR10-PC-112
HR12-SC-112
_______
Applicable cable
26 to 30AWG
_______
HR10-PC-211
212
Automatic
Applicator
AP105-HR12-1
901-2015-9
26 to 30AWG
HR12-SC-211
212
Cable crimping tool
Extractor
HR10-TC-01
150-0036-2
HR10A-TC-02
150-0041-2
HR12-SC-TP
150-0050-3
RP6-SC-TP
150-0039-0
HR10B-TP
150-0061-0
_______
(HR10B-2.5CP(73),
HR10B-2.5CJ(73))
Ø5, Ø7
HR12-SC-112
HR12-SC-212
HR10-PC-112
HR10-PC-212
_______
HR10B-2.5CP(73)
HR10B-2.5CJ(73)
(HT802/HR12-SC-1)
Hand Crimp Tool
(HR12-SC-TP)
(HR10A-TC-02)
Hand Cable Crimp Tool
(RP6-SC-TP)
Extraction Tool
Auto Crimp Tool CM-105C
(HR10B-TP)
Coaxial Contact Removal Tool
17
How to use a connector
1.Inserting
2.Withdrawing
Panel
HR10 TYPE
Receptacle
Plug
Cable
B
A
Panel
HR10A TYPE
Receptacle
Panel
Plug connection sleeve Cable
Panel
Plug
Cable
A
Cable
B
Hold the plug at point A, align the plug guide with the
receptacle guide, and push the plug straight.
The plug will mate with the receptacle smoothly.
Hold the plug connection sleeve B and pull the sleeve
straight. The plug will come off easily.
Connecting tools
When terminating the wires, use the jigs noted below for easy assembly / disassembly of the connector parts.
HR10-10P-T02
18
HR10-10J-T04
Part No.
HRS No.
HR10-7P-T01
150-0009-0
HR10-7P
HR10-10P-T02
150-0010-9
HR10-10P
HR10-7J-T03
150-0011-1
HR10-7J
HR10-10J-T04
150-0012-4
HR10-10J
HR10-13P-T05
150-0059-8
HR10-13P
HR10-13J-T06
150-0060-7
HR10-13J
Cable assembly procedure on plug side
This applies also to the jack side assembly procedure.
No special procedure is given here for the receptacle side because no special procedure is necessary.
P shell unit
Clamp washer
Plug body
Tightener
Cable
HR10 TYPE
Bifurcated part
About 2
Face A
C
Face B
Spanner jaw distance
HR10A TYPE
Cord bushing
P shell unit
Clamp
Plug body
Cable
A
About 2 for solder type
for crimp type
Boss
2 or more
Set screw
D
Table 2 spanner jaw distance Table 3 cable end processing dimensions
Size
7
10
13
HR10
8
11
____
HR10A
7.5
9.5
13
Size
7
10
13
Dimension C Dimension D for HR10A
for HR10
Solder type Crimp type
5.5 or less
10
15 to 20
7 or less
16
____
25
HR10 TYPE
1
2
3
4
5
Table 1
Size
7
10
13
Tightening force
1.5N·m(15kg·cm)
2N·m(20kg·cm)
HR10A TYPE
Use cables with a nominal sectional area of 0.129mm2 (26 AWG) at the finish outside diameters applicable for each size.
After processing the cable ends according to the dimensions in the above drawings, fit the parts to the cable as shown
in the drawings.
Fit the parts to the cable in the following order:
tightener, clamp washer, and plug body.
cord bushing and plug body.
(solder type)
Insert the P shell unit into the assembly tool stand and solder it.
(crimp type)
After crimping the appropriate crimp terminal to the cable core, insert the crimp terminal into the terminal hole in the P
shell unit.
Assemble the connector in the following steps.
1. Screw the plug body into the thread in the P shell unit
with the tightening force shown in Table 1 using a
torque wrench with a fixed torque.
Before tightening the plug body,slacken part C so that
no load is applied to the soldered wires.
2. Apply the clamp washer to the bifurcated part of the
plug body, and then tighten the tightener until surface
B touches the plug body surface A.
Note : In order to prevent looseing, please apply an
adhesive at the thread of plug body.
1. Fix by caulking the clamp accompanying the cable
with the cable crimping tool(HR10A-TC-02)
2. Screw the plug body into the thread in the P shell until
with a tightening force shown in Table 1 using a torque
wrench with a fixed torque. Before tightening the plug
body, slacken the part D so that no load is applied to
the soldered wires.
3. Tighten the set screw so that the tip of the screw
presses one of the two bosses on the clamp.
Fix the set screw with a tightening torque of 0.3N
(3kg·cm).
4. Attach the cord bushing to the plug body.
This completes the work.
For any question on using the plugs, contact our sales or engineering department.
19
Recommended Mounting Hole
Mounting hole dimension shown here is tight by hexagon nut from back side.
A
Map mark
7 size
A
1.6 +0.1
B
5.1
+0.1
C
8.1 +0.1
Panel thickness
10 size
13 size
2.6 +0.1
B
Shell size
+0.1
0.7 to 2
ØC
0.8 to 1.5
Contact Arrangement
Shell size
7 size
10 size
Contact arrangement
No. of contacts
Current rating
Contact resistance
Solder pot inside dia.
Shell size
4
AC500V for a minute
5
6
10
AC300V for a minute
2A
MIN 1,000Mø
MAX 10mø
Ø0.8
10 size
12
13 size
Contact arrangement
No. of contacts
Current rating
Contact resistance
10+coaxial contact
AC300V for a minute
2A
MIN 1,000Mø
MAX 30mø
____
Notes 1. The contact arrangement shown here is the mating surface of socket insert assembled.
2. The withstanding voltage shown here is test voltage value.
3. The isulation resistance value is measured at DC100V.
4. The contact resistance value is measured at DC1A.
MAX 10mø
Ø0.8
Precautions
1. Switch off the power of the circuit before disconnecting or plugging-in the connector.
2. Use a connector with socket contacts at the power side of the circuit.
3. Make sure that the coupling is in completely locked position.
4. Cable clamping, cable rotation, and other forces may vary with the cable construction. Please make sure that your cable is
suitable for use with these connectors before usage and production.
5. This product series uses silver plated contacts. Silver reacts easily to exposure to sulfur gas so the below conditions may
cause tarnishing.
・Dusty environments
・Area with a high concentration area of gases such as sulfur dioxide gas, hydrogen sulfide gas, nitrogen dioxide gas
and so on.
Example; In close proximity to factory exhaust, automotive emissions, etc.
・Close to heaters, or in other areas marked by extreme temperature differences or high humidity.
・Close to rubber products includes rubber adhesives.
The Electrical connection is not affected by tarnishing on a silver surface due to the wiping effect of the contact pins.
Storage
Packing state; Packed in original packing or equivalent container
Temperature -10 to +60ç
Humidity
85% Max
(It is recommended that the product be stored in an area of normal level of temperature and humidity, and free of any
temperature fluctuation)
Please use this products within 6 months of delivery.
(After 6 month, please check the solderbility before use)
“Storage” means long-term storage of the unused products in sealed packaging, prior to assembly to PCB.
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose.com
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 12/2017. Contents are subject to change without notice for the purpose of improvements.
21
