B004-DUA2-K-R
B004-DUA2-K-R
    TRIPPLITE
    2 PORT KVM SWITCH (DVI/USB)
B004-DUA2-K-R 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 2-Port DVI/USB KVM Switch with Audio and Cables MODEL NUMBER: B004-DUA2-K-R Highlights ● Control 2 computers with a single DVI monitor, USB keyboard and USB mouse ● Switch ports via keyboard hotkeys or pushbuttons ● Allows for the sharing of audio components between systems; listen to music from one computer while accessing another ● Features two USB 2.0 ports for the sharing of USB peripherals between the connected computers ● (x2) 4-ft. (1.22 m) USB cables and (x2) 4-ft. (1.22 m) DVI + Audio KVM cable kits included ● Full time DDC support provides the necessary EDID information for optimal video performance on Windows 7 and other operating systems ● Compatible with all major operating systems Features ● Fast, easy switching via keyboard hotkeys or pushbuttons ● Plug-and-play setup - no software required ● ● Hot-swap capability allows easy addition or removal of computers without powering down the switch or other computers KVM Console: A DVI monitor, USB keyboard, and USB mouse ● ● Speaker and microphone connections allow for the sharing of audio components between systems ● Independent audio/mic and USB peripheral switching function allows for an uninterrupted experience. A computer can be printing on a printer connected to one of the USB 2.0 peripheral ports, while you listen to audio from and access another computer; all at the same time. Computers: DVI-I port (P118000 DVI-I to DVI-D Adapter is required for computers with DVID ports), and USB Port ● Audio (Optional): A microphone and speakers with 3.5mm MiniStereo connectors and a computer with 3.5mm MiniStereo ports ● Compatible with all major operating systems System Requirements ● Supports 2-Channel Stereo Audio ● Features two USB 2.0 ports for the sharing of USB peripherals (e.g. flash drives, printers, etc.) between the connected computers ● Uses DVI-I technology, allowing for the transmission of a digital (up to 1920 x 1200) or analog (up to 2048 x 1536) signal. A DVI to VGA adapter, such as Tripp Lite's P126-000, is required for conversion to an analog monitor. ● To connect to a HDMI monitor, a DVI to HDMI adapter such as Tripp Lite's P132-000 is required (Audio is not supported when converting from DVI to HDMI). ● Full time DDC support provides the necessary EDID information for optimal video performance on Windows 7 and other operating systems ● Supports Microsoft® IntelliMouse® and the scrolling wheel on most mice ● (x2) 4-ft. (1.22 m) USB cables and (x2) 4-ft. (1.22 m) DVI + Audio KVM cable kits included ● Compatible with all major operating systems Specifications 1/4 Package Includes ● B004-DUA2-K-R ● (x2) 4-ft. (1.22 m) DVI-I + 3.5mm Audio Cable kits ● (x2) 4-ft. (1.22 m) USB A-B Device Cables ● Owner's Manual ● External Power Supply with NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.4A Output: 5V, 2A) 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332140036 Max CPU 2 Technology USB 2.0 (High Speed); DVI; Stereo Audio VIDEO Max Supported Video Resolution 1920 x 1200 (Digital), 2048 x 1536 (Analog) INPUT Voltage Compatibility (VAC) 100; 110; 120; 127; 200; 208; 220; 230; 240 POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 1.0A External Power Supply Output Specs (V / A) 5V / 2.4A External Power Supply Cord Length (ft.) 5 External Power Supply Cord Length (m.) 1.5 DC Barrel Plug OD: 5.5 x 2.5 x 9.5mm, Positive Pin, Negative Sleeve Power Consumption (Watts) 4.7 USER INTERFACE, ALERTS & CONTROLS LED Indicators Green (PC 1); Blue (PC 2) PHYSICAL Color Silver Material of Construction ABS Cable Jacket Color Silver Shipping Dimensions (hwd / in.) 5.60 x 8.20 x 7.10 Shipping Dimensions (hwd / cm) 14.22 x 20.83 x 18.03 Shipping Weight (lbs.) 2.90 Shipping Weight (kg) 1.32 Unit Dimensions (hwd / in.) 1.000 x 6.000 x 2.500 Unit Packaging Type Box Unit Weight (lbs.) 0.4 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Weight (kg) 0.18 ENVIRONMENTAL Operating Temperature Range 32 to 104 F (0 to 40 C) Storage Temperature Range -4 to 140 F (-20 to 60 C) Relative Humidity 0%-90% RH, Non-Condensing BTUs 245.52 COMMUNICATIONS IP Remote Access No CONNECTIONS Number of Ports 2 PC/Server Connections DVI; USB Side A - Connector 1 (2) DVI-I (FEMALE) Side A - Connector 2 (2) USB B (FEMALE) Side B - Connector 1 DVI-I (FEMALE) Side B - Connector 2 (4) USB A (FEMALE) Side B - Connector 3 (2) 3.5MM (FEMALE) Computer Keyboard and Mouse Interface USB Computer Monitor Interface DVI-I Single-Link Console Keyboard and Mouse Interface USB Console Monitor Interface DVI-I Single-Link Connector Plating Nickel FEATURES & SPECIFICATIONS Number of Users 1 NIAP-Certified Secure No Port Selection Pushbutton; Hotkey USB Hub Ports Yes Number of USB Hub Ports 2 USB Specification USB 2.0 (up to 480 Mbps) Driver Required No Cat5 KVM Switch No STANDARDS & COMPLIANCE 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States External Power Supply Certifications FCC; UL; cUL; TUV; CB Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B004-DUA2-K-R 价格&库存
很抱歉,暂时无法提供与“B004-DUA2-K-R”相匹配的价格&库存,您可以联系我们找货
