B004-DUA4-K-R
B004-DUA4-K-R
    TRIPPLITE
    KVM SWITCH DVI USB W/AUDIO CABLE
B004-DUA4-K-R 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 4-Port DVI/USB KVM Switch with Audio and Cables MODEL NUMBER: B004-DUA4-K-R Highlights ● Control 4 computers with a single DVI monitor, USB keyboard and USB mouse ● Switch ports via keyboard hotkeys or pushbuttons ● Allows for the sharing of audio components between systems; listen to music from one computer while accessing another ● Features two USB 2.0 ports for the sharing of USB peripherals (e.g. flash drives, printers, etc.) between the connected computers ● (x4) 6ft USB cables and (x4) 6ft DVI + Audio KVM cable kits included ● Full time DDC support provides the necessary EDID information for optimal video performance on Windows 7 and other operating systems ● Compatible with all major operating systems Features ● Fast, easy switching via keyboard hotkeys or pushbuttons ● Plug-and-play setup - no software required ● Hot-swap capability allows easy addition or removal of computers without powering down the switch or other computers ● KVM Console: A DVI monitor, USB keyboard, and USB mouse ● Speaker and microphone connections allow for the sharing of audio components between systems ● ● Supports 2-Channel Stereo Audio ● Independent audio/mic and USB peripheral switching function allows for an uninterrupted experience. A computer can be printing on a printer connected to one of the USB 2.0 peripheral ports, while you listen to audio from and access another computer; all at the same time. Computers: DVI-I port (P118000 DVI-I to DVI-D Adapter is required for computers with DVID ports), and USB Port ● Audio (Optional): A microphone and speakers with 3.5mm MiniStereo connectors and a computer with 3.5mm MiniStereo ports ● Compatible with all major operating systems System Requirements ● Uses DVI-I technology, allowing for the transmission of a digital (up to 1920 x 1200) or analog (up to 2048 x 1536) signal. A DVI to VGA adapter, such as Tripp Lite's P126-000, is required for conversion to an analog monitor. ● To connect to a HDMI monitor, a DVI to HDMI adapter such as Tripp Lite's P132-000 is required (Audio is not supported when converting from DVI to HDMI). ● Full time DDC support provides the necessary EDID information for optimal video performance on Windows 7 and other operating systems Package Includes Supports Microsoft® IntelliMouse® and the scrolling wheel on most mice ● B004-DUA4-K-R ● (x4) 6ft USB cables and (x4) 6-ft. (1.83 m) DVI + Audio KVM cable kits included ● (x4) 6-ft. (1.83 m) DVI-I + 3.5mm Audio Cable kits ● Compatible with all major operating systems ● (x4) 6-ft. (1.83 m) USB A-B device cables ● Owner's Manual ● External Power Supply with NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.4A Output: 5V, 3A) ● Specifications 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332167903 Max CPU 4 Technology USB 2.0 (High Speed); DVI; Stereo Audio VIDEO Max Supported Video Resolution 1920 x 1200 (Digital), 2048 x 1536 (Analog) INPUT Voltage Compatibility (VAC) 100; 110; 120; 127; 200; 208; 220; 230; 240 POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America; CEE 7/16 Schuko; BS 1363 UK; AS/NZS 3112 Australia External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.8A External Power Supply Output Specs (V / A) 5V / 3A External Power Supply Cord Length (ft.) 6 External Power Supply Cord Length (m.) 1.83 DC Barrel Plug OD: 5.5 x 2.5 x 10mm, Positive Pin, Negative Sleeve Power Consumption (Watts) 8 USER INTERFACE, ALERTS & CONTROLS LED Indicators Blue (Selected PC) PHYSICAL Color Silver Material of Construction ABS Cable Jacket Color Silver Shipping Dimensions (hwd / in.) 5.00 x 10.00 x 12.60 Shipping Dimensions (hwd / cm) 12.70 x 25.40 x 32.00 Shipping Weight (lbs.) 6.50 Shipping Weight (kg) 2.95 Unit Dimensions (hwd / in.) 1.900 x 10.250 x 4.000 Unit Packaging Type Box Unit Weight (lbs.) 1.2 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Weight (kg) 0.54 ENVIRONMENTAL Operating Temperature Range 32 to 104 F (0 to 40 C) Storage Temperature Range -4 to 140 F (-20 to 60 C) Relative Humidity 0%-90% RH, Non-Condensing BTUs 27.3 BTU/Hr COMMUNICATIONS IP Remote Access No CONNECTIONS Number of Ports 4 PC/Server Connections DVI; USB Side A - Connector 1 (4) DVI-I (FEMALE) Side A - Connector 2 (4) USB B (FEMALE) Side B - Connector 1 DVI-I (FEMALE) Side B - Connector 2 (6) USB A (FEMALE) Side B - Connector 3 (2) 3.5MM (FEMALE) Computer Keyboard and Mouse Interface USB Computer Monitor Interface DVI-I Single-Link Console Keyboard and Mouse Interface USB Console Monitor Interface DVI-I Single-Link Connector Plating Nickel FEATURES & SPECIFICATIONS Autoscan (Y,N) Y Autoscan Duration 10 TO 100 SECONDS (SELECTABLE IN 10 SECOND INTERVALS) Number of Users 1 NIAP-Certified Secure No Port Selection Pushbutton; Hotkey USB Hub Ports Yes Number of USB Hub Ports 4 USB Specification USB 2.0 (up to 480 Mbps) Driver Required No Cat5 KVM Switch No 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States STANDARDS & COMPLIANCE External Power Supply Certifications BS; CE; FCC; GS; TUV; UL; cUL Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B004-DUA4-K-R 价格&库存
很抱歉,暂时无法提供与“B004-DUA4-K-R”相匹配的价格&库存,您可以联系我们找货
