1000 Eaton Boulevard
Cleveland, OH 44122
United States
NetCommander 8-Port Cat5 KVM Switch 1U
Rack-Mount with PS2 to USB Input Adapter
MODEL NUMBER: B072-008-1A
Highlights
8 RJ45 Ports utilize inexpensive
Cat5 patch cables
Expandable - Cascade a second
level of KVM switches to control
up to 128 servers from a single
station
Accepts PS2 or USB Mouse and
Keyboards with included
Adapter
System Requirements
Computers: The Tripp Lite
B078-101-USB-1 Server
Interface Module must be used
to connect a server to the server
ports on the KVM switch.
For computers with Displayport
or HDMI, change to VGA using
Tripp Lite adapters P134-06NVGA-V2 or P131-06N.
Maximum video resolutions
using adapters may vary.
Compatible with all major
operating systems
Features
Expandable - Cascade a second level of KVM switches to control up to 128 servers from a single
station
Extend distance: between computer and switch up to 30 meters/100 ft.
Package Includes
8-Port NetCommander 1U
Rackmount Cat5 KVM Switch
Rack mountable: sleek, 1U space saving KVM switches
PS2 to USB Adapter
Accepts PS2 Mouse and Keyboard ( or USB Mouse and Keyboard with included adapter )
6-ft. (1.83 m) Power Cord
Innovative CAT5 technology: eliminate cable clutter at the rack
Multi-layer security: protects your corporate data
6-ft. (1.83 m) Firmware Upgrade
Cable
Easy server management: choice of On Screen Display, Hot-key,or push button control
Rackmount Bracket kit
Multi-platform: PS/2 and USB support
To convert DisplayPort or HDMI computers to VGA, use Tripp Lite adapters P134-06N-VGA-V2 or
P131-06N. Maximum video resolutions using adapters may vary.
Easily add IP functionality with Tripp Lite Model B051-000
Add Tripp Lite Model B021-000-19 for space saving, in-the-rack, LCD, Keyboard and Mouse
Compact Size: 17"W x 5"D x 1.75"H
Video Resolution: 1600x1200@75Hz
Internal Power Supply
Compatible with all major operating systems
Constructed of heavy-duty steel housing
Specifications
OVERVIEW
UPC Code
037332186584
1/4
Cleveland, OH 44122
United States
Max CPU
128
Technology
Cat5/5e; PS/2; VGA/SVGA
VIDEO
Max Supported Video Resolution
1600 X 1200 @ 75 Hz
Max. Distance (Between any 2
Units)
100 ft (30.5m)
Max Number of Ports (Entire Chain)
128
INPUT
Voltage Compatibility (VAC)
100; 110; 120; 127; 200; 208; 220; 230; 240
Input Frequency
50/60Hz
Input Current
120V (0.7A) / 230V (0.3A)
Power Input Receptacle
IEC-320-C14
POWER
Power Consumption (Watts)
8
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
Green(CPU ON, SELECTED)
PHYSICAL
Color
Black
Material of Construction
Steel (Steel, Electrogalvanized, Cold Rolled, Coil)
Rackmountable
Yes
Shipping Dimensions (hwd / in.)
4.33 x 20.28 x 7.68
Shipping Dimensions (hwd / cm)
11.00 x 51.51 x 19.51
Shipping Weight (lbs.)
5.34
Shipping Weight (kg)
2.42
Unit Dimensions (hwd / in.)
1.710 x 16.780 x 4.770
Unit Packaging Type
Box
Unit Weight (lbs.)
3.50
Unit Weight (kg)
1.59
ENVIRONMENTAL
Operating Temperature Range
32 to 104 F (0 to 40 C)
Storage Temperature Range
-40 to 158 F (-40 to 70 C)
Relative Humidity
0% to 80% RH, Non-Condensing
2/4
Cleveland, OH 44122
United States
BTUs
27.3 BTU/Hr
COMMUNICATIONS
IP Remote Access
No
CONNECTIONS
Number of Ports
8
PC/Server Connections
PS/2; USB; VGA
Side A - Connector 1
HD15 (FEMALE)
Side A - Connector 2
(2) MINI DIN-6 (FEMALE)
Side A - Connector 3
RJ11 (FEMALE)
Side B - Connector 1
(8) RJ45 (FEMALE)
Computer Keyboard and Mouse
Interface
PS/2; USB
Computer Monitor Interface
VGA
Console Keyboard and Mouse
Interface
PS/2
Console Monitor Interface
VGA
PORT EXPANSION
Daisy-chainable or Cascadable
Cascadeable
FEATURES & SPECIFICATIONS
Number of Users
1
NIAP-Certified Secure
No
On-Screen Display (OSD)
Yes
Port Selection
Pushbutton; Hotkey; OSD
Driver Required
No
Cat5 KVM Switch
Yes
Recommended Category Cable
Cat5e/6 Cables
STANDARDS & COMPLIANCE
Product Certifications
CAN/CSA C22.2; CAN/CSA-C22.2 No. 60950-1 (Canada); UL 60950-1
Product Compliance
RoHS; CE (Europe); REACH; FCC Part 15 Class A (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
3/4
Cleveland, OH 44122
United States
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“B072-008-1A”相匹配的价格&库存,您可以联系我们找货
