B004-DUA2-HR-K
B004-DUA2-HR-K
    TRIPPLITE
    2PORTKVMSWITCH(DVI/USB)
B004-DUA2-HR-K 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 2-Port DVI Dual-Link / USB KVM Switch with Audio and Cables MODEL NUMBER: B004-DUA2-HR-K Highlights ● Control 2 computers with a single DVI monitor, USB keyboard and USB mouse ● Supports DVI Dual Link resolution 2560 x 1600 ● 2 sets 6ft cables included ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases System Requirements ● DVI or VGA* port ● A USB port ● 3.5 mm Mini Stereo microphone and speaker jacks (If using the audio feature) Package Includes Features ● ● 2-Port DVI Dual Link/USB KVM switch with 7.1 channel surround-sound audio and USB 2.0 peripheral sharing (B004-DUA2-HR-K) Built-in 2-Port USB 2.0 hub allows USB devices to be shared amongst computers connected to the KVM switch ● 3.5 mm Mini Stereo Speaker and Microphone jacks allow a single microphone to provide audio input to each of the connected computers, and let you listen to the audio output of each computer on a single set of speakers ● B004-DUA2-HR-K features additional audio jacks for use with 7.1 channel surround-sound ● An additional set of console audio jacks are conveniently located on the front panel of the KVM switch, making them ideal for use with IP phones ● The KVM, USB and Audio can be switched independently of each other ● Features mouse port switching functionality*, which allows users accessing the KVM switch with a scroll mouse to switch between ports by double-clicking the mouse’s scroll wheel ● Switch between connected computers via front panel pushbuttons, keyboard hotkeys, and the mouse switching function* ● Auto Scan mode allows you to scan the connected computers without having to manually switch between them ● Supports both analog and digital video signals, allowing for the connection of a VGA computer and/or monitor with a DVI to VGA adapter ● Supports digital video resolutions up to 2560 x 1600 and analog video resolutions up to 2048 x 1536 ● Multi-platform support – Compatible with Windows, Mac, Sun and Linux ● Supports hot-plugging – Computers and devices can be unplugged and re-plugged without having to shut down the KVM switch ● The KVM switch stores the monitor’s EDID (Extended Display Identification Data) to optimize display resolution ● LEDs provide for easy monitoring of connected computers ● Power-On-Detection recognizes when a connected computer has been powered-off and automatically switches to the next powered-on computer ● HDCP compliant 1/4 ● B004-DUA2-HR-K KVM Switch ● (x2) 6-ft. (1.83 m) USB KVM Cable Kits ● (x2) 6-ft. (1.83 m) 7.1 Surround Sound Cables ● External Power Supply with NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.5A Output: 5.3V, 2.4A) ● Owner's Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Console mouse port emulation/bypass feature supports most mouse drivers and multifunction mice ● Console keyboard port emulation/bypass feature supports most gaming/multimedia keyboards ● Complete keyboard emulation for error-free booting ● Multilingual keyboard mapping – supports English, Japanese, and French keyboards ● Quick installation without the need for software ● Sun/Mac keyboard support and emulation** ● Firmware upgradeable ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332183033 Max CPU 2 Technology USB 2.0 (High Speed); DVI; Stereo Audio VIDEO Max Supported Video Resolution 2560 X 1600 @60Hz (DIGITAL), 2048 X 1536 @60Hz (ANALOG) POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.5A External Power Supply Output Specs (V / A) 5.3V / 2.4A External Power Supply Cord Length (ft.) 5 External Power Supply Cord Length (m.) 1.5 AC Adapter Input: 100-240V, 50/60Hz, 0.5A Output: 5.3V, 2.4A USER INTERFACE, ALERTS & CONTROLS LED Indicators Online (Orange), USB Link (Green) PHYSICAL Color Black Cable Jacket Color Black 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / in.) 8.30 x 12.80 x 3.90 Shipping Dimensions (hwd / cm) 21.08 x 32.51 x 9.91 Shipping Weight (lbs.) 4.59 Shipping Weight (kg) 2.08 Unit Dimensions (hwd / in.) 2.200 x 10.600 x 3.500 Unit Weight (lbs.) 2.4 Unit Weight (kg) 1.09 ENVIRONMENTAL Operating Temperature Range 32 to 122°F Storage Temperature Range -4 to 140°F Relative Humidity 0 to 80% RH, Non-Condensing BTUs 17.07 BTU/Hr COMMUNICATIONS Port Control Push Buttons, Hotkeys, OSD Mouse Switching IP Remote Access No CONNECTIONS Number of Ports 2 PC/Server Connections DVI; USB Side A - Connector 1 (2) DVI-I DUAL LINK (FEMALE) Side A - Connector 2 (2) USB B (FEMALE) Side A - Connector 3 (12) 3.5MM (FEMALE) Side B - Connector 1 (1) DVI-I DUAL LINK (FEMALE) Side B - Connector 2 (8) 3.5MM (FEMALE) Side B - Connector 3 (4) USB A (FEMALE) FEATURES & SPECIFICATIONS Autoscan (Y,N) Y Autoscan Duration (1-99 SECONDS) Number of Users 1 NIAP-Certified Secure No USB Specification USB 2.0 (up to 480 Mbps) Cat5 KVM Switch No STANDARDS & COMPLIANCE 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States External Power Supply Certifications BSMI; FCC; PSE; RoHS; UL; cUL Product Compliance RoHS; CE (Europe); FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B004-DUA2-HR-K 价格&库存
很抱歉,暂时无法提供与“B004-DUA2-HR-K”相匹配的价格&库存,您可以联系我们找货
