B004-008
B004-008
    TRIPPLITE
    SWITCH KVM 8 PORT 1U RACK MT PS2
B004-008 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 8-Port 1U Rack-Mount KVM Switch, PS/2 MODEL NUMBER: B004-008 Highlights ● Low Cost Switching Solution ● Does not require software or complicated setup simply Plug and Play ● Ultra-Compact – occupies only 1U rack space System Requirements ● PS/2 mouse ● PS/2 keyboard ● Computer with PS/2 mouse and keyboard ports or an available USB port ● 1 P750-Series PS/2 KVM cable kit per PS/2 computer; or, 1 P750-Series PS/2 KVM cable kit and 1 B015-000 PS/2 to USB adapter per USB computer ● Compatible with all major operating systems Description Tripp Lite's B004-008, 8-Port KVM Switch, is a low-cost solution for IT managers needing a KVM switch Package Includes ● 8 Port KVM Switch (Rackmount Ready) ● Optional AC Power Adapter (Input: 100-240V, 50/60Hz, 0.5A Output: 9V/1.44A) ● Manual for up to 8 CPU's. Use on a desktop or in the rack; comes with 19" rackmount hardware. This switch provides two convenient methods to access any PC connected to the unit: Port Selection buttons located on the front panel, or, Hot-Key commands from the keyboard. A powerful Quick View Scan Mode feature allows you to auto-scan and monitor the activities of all installed operating PC's, one-by-one. Choose from three different cable lengths to connect from the switch to the CPU: P750-006, P750-010, or P750-015. (For computers with USB keyboard and mouse inputs, use Tripp Lite B015-000, PS/2 to USB converter, in conjunction with the P750 cable kit). For a more feature rich 8-port KVM switch, with On Screen Display (OSD) menu functions, as well as expandability, see Tripp Lite B042-008. Constructed of heavy-duty steel housing. Features ● Control up to 8 PC's from a single console ● No software required - Switch between ports via front panel push buttons or hotkey commands ● Quick View Scan Mode for monitoring selected PC's ● PS/2 and Serial Mouse emulation provided for system boot-up ● Microsoft Intellimouse Pro, Logitech FirstMouse, FirstMouse+ support ● SVGA, VGA, and MultiSync monitor support ● Push Button LED display for easy status monitoring ● Rack mountable in 19" system rack - mounting hardware included with switch ● Hot Pluggable - add or remove PC's without powering down the switch ● Compatible with all major operating systems ● Superior Video Quality: 1920x1440; DDC2B ● Constructed of heavy-duty steel housing ● 19"W x 6"D x 1.75"H - 6.25lbs 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332125323 Console No Max CPU 8 Technology PS/2; VGA/SVGA POWER AC Adapter (Input: 100-240V, 50/60Hz, 0.5A Output: 9V/1.44A) PHYSICAL Color Black Shipping Dimensions (hwd / in.) 4.25 x 21.75 x 11.50 Shipping Dimensions (hwd / cm) 10.80 x 55.24 x 29.21 Shipping Weight (lbs.) 6.80 Shipping Weight (kg) 3.08 Unit Dimensions (hwd / in.) 3.900 x 21.700 x 11.400 Unit Dimensions (hwd / cm) 4.45 x 48.26 x 15.24 Unit Weight (lbs.) 6.25 Unit Weight (kg) 2.83 COMMUNICATIONS Port Control Push Buttons, Hotkeys IP Remote Access Yes CONNECTIONS Number of Ports 8 PC/Server Connections VGA; USB; PS/2 FEATURES & SPECIFICATIONS Number of Users 1 NIAP-Certified Secure No Cat5 KVM Switch No WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
B004-008 价格&库存
很抱歉,暂时无法提供与“B004-008”相匹配的价格&库存,您可以联系我们找货
