B078-101-USB2
B078-101-USB2
    TRIPPLITE
    MODULEINTERFACEUSBCAT5E
B078-101-USB2 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States To ensure proper functionality, shielded Cat5e/6 cable must be used with the B078-101-USB2 NetCommander USB Server Interface Unit (SIU) with Virtual Media up to 12Mbps MODEL NUMBER: B078-101-USB2 Highlights ● Needed to connect a USB Server to a NetCommander Cat5 IP KVM switch, with virtual media support ● Supports virtual media data transfer rates up to 12Mbps ● Easy to install; no software needed ● No power supply required ● Allows a maximum distance of 100ft from KVM to computer/server via Shielded Cat5e/6 cable ● Package includes a 5-ft. (1.52 m) Cat5e Shielded Patch Cable' ● Fast Virtual Media KVM System patented under Pat. No. US 9,417,720 ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases System Requirements Description The Tripp Lite NetCommander USB Server Interface Unit (SIU) with Virtual Media support connects to the HD15 port and USB ports on a computer/server, and converts them to a single RJ45 connector. Shielded Cat5e/6 patch cable can then be used to connect the server to the switch ports on a Tripp Lite NetCommander Cat5 IP KVM switch. A 5-ft. (1.52 m) Cat5e Shielded patch cable is included with the product. Supports Virtual Media, with data transfer rates up to 12Mbps. Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. Features ● Needed to connect a USB Server to a NetCommander Cat5 IP KVM switch, with virtual media support ● Supports virtual media data transfer rates up to 12Mbps ● Easy to install; no software needed ● No power supply required ● Allows a maximum distance of 100-ft. (30.5 m) from KVM to computer/server via Shielded Cat5e/6 cable ● Package includes a 5-ft. (1.52 m) Cat5e Shielded Patch Cable ● To convert DisplayPort or HDMI computers to VGA, use Tripp Lite adapters P134-06N-VGA-V2 or P131-06N ● Fast Virtual Media KVM System patented under Pat. No. US 9,417,720 ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332180025 Accessory Type Server Interface Unit 1/3 ● Server or CPU with a HD15 port and (x2) USB ports ● NetCommander Cat5 IP KVM Switch (Note: Not compatible with all NetCommander Cat5 IP KVM switches. Contact Tripp Lite Technical Support for information on your model) ● To ensure proper functionality, shielded Cat5e/6 cable must be used with the B078-101-USB2 ● To convert DisplayPort or HDMI computers to VGA, use Tripp Lite adapters P134-06N-VGAV2 or P131-06N Package Includes ● B078-101-USB2 USB Server Interface Unit with Virtual Media Support ● 5-ft. (1.52 m) Cat5e Shielded Patch Cable 1000 Eaton Boulevard Cleveland, OH 44122 United States Technology Cat5/5e; VGA/SVGA Accessory Class KVM Switch Accessories INPUT Bus Powered Yes Product Length (ft.) 1.3 USER INTERFACE, ALERTS & CONTROLS LED Indicators GREEN (RECEIVING POWER), ORANGE (SELECTED AS ACTIVE PORT) PHYSICAL Color Black Material of Construction ABS Shipping Dimensions (hwd / in.) 1.50 x 7.00 x 10.00 Shipping Dimensions (hwd / cm) 3.81 x 17.78 x 25.40 Shipping Weight (lbs.) 0.45 Shipping Weight (kg) 0.20 Unit Packaging Type Polybag Unit Weight (lbs.) 0.24 Unit Weight (kg) 0.11 CONNECTIONS Side A - Connector 1 HD15 (MALE) Side A - Connector 2 (2) USB A (MALE) Side B - Connector 1 RJ45 (FEMALE) Computer Keyboard and Mouse Interface USB Computer Monitor Interface VGA FEATURES & SPECIFICATIONS Driver Required No Recommended Category Cable N105 - SERIES CAT5E SHIELDED CABLES IP68 Rated No IP20 Rated No REMOTE ACCESS Virtual Media Speed Up to 12 Mbps 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States STANDARDS & COMPLIANCE Product Certifications EN 55022; EN 55024 Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
B078-101-USB2 价格&库存
很抱歉,暂时无法提供与“B078-101-USB2”相匹配的价格&库存,您可以联系我们找货
