B006-VU4-R
B006-VU4-R
    TRIPPLITE
    4-PORT DESKTOP KVM SWITCH (USB)
B006-VU4-R 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 4-Port Desktop KVM Switch (USB) Highlights ● Control up to 4 USB computers from a single VGA monitor and USB keyboard/mouse ● Switch between connected computers via pushbuttons or hotkey commands ● Auto Scan Mode allows monitoring of connected computers without manually switching between them ● Compatible with all major operating systems ● Supports video resolutions up to 2048 x 1536, DDC2B MODEL NUMBER: B006-VU4-R Package Includes ● B006-VU4-R 4-port USB KVM Switch ● External Power Supply with NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.5A / Output: 5.3V, 2.4A ) ● Owner's manual Description Tripp Lite's 4-port Desktop USB KVM Switch is the optimal solution for controlling up to 4 USB computers from one VGA monitor and USB keyboard/mouse. Manually switch between connected computers using pushbuttons or hotkey controls; or, monitor connected computers automatically via Auto Scan Mode. The B006-VU4-R is operating system independent, and works with all computers that have an available VGA and USB port. It supports video resolutions up to 2048 x 1536, and features a compact design that does not require software or complicated set-up procedures. Constructed of heavy-duty steel housing. Order P758 Cables separately. Features ● Control up to 4 USB computers from a single VGA monitor and USB keyboard/mouse ● Order P758 Cables separately ● Port LEDs illuminate Dim Orange to indicate a computer is connected, and Bright Orange to indicate it is the selected port ● Supports video resolutions up to 2048 x 1536, DDC2B ● No software or complicated set-up procedures required ● Manually switch between connected computers via front panel pushbuttons or hotkey commands ● Automatically monitor connected computers via Auto Scan Mode ● Compatible with all major operating systems ● Compatible with most mice; including scroll mice ● Constructed of heavy-duty steel housing Specifications OVERVIEW UPC Code 037332152947 Console No Max CPU 4 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Technology VGA/SVGA VIDEO Max Supported Video Resolution 2048 X 1536, DDC2B POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.5A External Power Supply Output Specs (V / A) 5.3V / 2.4A External Power Supply Cord Length (ft.) 5 External Power Supply Cord Length (m.) 1.5 USER INTERFACE, ALERTS & CONTROLS LED Indicators Online Selected (Orange) PHYSICAL LCD Monitor (cm) Not Applicable Shipping Dimensions (hwd / in.) 3.50 x 9.80 x 8.70 Shipping Dimensions (hwd / cm) 8.89 x 24.89 x 22.10 Shipping Weight (lbs.) 2.20 Shipping Weight (kg) 1.00 Unit Dimensions (hwd / in.) 1.700 x 7.900 x 2.900 Unit Dimensions (hwd / cm) 4.32 x 20.07 x 7.37 Unit Weight (lbs.) 1.50 Unit Weight (kg) 0.68 ENVIRONMENTAL BTUs 7.1694 BTU/Hr COMMUNICATIONS Port Control Push Buttons, Hotkeys IP Remote Access No CONNECTIONS Number of Ports 4 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States PC/Server Connections USB; VGA Side A - Connector 1 (4) HD15 (MALE) Side A - Connector 2 (4) USB B (FEMALE) Side B - Connector 1 (1) HD15 (FEMALE) Side B - Connector 2 (2) USB A (FEMALE) Computer Keyboard and Mouse Interface USB Computer Monitor Interface VGA Console Keyboard and Mouse Interface USB Console Monitor Interface VGA FEATURES & SPECIFICATIONS Autoscan (Y,N) Y Autoscan Duration 11 TO 99 SECONDS; USER-DEFINEABLE Number of Users 1 NIAP-Certified Secure No USB Specification USB 2.0 (up to 480 Mbps) Cat5 KVM Switch No WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
B006-VU4-R 价格&库存
很抱歉,暂时无法提供与“B006-VU4-R”相匹配的价格&库存,您可以联系我们找货
