B072-016-1A
B072-016-1A
    TRIPPLITE
    SWITCHKVM16PORTCAT5E1U
B072-016-1A 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States NetCommander 16-Port Cat5 KVM Switch 1U Rack-Mount with PS2 to USB Input Adapter MODEL NUMBER: B072-016-1A Highlights ● 16 RJ45 Ports utilize inexpensive Cat5 patch cables ● Expandable - Cascade a second level of KVM switches to control up to 256 servers from a single station ● Accepts PS2 or USB Mouse and Keyboards with included Adapter System Requirements ● Computers: The Tripp Lite B078-101-USB-1 Server Interface Module must be used to connect a server to the server ports on the KVM switch. ● For computers with Displayport or HDMI, change to VGA using Tripp Lite adapters P134-06NVGA-V2 or P131-06N. Maximum video resolutions using adapters may vary. ● Compatible with all major operating systems Features ● Expandable - Cascade a second level of KVM switches to control up to 256 servers from a single station ● Extend distance: between computer and switch up to 30 meters/100 ft. ● ● Package Includes ● 16-Port NetCommander 1U Rackmount Cat5 KVM Switch Rack mountable: sleek, 1U space saving KVM switches ● PS2 to USB Adapter Accepts PS2 Mouse and Keyboard ( or USB Mouse and Keyboard with included adapter ) ● 6-ft. (1.83 m) Power Cord ● Innovative CAT5 technology: eliminate cable clutter at the rack ● ● Multi-layer security: protects your corporate data 6-ft. (1.83 m) Firmware Upgrade Cable ● Easy server management: choice of On Screen Display, Hot-key,or push button control ● Rackmount Bracket kit ● Multi-platform: PS/2 and USB support ● To convert DisplayPort or HDMI computers to VGA, use Tripp Lite adapters P134-06N-VGA-V2 or P131-06N. Maximum video resolutions using adapters may vary. ● Easily add IP functionality with Tripp Lite Model B051-000 ● Add Tripp Lite Model B021-000-19 for space saving, in-the-rack, LCD, Keyboard and Mouse ● Compact Size: 17"W x 5"D x 1.75"H ● Video Resolution: 1600x1200@75Hz ● Internal Power Supply ● Compatible with all major operating systems ● Constructed of heavy-duty steel housing Specifications OVERVIEW UPC Code 037332186607 Max CPU 256 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Technology Cat5/5e; PS/2; VGA/SVGA VIDEO Max Supported Video Resolution 1600 X 1200 @ 75 Hz Max. Distance (Between any 2 Units) 100 ft (30.5m) Max Number of Ports (Entire Chain) 256 INPUT Voltage Compatibility (VAC) 100; 110; 120; 127; 200; 208; 220; 230; 240 Input Frequency 50/60Hz Input Current 120V (0.7A) / 230V (0.3A) Power Input Receptacle IEC-320-C14 POWER Power Consumption (Watts) 8 USER INTERFACE, ALERTS & CONTROLS LED Indicators Green(CPU ON, SELECTED) PHYSICAL Color Black Material of Construction Steel (Steel, Electrogalvanized, Cold Rolled, Coil) Rackmountable Yes Shipping Dimensions (hwd / in.) 4.33 x 20.28 x 7.68 Shipping Dimensions (hwd / cm) 11.00 x 51.51 x 19.51 Shipping Weight (lbs.) 5.45 Shipping Weight (kg) 2.47 Unit Dimensions (hwd / in.) 1.710 x 16.780 x 4.770 Unit Packaging Type Box Unit Weight (lbs.) 3.70 Unit Weight (kg) 1.68 ENVIRONMENTAL Operating Temperature Range 32 to 104 F (0 to 40 C) Storage Temperature Range -40 to 158 F (-40 to 70 C) Relative Humidity 0% to 80% RH, Non-Condensing BTUs 27.3 BTU/Hr 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States COMMUNICATIONS IP Remote Access No CONNECTIONS Number of Ports 16 PC/Server Connections PS/2; USB; VGA Side A - Connector 1 HD15 (FEMALE) Side A - Connector 2 (2) MINI DIN-6 (FEMALE) Side A - Connector 3 RJ11 (FEMALE) Side B - Connector 1 (16) RJ45 (FEMALE) Computer Keyboard and Mouse Interface PS/2; USB Computer Monitor Interface VGA Console Keyboard and Mouse Interface PS/2; USB Console Monitor Interface VGA PORT EXPANSION Daisy-chainable or Cascadable Cascadeable FEATURES & SPECIFICATIONS Number of Users 1 NIAP-Certified Secure No On-Screen Display (OSD) Yes Port Selection Pushbutton; Hotkey; OSD Driver Required No Cat5 KVM Switch Yes Recommended Category Cable Cat5e/6 Cables STANDARDS & COMPLIANCE Product Certifications CAN/CSA C22.2; CAN/CSA-C22.2 No. 60950-1 (Canada); UL 60950-1 Product Compliance RoHS; CE (Europe); REACH; FCC Part 15 Class A (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B072-016-1A 价格&库存
很抱歉,暂时无法提供与“B072-016-1A”相匹配的价格&库存,您可以联系我们找货
