B004-VUA2-K-R
B004-VUA2-K-R
    TRIPPLITE
    KVM SWITCH USB W AUDIO & CABLES
B004-VUA2-K-R 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 2-Port Compact USB KVM Switch with Audio and Cable MODEL NUMBER: B004-VUA2-K-R Highlights ● Fast, easy switching via keyboard hot keys, push buttons or software (not required) ● PC and Mac compatible ● Allows sharing of audio components between systems; listen to music from one computer while switching to the other computer ● Compact design saves desk space ● No AC adapter required ● (x2) 6-ft. (1.83 m) USB KVM Cable kits and (x2) 6-ft. (1.83 m) 3.5mm Audio Cable kits included ● Compatible with all major operating systems System Requirements ● Console: VGA, SVGA or Multisync Monitor, USB Keyboard and USB Mouse ● Computers: VGA, SVGA or Multisync Monitor Port and USB Port ● Audio (Optional): Speakers with standard 3.5 mm Connectors and a computer with 3.5mm ports ● Compatible with all major operating systems 2-port Compact USB KVM Switch with optional audio and microphone switching function allows you to access control boot and reboot two USB-enabled computers from a single keyboard monitor and mouse Features ● Fast, easy switching via keyboard hot keys, push buttons or software ● Plug-and-play setup - no software required ● Hot-swap capability allows easy addition or removal of computers without powering down the switch or other computers ● Speaker and microphone connections allow sharing of audio components between systems (standard 3.5 mm audio connections) ● Independent audio switching allows you to listen to audio from one computer while switching to the other computer ● Supports video resolutions up to 2048 x 1536 (standard 15-pin VGA connectors) ● Supports Microsoft® IntelliMouse® and the scrolling wheel on most mice] ● Compact design saves desk space ● Does not require an AC adapter ● Compatible with all major operating systems ● Includes two, 6-ft. (1.83 m) Cable Kits Specifications OVERVIEW UPC Code 037332140043 Product Type KVM 1/4 Package Includes ● Compact 2-port USB KVM Switch with Audio ● (2) 6-ft. (1.83 m) USB KVM Cable Kits and (2) 6-ft. (1.83 m) 3.5mm Audio Cable Kits ● CD-ROM with KVM Switcher Software ● Owner's Manual with Warranty Information 1000 Eaton Boulevard Cleveland, OH 44122 United States Console No Max CPU 1 Technology VGA/SVGA; Stereo Audio Host Connector (2) USB A (FEMALE) VIDEO Video Input HD15 (FEMALE) Video Output HD15 (FEMALE) Number of Monitors Supported 1 Video Ports (3) HD15 (FEMALE) Max Supported Video Resolution 2048 x 1536 @60Hz AUDIO Audio Ports (2) 3.5MM (FEMALE) Audio Ports Details Connect a microphone and speaker via the dual 3.5mm audio ports Audio Input 3.5mm Audio Output Audio Audio Specification Stereo Audio DATA Data Ports (2) USB A (FEMALE) Data Ports Details (2) USB-A - USB 2.0 INPUT Bus Powered Yes Power Source Bus; USB POWER Power Consumption (Watts) 0.5 USER INTERFACE, ALERTS & CONTROLS LED Indicators Green (Selected PC) PHYSICAL Color Black Material of Construction ABS Cable Jacket Color Black Total Number of Ports 9 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / in.) 3.00 x 7.90 x 7.80 Shipping Dimensions (hwd / cm) 7.62 x 20.07 x 19.81 Shipping Weight (lbs.) 1.80 Shipping Weight (kg) 0.82 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Packaging Type Box Unit Weight (lbs.) 0.22 Unit Weight (kg) 0.10 ENVIRONMENTAL Operating Temperature Range 32 to 104 F (0 to 40 C) Storage Temperature Range -4 to 140 F (-20 to 60 C) Relative Humidity 0%-90% RH, Non-Condensing BTUs 1.7 BTU/Hr ESD Protection Yes COMMUNICATIONS Hotkey Yes IP Remote Access No EDID Compatible Yes IR Remote Extension Support No CONNECTIONS Number of Ports 2 Daisy-Chain Port No Firmware Upgrade Port No PC/Server Connections USB; VGA Side A - Connector 1 (2) HD15 (FEMALE) Side B - Connector 1 HD15 (FEMALE) Side B - Connector 2 (2) USB A (FEMALE) Side B - Connector 3 (2) 3.5MM (FEMALE) Side B - Connector 4 (2) USB MINI-B 5-PIN (FEMALE) Included Cable (Side A) - Connector 1 Yes Computer Keyboard and Mouse Interface USB Computer Monitor Interface VGA 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Console Keyboard and Mouse Interface USB Console Monitor Interface VGA Connector Plating Nickel FEATURES & SPECIFICATIONS Autoscan (Y,N) Y Autoscan Duration 10 - 60 seconds Number of Users 1 NIAP-Certified Secure No On-Screen Display (OSD) No Port Selection Pushbutton; Hotkey; Software USB Hub Ports Yes USB Specification USB 2.0 (up to 480 Mbps) Driver Required No Cat5 KVM Switch No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B004-VUA2-K-R 价格&库存
很抱歉,暂时无法提供与“B004-VUA2-K-R”相匹配的价格&库存,您可以联系我们找货
