1000 Eaton Boulevard
Cleveland, OH 44122
United States
4-Port 1U Rack-Mount USB/PS2 KVM Switch with
On-Screen Display
MODEL NUMBER: B042-004
Highlights
NetController 4-Port, 1U
rackmount KVM switch
Control 4 computers via a single
VGA monitor and USB or PS/2
keyboard/mouse
Control up to 244 computers by
daisychaining up to 15
additional B042-Series KVM
switches
P780-Series USB/PS2 combo
KVM cables (purchased
separately) allow you to connect
either USB or PS/2 computers
Compatible with all major
operating systems
System Requirements
Description
Tripp Lite's NetController 4-Port, 1U rackmount KVM Switch is an affordable, highly-flexible enterprise
class KVM Switch, which allows the user to connect either USB or PS/2 keyboards and mice. In addition,
P780-Series USB/PS2 combo KVM cable kits allow you to connect either USB or PS/2 computers, without
the need to purchase separate cables or adapters. Control up to 4 directly connected computers, or
expand the number of connected computers to up to 244 by daisychaining up to 15 additional B042Series KVM switches. Switch between connected computers via the On-Screen Display (OSD),
pushbuttons, or keyboard hotkey commands. Other features include: password protection, auto-scanning,
auto-logout, firmware upgrade and video support up to 2048 x 1536 (QXGA). Mounts easily in a standard
19" rack/cabinet and includes all necessary mounting hardware. Compatible with all major operating
systems. Constructed of heavy-duty steel housing.
Features
Hardware Versions
A new hardware version (v2) of the
B042-004 was released in 2019,
requiring different firmware from
the previous version (v1). The
Support tab of this page includes a
zip folder for v2. Along with the
applicable firmware, it contains an
FW Notes file to help you
determine which hardware version
you have and which firmware to
use. The current firmware comes
pre-installed on all v2 models. If
you have a hardware version (v1)
KVM, consult Technical Support for
the applicable firmware.
Note: *When daisy-chaining KVM
switches together and problems
are experienced, confirm switches
have the same hardware version. If
firmware is not up to date, you may
need to upgrade the firmware of
your unit(s).*
NetController 4-Port, 1U rackmount KVM switch
Control 4 computers via a single VGA monitor and USB or PS/2 keyboard/mouse
without the need to purchase separate cables or adapters
Control up to 244 computers by daisychaining up to 15 additional B042-Series KVM switches
Allows for easy customization of ports by daisy-chaing any combination of B042-Series KVM's (4-, 8- or
16-port)
B042-004 NetController 4-Port,
Standard 19" Rackmount size - hardware included
On-Screen Display (OSD) menu for intuitive operation and easy control
External Power Supply with
NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.3A / Output:
9V, 1A)
Switch between connected computers via the On-Screen Display (OSD), pushbuttons, or keyboard
hotkey commands
Rackmount hardware
8 In. Daisychain cable ( for
longer daisy-chain cables, see
Tripp Lite P781 series cables)
Package Includes
Supports video resolution up to 2048 x 1536
Password protection and auto-logout features
Firmware upgradeable
Daisychain terminator
Robust metal case design ensures best EMI/RFI shielding and video quality
4 ft. HD15 to DB9 firmware
upgrade cable
Hot-swappable: disconnect and reconnect USB computers without rebooting
CD with owner's manual and
Supports standard 5-button Microsoft, Logitech, or comparable mice
1/4
Cleveland, OH 44122
United States
Supports standard Microsoft, Logitech, or comparable keyboards
Compatible with all major operating systems
quick start guide
Specifications
OVERVIEW
UPC Code
037332143266
Console
No
Max CPU
244
Technology
PS/2; VGA/SVGA
VIDEO
Max Supported Video Resolution
2048 x 1536 @60Hz
Max. Distance (Between any 2
Units)
98ft (30m)
Max Number of Ports (Entire Chain)
244
INPUT
Voltage Compatibility (VAC)
100; 110; 120; 127; 200; 208; 220; 230; 240
POWER
Power Source Type
AC Adapter
External Power Supply Plug(s)
NEMA 1-15P North America
External Power Supply Input Specs
(V / Hz / A)
100-240V / 50/60Hz / 1A
External Power Supply Output
Specs (V / A)
9V / 1.33A
External Power Supply Cord Length
(ft.)
5
(m.)
1.5
AC Adapter
Input: 100-240V, 50/60Hz, 0.3A / Output: 9V, 1.33A
DC Barrel Plug
OD: 5.5 x 2.1 x 9.5mm, Positive Pin, Negative Sleeve
Power Consumption (Watts)
4.9
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
Red (Link); Green (Selected PC)
PHYSICAL
2/4
Quick start guide
Cleveland, OH 44122
United States
Color
Black
Material of Construction
Steel
Rackmountable
Yes
Shipping Dimensions (hwd / in.)
2.80 x 17.30 x 11.50
Shipping Dimensions (hwd / cm)
7.11 x 43.94 x 29.21
Shipping Weight (lbs.)
6.10
Shipping Weight (kg)
2.77
Unit Dimensions (hwd / in.)
1.750 x 19.000 x 6.500
Unit Packaging Type
Box
Unit Weight (lbs.)
4.19
Unit Weight (kg)
1.90
ENVIRONMENTAL
Operating Temperature Range
32 to 104 F (0 to 40 C)
Storage Temperature Range
-4 to 140 F (-20 to 60 C)
Relative Humidity
0%-90% RH, Non-Condensing
BTUs
16.7 BTU/Hr
ESD Protection
Yes
COMMUNICATIONS
Hotkey
Yes
IP Remote Access
No
EDID Compatible
Yes
CONNECTIONS
Number of Ports
4
Daisy-Chain Port
Yes
PC/Server Connections
PS/2; USB; VGA
Side A - Connector 1
(4) HD15 (FEMALE)
Side B - Connector 1
(2) HD15 (FEMALE)
Side B - Connector 2
HD15 (MALE)
Side B - Connector 3
(2) USB A (FEMALE)
Side B - Connector 4
(2) MINI DIN-6 (FEMALE)
Included Cable (Side A) - Connector
1
No
Computer Keyboard and Mouse
Interface
PS/2; USB
3/4
Cleveland, OH 44122
United States
Computer Monitor Interface
VGA
Console Keyboard and Mouse
Interface
PS/2; USB
Console Monitor Interface
VGA
Connector Plating
Nickel
PORT EXPANSION
Daisy-chainable or Cascadable
Daisychainable
FEATURES & SPECIFICATIONS
Number of Users
1
NIAP-Certified Secure
No
Yes
Port Selection
Pushbutton; Hotkey; OSD
Driver Required
No
Cat5 KVM Switch
No
STANDARDS & COMPLIANCE
External Power Supply Certifications
CB; FCC; TUV; UL; cUL
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“B042-004”相匹配的价格&库存,您可以联系我们找货
