B020-008-17
B020-008-17
    TRIPPLITE
    SWITCH KVM 8PORT 1U W/LCD PS/2
B020-008-17 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States NetDirector 8-Port 1U Rack-Mount Console KVM Switch with 17-in. LCD MODEL NUMBER: B020-008-17 Highlights ● Occupies just 1U of space in a rack-mountable drawer ● 17” LCD screen supports video resolutions up to 1280 x 1024 ● Simplifies IT tasks with easy switching between all 8 ports ● Provides 2-level password security (administrator and user) ● Compatible with all operating systems System Requirements Control up to 8 computers with a single KVM switch with integrated console. This KVM switch is a smart solution for secure and centralized server control that saves rack space and money. Features ● PS/2 or USB computer ● (1) P774-Series (PS/2) or P776Series (USB) KVM Cable Kit is required for each connected computer/server ● Compatible with all major operating systems (special keys on Mac and Sun keyboards are supported) ● Power consumption: 120V, 60Hz, 22.8W; 230V, 50Hz, 24W Package Includes Saves Valuable Space and Money ● Combines an 8-port KVM switch, 17" LCD screen, full keyboard and touchpad in a 1U rack-mountable drawer ● B020-008-17 8-Port Console KVM Switch with 17" LCD ● P774-Series 6 ft. PS/2 KVM Cable Kit ● Mounts into 19”-wide rack, 24”-37” deep ● Gives you control of up to 8 computers/servers from a single, easily accessible console – ideal when rack space is at a premium ● P776-Series 6-ft. (1.83 m) USB KVM Cable Kit ● Flip-up/fold-down screen keeps the console from blocking access to rack equipment when not in use ● C13 to 5-15P power cord ● Eliminates need to buy costly separate monitors, keyboards and mice for each computer/server ● RJ11 to DB9 firmware upgrade cable ● Owner's Manual CD Simplifies IT Tasks ● Switch quickly and easily between the 8 ports via on-console buttons, on-screen display or keyboard hot key commands ● Hot pluggable; add or remove computers without having to power down the switch ● Auto-scan mode automatically sequences through all active ports that are accessible to the user Large 17” LCD ● Wide display makes multitasking easier ● Supports video resolutions up to 1280 x 1024 ● DDC emulation allows the video settings of each computer to be automatically adjusted for optimal output to the LCD Multi-Level Password Security ● Enhances security by limiting access to an administrator and up to 4 local users ● Two-level log-out allows for manual log-out or automatic log-out after a user-defined period of time has passed 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Expandability and Long-Lasting Reliability ● Increase the number of connected computers to up to 256 by daisy-chaining up to 31 B022-U08 KVM switches ● Includes additional HD15 VGA monitor port and PS/2 keyboard/mouse ports for connecting an external console or a Tripp Lite B051-000 IP Remote Access Unit ● Compatible with all major operating systems for easy integration into your existing structure (special keys on Mac and Sun keyboards are not supported) ● Firmware is easily upgradable with included cable and utility ● Heavy-duty steel housing stands up to frequent use Specifications OVERVIEW UPC Code 037332125385 Console Yes Max CPU 8 Technology PS/2; VGA/SVGA VIDEO Max Supported Video Resolution 1280 x 1024 @60Hz INPUT Nominal Input Voltage(s) Supported 100V AC; 110V AC; 115V AC; 120V AC; 127V AC; 140V AC; 200V AC; 208V AC; 220V AC; 230V AC; 240V AC Input Frequency 50/60Hz Input Current 120V (0.8A) / 230V (0.4A) POWER Power Consumption (Watts) 22.80 Power Consumption Detail (22.8W at 120V, 60Hz) / (24W at 230V, 50Hz) PHYSICAL Color Black LCD Monitor (cm) 43.18 LCD Monitor (in.) 17 Shipping Dimensions (hwd / in.) 5.40 x 26.75 x 28.25 Shipping Dimensions (hwd / cm) 13.72 x 67.94 x 71.76 Shipping Weight (lbs.) 38.80 Shipping Weight (kg) 17.60 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Dimensions (hwd / in.) 1.750 x 17.000 x 24.000 Unit Dimensions (hwd / cm) 4.45 x 42.55 x 60.96 ENVIRONMENTAL Relative Humidity 0% TO 80% RH Operating Temperature 32 DEGREES TO 120 DEGREES F BTUs 76.1 BTUs at 120V, 50Hz or 83.98 BTUs at 230V, 50Hz COMMUNICATIONS Port Control Push Buttons, Hotkeys, OSD IP Remote Access No CONNECTIONS Number of Ports 8 Computer/Server Ports (x8) HD15 (Female) PC/Server Connections PS/2; USB; VGA Side A - Connector 1 (8) HD15 (FEMALE) Side B - Connector 1 (2) 6 PIN (FEMALE); (1) HD15 (FEMALE); (1) RJ11 (FEMALE) FEATURES & SPECIFICATIONS Autoscan (Y,N) Y Autoscan Duration 1-255 Seconds Number of Users 1 NIAP-Certified Secure No Cat5 KVM Switch No STANDARDS & COMPLIANCE Product Certifications CAN/CSA C22.2; CAN/CSA-C22.2 No. 60950-1 (Canada); UL 60950-1 Product Compliance RoHS; CE (Europe); FCC Part 15 Class A (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B020-008-17 价格&库存
很抱歉,暂时无法提供与“B020-008-17”相匹配的价格&库存,您可以联系我们找货
