B042-016
B042-016
    TRIPPLITE
    NETCONTROLLERKVMSWITCH16PORT
B042-016 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Compatible with B040/42-Series KVM's only. Cannot be daisy-chained to other KVM series. 16-Port 1U Rack-Mount USB/PS2 KVM Switch with On-Screen Display Highlights ● NetController 16-Port, 1U rackmount KVM switch ● Control 16 computers via a single VGA monitor and USB or PS/2 keyboard/mouse ● Control up to 256 computers by daisychaining up to 15 additional B040/42-Series KVM switches (Compatible with B040/42-Series KVM's only. Cannot be daisychained to other KVM series) ● P780-Series USB/PS2 combo KVM cables kits allow you to connect either USB or PS/2 computers, without the need to purchase separate cables or adapters ● Compatible with all major operating systems MODEL NUMBER: B042-016 System Requirements Description Tripp Lite's NetController 16-Port, 1U rackmount KVM Switch is an affordable, highly-flexible enterprise class KVM Switch, which allows the user to connect either USB or PS/2 keyboards and mice. In addition, P780-Series USB/PS2 combo KVM cable kits allow you to connect either USB or PS/2 computers, without the need to purchase separate cables or adapters. Control up to 16 directly connected computers, or expand the number of connected computers to up to 256 by daisychaining up to 15 additional B040/42Series KVM switches (Compatible with B040/42-Series KVM's only. Cannot be daisychained to other KVM series) Switch between connected computers via the On-Screen Display (OSD), pushbuttons, or keyboard hotkey commands. Other features include: password protection, auto-scanning, auto-logout, firmware upgrade and video support up to 2048 x 1536 (QXGA). Mounts easily in a standard 19" rack/cabinet and includes all necessary mounting hardware. Compatible with all major operating systems. Constructed of heavy-duty steel housing. Features ● NetController 16-Port, 1U rackmount KVM switch ● Control 16 computers via a single VGA monitor and USB or PS/2 keyboard/mouse ● P780-Series USB/PS2 combo KVM cable kits allow you to connect either USB or PS/2 computers, without the need to purchase separate cables or adapters ● Control up to 256 computers by daisychaining up to 15 additional B040/42-Series KVM switches (Compatible with B040/42-Series KVM's only. Cannot be daisychained to other KVM series) ● Allows for easy customization of ports by daisy-chaing any combination of B042-Series KVM's (4-, 8- or 16-port) ● Standard 19" Rackmount size - hardware included ● On-Screen Display (OSD) menu for intuitive operation and easy control ● Switch between connected computers via the On-Screen Display (OSD), pushbuttons, or keyboard hotkey commands ● ● ● Firmware upgradeable ● Robust metal case design ensures best EMI/RFI shielding and video quality Hardware Versions A new hardware version (v2) of the B042-016 was released in 2019, requiring different firmware from the previous version (v1). The Support tab of this page includes a zip folder for v2. Along with the applicable firmware, it contains an FW Notes file to help you determine which hardware version you have and which firmware to use. The current firmware comes pre-installed on all v2 models. If you have a hardware version (v1) KVM, consult Technical Support for the applicable firmware. Note: *When daisy-chaining (8) or (16) Port KVM switches together and problems are experienced, confirm switches have the same hardware version. If firmware is not up to date, you may need to upgrade the firmware of your unit(s).* Package Includes ● B042-016 NetController 16-Port, 1U rackmount KVM switch ● External Power Supply with NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.3A / Output: 9V, 1A) Supports video resolution up to 2048 x 1536 ● Rackmount hardware Password protection and auto-logout features ● 8 In. Daisychain cable ( for longer daisy-chain cables, see 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Hot-swappable: disconnect and reconnect USB computers without rebooting ● ● ● Compatible with all major operating systems ● Constructed of heavy-duty steel housing Tripp Lite P781 series cables) Supports standard 5-button Microsoft, Logitech, or comparable mice ● Daisychain terminator Supports standard Microsoft, Logitech, or comparable keyboards ● 4 ft. HD15 to DB9 firmware upgrade cable ● CD with owner's manual and quick start guide ● Quick start guide Specifications OVERVIEW UPC Code 037332141408 Console No Max CPU 256 Technology PS/2; VGA/SVGA VIDEO Max Supported Video Resolution 2048 x 1536 @60Hz Max. Distance (Between any 2 Units) 98ft (30m) Max Number of Ports (Entire Chain) 256 INPUT Voltage Compatibility (VAC) 100; 110; 120; 127; 200; 208; 220; 230; 240 Bus Powered No POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 1A External Power Supply Output Specs (V / A) 9V / 1.33A External Power Supply Cord Length (ft.) 5 External Power Supply Cord Length (m.) 1.5 AC Adapter Input: 100-240V, 50/60Hz, 0.3A / Output: 9V, 1.33A DC Barrel Plug OD: 5.5 x 2.1 x 9.5mm, Positive Pin, Negative Sleeve Power Consumption (Watts) 9.7 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States USER INTERFACE, ALERTS & CONTROLS LED Indicators Red (Link); Green (Selected PC) PHYSICAL Color Black Material of Construction Steel Rackmountable Yes Shipping Dimensions (hwd / in.) 2.80 x 11.30 x 17.10 Shipping Dimensions (hwd / cm) 7.11 x 28.70 x 43.43 Shipping Weight (lbs.) 6.50 Shipping Weight (kg) 2.95 Unit Dimensions (hwd / in.) 1.750 x 19.000 x 6.500 Unit Packaging Type Box Unit Weight (lbs.) 4.19 Unit Weight (kg) 1.90 ENVIRONMENTAL Operating Temperature Range 32 to 104 F (0 to 40 C) Storage Temperature Range -4 to 140 F (-20 to 60 C) Relative Humidity 0%-90% RH, Non-Condensing BTUs 33.1 BTU/Hr ESD Protection Yes COMMUNICATIONS Hotkey Yes IP Remote Access No EDID Compatible Yes CONNECTIONS Number of Ports 16 Daisy-Chain Port Yes Firmware Upgrade Port Yes PC/Server Connections PS/2; USB; VGA Side A - Connector 1 (16) HD15 (FEMALE) Side B - Connector 1 (2) HD15 (FEMALE) Side B - Connector 2 HD15 (MALE) 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Side B - Connector 3 (2) MINI DIN-6 (FEMALE) Side B - Connector 4 (2) USB A (FEMALE) Included Cable (Side A) - Connector 1 No Computer Keyboard and Mouse Interface PS/2; USB Computer Monitor Interface VGA Console Keyboard and Mouse Interface PS/2; USB Console Monitor Interface VGA Connector Plating Nickel PORT EXPANSION Daisy-chainable or Cascadable Daisychainable FEATURES & SPECIFICATIONS Autoscan (Y,N) Y Autoscan Duration 10 to 60 seconds Number of Users 1 NIAP-Certified Secure No On-Screen Display (OSD) Yes Port Selection Pushbutton; Hotkey; OSD Driver Required No Cat5 KVM Switch No STANDARDS & COMPLIANCE External Power Supply Certifications FCC; UL; cUL; TUV; CB Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B042-016 价格&库存
很抱歉,暂时无法提供与“B042-016”相匹配的价格&库存,您可以联系我们找货
