B078-101-USB-8
B078-101-USB-8
    TRIPPLITE
    MODULE INTERFACE USB CAT5E
B078-101-USB-8 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States NetCommander USB Server Interface Unit (SIU) 8-Pack MODEL NUMBER: B078-101-USB-8 Highlights ● 8-Pack of B078-101-USB-1 Server Interface Units ● Needed to connect a USB Server to a B070 / B072-Series NetCommander KVM switch via Cat5e cable ● Easy to install; no software needed ● No power supply required ● Allows a recommended maximum distance of 100-ft. (30.5 m) from KVM to computer/server via Cat5e cable ● Compact and lightweight design System Requirements Features ● 8-Pack of B078-101-USB-1 Server Interface Units ● Needed to connect a USB Server to a B070 / B072-Series NetCommander KVM switch via Cat5e cable ● Eliminates the need for thicker, heavier KVM cables ● Compact, lightweight design ● Plug and Play; no software required ● No power supply required ● Allows a Server/CPU to be located up to 100-ft. (30.5 m) away from the KVM switch ● To convert DisplayPort or HDMI computers to VGA, use Tripp Lite adapters P134-06N-VGA-V2 or P131-06N ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases ● Server or CPU with a HD15 port and a USB port ● A B070 / B072-Series NetCommander Cat5 KVM Switch ● Cat5e/6 cable; up to 100ft ● To convert DisplayPort or HDMI computers to VGA, use Tripp Lite adapters P134-06N-VGAV2 or P131-06N Package Includes ● Specifications OVERVIEW UPC Code 037332182470 Accessory Type Server Interface Unit Technology Cat5/5e; VGA/SVGA Accessory Class KVM Switch Accessories INPUT Bus Powered Yes Product Length (ft.) 1.3 1/3 (x8) B078-101-USB-1 USB Server Interface Units (SIU) 1000 Eaton Boulevard Cleveland, OH 44122 United States USER INTERFACE, ALERTS & CONTROLS LED Indicators GREEN (RECEIVING POWER); ORANGE (SELECTED AS ACTIVE PORT) PHYSICAL Color Gray Material of Construction ABS Shipping Dimensions (hwd / in.) 4.50 x 6.00 x 10.30 Shipping Dimensions (hwd / cm) 11.43 x 15.24 x 26.16 Shipping Weight (lbs.) 2.20 Shipping Weight (kg) 1.00 Unit Packaging Type Box Unit Weight (lbs.) 0.18 Unit Weight (kg) 0.08 CONNECTIONS Side A - Connector 1 HD15 (MALE) Side A - Connector 2 USB A (MALE) Side B - Connector 1 RJ45 (FEMALE) Computer Keyboard and Mouse Interface USB Computer Monitor Interface VGA FEATURES & SPECIFICATIONS Driver Required No Recommended Category Cable N105 - SERIES CAT5E SHIELDED CABLES IP68 Rated No IP20 Rated No STANDARDS & COMPLIANCE Product Certifications EN 55022; EN 55024 Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
B078-101-USB-8 价格&库存
很抱歉,暂时无法提供与“B078-101-USB-8”相匹配的价格&库存,您可以联系我们找货
B078-101-USB-8
  • 1+2467.13860
  • 3+2354.97661
  • 6+2252.59466
库存:8
