1000 Eaton Boulevard
Cleveland, OH 44122
United States
8-Port 1U Rack-Mount DVI / USB KVM Switch
with Audio and 2-port USB Hub
MODEL NUMBER: B043-DUA8-SL
Highlights
NetController 8-Port, 1U
rackmount KVM switch
Control 8 computers via a single
DVI monitor and USB
keyboard/mouse
Control up to 64 computers by
cascading up to 8 additional
B043-DUA8-SL KVM switches
Compatible with all major
operating systems
System Requirements
DVI , HDMI*, or VGA** monitor
USB mouse and keyboard
Computer with a DVI or VGA*
port
Computer with a USB port
P759-Series DVI-D/USB/Audfor
each connected computer
Microphone with a 3.5 mm Male
connector (if using the
microphone feature)
Speakers with a 3.5 mm Male
connector (if using the speaker
feature)
operating systems
Description
Tripp Lite's B043-DUA8-SL, NetController 8-Port, 1U rackmount DVI / USB / Audio KVM Switch is an
affordable, highly-flexible enterprise class KVM Switch. Control up to 8 directly connected computers, or
expand the number of connected computers to up to 64, by cascading up to 8 additional B043-DUA8-SL
KVM switches. Switch between connected computers via pushbuttons or keyboard hot-key commands.
Other features include: Audio Support, 2-Port USB Hub for peripheral sharing among switched computers,
and DVI Single Link resolution at 1920x1200. Mounts easily in a standard 19" rack/cabinet and includes
all necessary mounting hardware. Compatible with all major operating systems. Constructed of heavyduty steel housing.
Order P759 Series cables separately, in 6-ft. (1.83 m), 10-ft. (3.05 m), and 15-ft. (4.57 m) lengths.
Features
Package Includes
Directly connect up to 8 computers with DVI, USB, and audio.
Expand the number of connected computers by cascading an additional level of KVM switches.
B043-DUA8-SL KVM Switch
Supports 2.1 Channel Stereo Audio and microphone.
(x2) USB 2.0 ports for sharing peripherals among connected computers.
External Power Supply (Input:
100-240V, 50/60Hz, 0.8A;
Output: 9V, 2A)
USB hub functionality can be unbinded from the KVM, allowing users to access one computer while the
USB hub focus remains on another computer.
Switch between connected computers via pushbuttons or hotkey commands.
International plug adapters
(North America, Europe, U.K.
and Australia)
DVI-I Single-Link supports digital video resolutions up to 1920 x 1200, and analog video resolutions up
to 2048 x 1536.
Rackmount Hardware
Owner’s Manual
Auto Scan mode lets users scan connected computers without having to manually switch between
them.
Multi-platform support – compatible with all major operating systems.
Plug and play setup – no software installation required.
Supports EDID (Extended Display Identification Data) transmission to connected computers for optimal
display performance.
Supports HDMI and VGA monitors with appropriate adapters...see "System Requirements"
Includes mounting hardware for 19” rackmount installations.
Power supply includes international plug adapters (North America, Europe, U.K. and Australia)
1/4
Cleveland, OH 44122
United States
Specifications
OVERVIEW
UPC Code
037332182395
Max CPU
64
Technology
DVI; Stereo Audio; USB 2.0 (High Speed)
VIDEO
Max Supported Video Resolution
1920 x 1200 @60Hz
Max. Distance (Between any 2
Units)
15ft (4.6m)
Max Number of Ports (Entire Chain)
64
AUDIO
Audio Specification
Stereo Audio
INPUT
Voltage Compatibility (VAC)
100; 110; 120; 127; 200; 208; 220; 230; 240
Bus Powered
No
POWER
Power Source Type
AC Adapter
External Power Supply Plug(s)
NEMA 1-15P North America; CEE 7/16 Schuko; BS 1363 UK; AS/NZS 3112 Australia
External Power Supply Input Specs
(V / Hz / A)
100-240V / 50/60Hz / 1A
External Power Supply Output
Specs (V / A)
9V / 2A
External Power Supply Cord Length
(ft.)
5
(m.)
1.5
AC Adapter
Input: 100-240V, 50/60Hz, 0.8A / Output: 9V, 2A
DC Barrel Plug
OD: 5.5 x 2.1 x 9.5mm, Positive Pin, Negative Sleeve
Power Consumption (Watts)
8.7
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
Green (Selected PC)
PHYSICAL
2/4
Cleveland, OH 44122
United States
Color
Black
Material of Construction
Steel
Rackmountable
Yes
Shipping Dimensions (hwd / in.)
2.80 x 17.30 x 11.50
Shipping Dimensions (hwd / cm)
7.11 x 43.94 x 29.21
Shipping Weight (lbs.)
4.90
Shipping Weight (kg)
2.22
Unit Dimensions (hwd / in.)
1.750 x 16.000 x 4.000
Unit Packaging Type
Box
Unit Weight (lbs.)
3.97
Unit Weight (kg)
1.80
ENVIRONMENTAL
Operating Temperature Range
32 to 104 F (0 to 40 C)
Storage Temperature Range
-4 to 140 F (-20 to 60 C)
Relative Humidity
0%-90% RH, Non-Condensing
BTUs
29.7 BTU/Hr
ESD Protection
Yes
COMMUNICATIONS
Hotkey
Yes
IP Remote Access
No
EDID Compatible
Yes
CONNECTIONS
Number of Ports
8
Daisy-Chain Port
No
Firmware Upgrade Port
Yes
PC/Server Connections
DVI; USB
Side A - Connector 1
(8) DVI-I (FEMALE)
Side A - Connector 2
(8) USB B (FEMALE)
Side A - Connector 3
(16) 3.5MM (FEMALE)
Side B - Connector 1
DVI-I (FEMALE)
Side B - Connector 2
(2) USB A (FEMALE)
Side B - Connector 3
(2) 3.5MM (FEMALE)
Included Cable (Side A) - Connector
1
No
3/4
Cleveland, OH 44122
United States
Computer Keyboard and Mouse
Interface
USB
Computer Monitor Interface
DVI-I Single-Link
Console Keyboard and Mouse
Interface
USB
Console Monitor Interface
DVI-I Single-Link
Connector Plating
Nickel
PORT EXPANSION
Daisy-chainable or Cascadable
Cascadeable
FEATURES & SPECIFICATIONS
Autoscan (Y,N)
Y
Autoscan Duration
10 to 60 seconds
Number of Users
1
NIAP-Certified Secure
No
On-Screen Display (OSD)
No
Port Selection
Pushbutton; Hotkey
USB Hub Ports
Yes
Number of USB Hub Ports
2
USB Specification
USB 2.0 (up to 480 Mbps)
Driver Required
No
Cat5 KVM Switch
No
STANDARDS & COMPLIANCE
External Power Supply Certifications
CE; FCC; RoHS; TUV; UL
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“B043-DUA8-SL”相匹配的价格&库存,您可以联系我们找货
