B002-DUA4
B002-DUA4
    TRIPPLITE
    4-PORT SECURE KVM SWITCH DVI USB
B002-DUA4 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Secure KVM Switch, DVI to DVI/VGA - 4-Port, NIAP EAL2+ Certified, Audio, CAC Support, Single Monitor Highlights ● 4-Port NIAP-Certified Secure DVI / USB KVM Switch with Audio ● Tested to comply with Common Criteria EAL2+ security requirements ● Multi-platform support: Windows, Linux, MAC, and SUN ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases ● CAC Support* MODEL NUMBER: B002-DUA4 System Requirements ● DVI or VGA Monitor ● USB Mouse and Keyboard ● Computer with DVI or VGA port ● Computer with USB Port ● Microphone with 3.5mm Male connector (optional) ● Speakers with 3.5mm Male connector (optional) ● Compatible with all major operating systems Safely switch between up to 4 computers with different levels of security. This NIAP-certified KVM Switch offers superior security and data protection for government / military agencies that require absolutely secure networks - read Government Computer Package Includes Description The Tripp Lite B002-DUA4 4 Port DVI / USB Secure KVM Switch with Audio offers secure and reliable access for any government/military desktop environment where security is required, by providing safe switching between computers operating on different networks. NIAP-certified to comply with Common Criteria EAL2+ security requirements Hardware security includes: tamper-evident tape, chassis intrusion detection, and tamper-proof hardware, while software security includes restricted USB connectivity — non HIDs (Human Interface Devices) are ignored when switching — an isolated channel per port that makes it impossible for data to be transferred between secure and unsecured computers, and automatic clearing of the keyboard buffer. CAC ( Common Access Card ) support* By combining physical security with controlled USB connectivity, the B002-DUA4 gives you the means to consolidate multiple workstations of various security classification levels with one keyboard, monitor and mouse (KVM) console. * CAC support not validated by NIAP Features ● National Information Assurance Partnership (NIAP) certified to comply with Common Criteria EAL2+ security requirements ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. ● Safely switch between computers with varying security levels. ● Isolated Channels – Each port is its own channel, making it impossible for data to be transferred between connected computers. ● Tamper-Warning Labels – Tamper-Warning labels will be placed on each side of the KVM, providing visual evidence if the unit has been tampered with or compromised. ● Housing Intrusion Protection Technology – Housing Intrusion Protection technology disables the KVM if the housing is opened, causing it to become inoperable. When disabled, the front panel LEDs will flash repeatedly. ● Tamper-Proof Components – All internal circuitry is soldered directly to the board, preventing the 1/3 ● B002-DUA4 4-Port Secure KVM Switch ● C13 - 5-15P Power Cord ● (4) Foot Pads ● Owner's Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States components from being tampered with. ● Fixed Firmware – Firmware is non-reprogrammable, securing against attempts to alter the logic of the KVM. ● Automatic Keyboard Buffer Clearing – The keyboard buffer is automatically cleared after data transmission, leaving no information stored in the switch. ● No Memory Buffer – The only way to access connected computers is via push button. Port switching methods such as On-Screen Display (OSD) and Hot key Commands, which require memory, have been excluded to further ensure data integrity. ● Compatible with all major operating systems: Windows, Linux, MAC, and SUN ● DVI-I Dual-Link signal supports digital video resolutions up to 2560 x 1600, and analog video resolutions up to 2048 x 1536. ● Supports transfer of EDID information, allowing for optimal display performance. ● Audio support for both speaker and microphone. ● CAC Support ( CAC support not validated by NIAP ) Specifications OVERVIEW UPC Code 037332167682 Max CPU 4 Technology DVI; Stereo Audio INPUT Nominal Input Voltage(s) Supported 100V AC; 110V AC; 115V AC; 120V AC; 127V AC; 140V AC; 200V AC; 208V AC; 220V AC; 230V AC; 240V AC Nominal Input Voltage Description 100-240V, 50/60 Hz, 0.5A Input Frequency 50/60Hz Input Current 120V (0.4A) / 230V (0.2A) POWER Power Consumption (Watts) 5.1 Power Consumption Detail 5.1W (120V ), 5.1W (230V) PHYSICAL Color Black Shipping Dimensions (hwd / in.) 4.60 x 16.30 x 8.50 Shipping Dimensions (hwd / cm) 11.68 x 41.40 x 21.59 Shipping Weight (lbs.) 5.70 Shipping Weight (kg) 2.59 Unit Dimensions (hwd / in.) 1.750 x 13.200 x 6.100 Unit Dimensions (hwd / cm) 4.45 x 33.66 x 15.24 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Weight (lbs.) 3.70 Unit Weight (kg) 1.68 ENVIRONMENTAL Storage Temperature Range -20 to 60 C ( -4 to 140F ) Relative Humidity 0 to 80% RH, Non-Condensing Operating Temperature 0 to 40C ( 32 to 104F ) COMMUNICATIONS Port Control Push Buttons IP Remote Access No CONNECTIONS Number of Ports 4 Computer/Server Ports 4 x DVI-I, 4 x USB "B", 8 x 3.5mm ( Speaker/Microphone ) PC/Server Connections DVI; USB Local Console Ports - Port 3 USB - Keyboard Local Console Ports - Port 4 2 x 3.5mm ( Speaker / Microphone ) FEATURES & SPECIFICATIONS Number of Users 1 NIAP-Certified Secure Yes Cat5 KVM Switch No WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
B002-DUA4 价格&库存
很抱歉,暂时无法提供与“B002-DUA4”相匹配的价格&库存,您可以联系我们找货
