B022-U08-IP
B022-U08-IP
    TRIPPLITE
    8-PORT RACKMOUNT IP KVM SWITCH
B022-U08-IP 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States To obtain a copy of the owner’s manual for your B022-U08-IP or B022-U16-IP KVM, please contact Product/Technical Support – (773) 869-1234. You will need to have the serial number for your product at Highlights ● Directly control up to 8 computers on a single KVM switch or up to 256 computers as part of a daisy-chain ● Remotely access computers via LAN, WAN or Internet via the Windows or Java browser clients ● Supports both IPv4 and IPv6 ● Supports RADIUS and LDAP/S authentication ● 3-level security (Admin, User and Select) – up to 64 accounts can be created ● Compatible with all major operating systems the time of the call. Should you experience any inconsistencies in upgrading firmware or lengthy load times, please contact the Product/Tech Support team at Tripp Lite. NetDirector 8-Port 1U Rack-Mount IP KVM Switch MODEL NUMBER: B022-U08-IP System Requirements External Console ● A VGA, SVGA or MultiSync monitor capable of displaying the highest resolution provided by any computer in the installation. ● PS/2 or USB keyboard and mouse. Description The B022-U08-IP NetDirector IP KVM Switch allows secure access to multiple computers from a single KVM (keyboard, monitor and mouse) console. A single KVM can directly control up to 8 computers. Daisychain up to 31 additional B022-U08 switches to control up to 256 computers. Built-in IP access allows the B022-U08-IP to be accessed from any computer on the LAN, WAN or Internet, whether that computer is located down the hall or halfway around the world. Simply log on via web browser using the Windows- and Java-based browser clients; or, access the KVM without a browser using the included Windows- and Java-based non-browser applications. Remote authentication is also supported via RADIUS and LDAP/S. A full-screen graphical OSD with multi-level authentication (Super Administrator, Administrator and User) allows you to quickly and efficiently manage your installation, and can be displayed in English, Spanish, French, German, and Japanese. Critical events on the installation can be tracked via the Log in the web interface, or the included Windows-based Log Server can be installed for more robust tracking. Once a remote session is initiated, you will be able to control the connected computers as if they were physically connected to your keyboard, monitor, and mouse. You can manually switch between computers using keyboard hotkeys, the remote session toolbar, or the KVM's OSD interface; or, you can automatically scan through each port using Auto Scan or Panel Array modes. Constructed of heavy-duty steel housing. The B022-U08-IP includes two 6-ft Tripp Lite USB/PS2 combo KVM cable kits. All other cable kits can be ordered separately. Computers ● A VGA, SVGA or MultiSync video graphics card with an HD15 port. ● Either a PS/2 or USB keyboard/mouse ports. ● Compatible with all major operating systems. Remote Console ● For best results, computers that remotely access the KVM switch should have at least a Pentium III 1GHz processor. ● Users who want to access the KVM switch with the Windows client must have DirectX 8.0 or higher installed. DirectX is available for free download from Microsofts website. ● Users who want to access the KVM switch with the Java client must have Sun's Java 6 (update 3 or higher) runtime environment installed. Java is available for free download from the Java website. Features ● 1U Rackmount KVM Switch with built-in IP access. ● Connect either USB or PS/2 computers using P778-Series USB/PS2 Combo KVM Cable Kits – no need for separate cable kits. ● Control up to 8 computers on a single KVM switch. ● Daisy-chain up to 31 additional B022-U08 switches to control up to 256 computers. ● Remotely access computers via LAN, WAN or Internet via the Windows™ or Java browser clients. ● AP Windows and Java non-browser applications allow the KVM to be remotely accessed via the network without going through a browser. ● External USB 1.1 port allows USB peripheral devices to be shared amongst connected computers. 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Grayscale feature allows you to view remote sessions in black and white, reducing the amount of data traveling over the network and improving keyboard/mouse response time over IP. ● Web management interface, OSD and toolbars provide convenient, user-friendly operation. ● 3-level security (Admin, User and Select) – up to 64 accounts can be created. ● Panel Array Mode – remotely monitor multiple ports at the same time. ● Message board feature allows users who are logged in at the same time to communicate with each other and manage port access. ● CD includes a Windows-based log server that records events on the installation and writes them to a searchable database. ● Supports RADIUS and LDAP/S authentication. ● Flash firmware upgradable via network and included firmware upgrade cable. ● Firefox 1.5 and higher ● Supports both IPv4 and IPv6. ● Mozilla 1.7 and higher ● Supports Link Local IPv6 Address and IPv6 Stateless Auto configuration protocol. ● Safari 4.0 and higher ● Web Management Interface, Remote OSD and Local OSD can be displayed in English, Spanish, French, German and Japanese. ● Opera 9.0 and higher ● For best results, a network transfer speed of at least 128Kbps is recommended. ● Browsers must support 128-bit data encryption. ● To run the Log Server, you must have the Microsoft Jet OLED8 4.0 (or higher) driver installed. Netscape 8.1 and higher Supported Web Browsers ● Internet Explorer 6 and higher ● Advanced encryption technologies: 128-bit SSL, 128-bit RC4, 1024-bit RSA, 56-bit DES, 256-bit AES, 168-bit 3DES. ● Video resolutions up to 2048 x 1536, DDC2B are supported at the local console. Video resolutions up to 1600 x 1200 @ 60Hz, 24-bit color depth are supported at the remote console. ● ● Compatible with all major operating systems. Package Includes ● B022-U08-IP IP KVM Switch ● (x2) 6 ft. USB/PS2 Combo KVM Cable Kits ● USB/PS2 Combo Console Cable Kit ● RJ11 to DB9 Firmware Upgrade Cable ● Rackmount Hardware ● External Power Supply with NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.5A Output: 5.3V, 2.4A) ● Rubber Feet ● CD with Owner's Manual and Device Files ● Quick Start Guide Specifications OVERVIEW UPC Code 037332177049 Max CPU 8 Technology PS/2; VGA/SVGA VIDEO Max Supported Video Resolution Up to 2048 x 1536, DDC2B are supported at the local console. Video resolutions up to 1600 x 1200 @ 60Hz, 24-bit color depth are supported at the remote console. 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.5A External Power Supply Output Specs (V / A) 5.3V / 2.4A External Power Supply Cord Length (ft.) 5 External Power Supply Cord Length (m.) 1.5 PHYSICAL Housing Color Black Shipping Dimensions (hwd / in.) 9.10 x 21.40 x 4.60 Shipping Dimensions (hwd / cm) 23.11 x 54.36 x 11.68 Shipping Weight (lbs.) 7.80 Shipping Weight (kg) 3.54 Unit Dimensions (hwd / in.) 1.750 x 17.000 x 6.000 Unit Dimensions (hwd / cm) 4.39 x 43.18 x 15.24 Unit Weight (lbs.) 6.1 Unit Weight (kg) 2.77 ENVIRONMENTAL Storage Temperature Range -20 to 60 C (-4 to 140 F) Relative Humidity 0 to 80% RH, Non-Condensing Operating Temperature 0 to 50 C (32 to 122 F) BTUs DC5.3V 7.67W / 55BTU COMMUNICATIONS Port Control Push Buttons, Hotkeys, OSD IP Remote Access Yes CONNECTIONS Number of Ports 8 PC/Server Connections PS/2; USB; VGA Side A - Connector 1 (8) HD18 (FEMALE) Side B - Connector 1 (1) HD18 (FEMALE) 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Side B - Connector 2 (1) DB25 (MALE) Side B - Connector 3 (1) RJ45 (FEMALE) Side B - Connector 4 (1) RJ11 (FEMALE) Side B - Connector 5 (1) USB A (FEMALE) PORT EXPANSION Daisy-chainable or Cascadable Daisychainable FEATURES & SPECIFICATIONS Autoscan (Y,N) Y Autoscan Duration 1-255 Seconds Number of Users 1 NIAP-Certified Secure No USB Specification USB 2.0 (up to 480 Mbps) Cat5 KVM Switch No STANDARDS & COMPLIANCE External Power Supply Certifications FCC; PSE; UL; cUL Product Certifications UL Listed Product Compliance RoHS; CE (Europe); FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B022-U08-IP 价格&库存
很抱歉,暂时无法提供与“B022-U08-IP”相匹配的价格&库存,您可以联系我们找货
