1000 Eaton Boulevard
Cleveland, OH 44122
United States
NetController 8-Port 1U Rack-Mount Console
KVM Switch with 19-in. LCD
MODEL NUMBER: B040-008-19
Highlights
Occupies just 1U of space in
rack-mountable drawer
19” LCD screen supports video
resolutions up to 1366 x 768
Simplifies IT tasks with easy
switching between all 8 ports
Password protection prevents
unauthorized access
Compatible with all major
operating systems
Compliant with the Federal
Trade Agreements Act (TAA) for
GSA Schedule purchases
System Requirements
Control up to 8 computers with a single KVM switch with integrated console, or increase the total
connected computers to 248 by daisy-chaining. This KVM switch is a smart solution for space- and
money-saving server control.
Description
Tripp Lite’s B040-008-19 KVM Switch gives you a rack-mountable keyboard, LCD and touchpad in a
single console that occupies only 1U of rack space. Easy to install and use, it’s the cost-effective solution
for controlling up to 8 directly connected computers/servers.
The B040-008-19 has a built-in 19” LCD screen that supports video resolutions up to 1366 x 768. You can
switch easily between the 8 ports using on-console push buttons, an on-screen display (OSD) or keyboard
hot key commands. Password protection prohibits unauthorized users from accessing the connected
computers.
With this KVM switch, you can increase the number of connected computers up to 248 by daisy-chaining
up to 15 B042-Series KVM switches. Uses Tripp Lite P780-series combo cable kits that support both PS/2
and USB connections without the need to purchase additional cables or adapters. An extra HD15 port
allows an additional VGA monitor or an external console to be connected. Add a Tripp Lite B051-000 IP
Remote Access Unit to connect from anywhere in the world. When not in use, the B040-008-19 stores
neatly in a rack drawer and pulls out when needed. This KVM console is compatible with all major
operating systems. Rugged steel housing stands up to frequent use. Complies with the Federal Trade
Agreements Act (TAA) for GSA Schedule purchases.
Features
Saves Valuable Space and Money
● Combines an 8-port KVM switch, 19” LCD screen, full keyboard and touchpad in a 1U rack-mountable
drawer
Mounts into 19”-wide rack, 27-42” deep; can be mounted in a 2-post rack using Tripp Lite’s B019-000
Control up to 8 computers or servers from one easily accessible console – ideal when rack space is at a
premium
Flip-up/fold-down screen keeps console from blocking access to rack equipment when not in use
Eliminates need to buy separate costly monitors, keyboards and mice for each computer/server
Simplifies IT Tasks
● Switch easily between the 8 ports via on-console buttons, on-screen display or keyboard hot key
commands
1/4
Computer with HD15 port, and
USB port or PS/2
keyboard/mouse ports
P780-Series USB/PS2 combo
KVM cable kit is required for
each connected
computer/server
operating systems
Power consumption: 120V,
60Hz, 33W; 230V, 50Hz, 34W
Hardware Versions
A new hardware version (v2) of the
B040-008-19 was released in
2019, requiring different firmware
from the previous version (v1). The
Support tab of this page includes a
zip folder for v2. Along with the
applicable firmware, it contains an
FW Notes file to help you
determine which hardware version
you have and which firmware to
use. The current firmware comes
pre-installed on all v2 models. If
you have a hardware version (v1)
KVM, consult Technical Support for
the applicable firmware.
Note: *When daisy-chaining (8) or
(16) Port KVM switches together
and problems are experienced,
confirm switches have the same
hardware version. If firmware is not
up to date, you may need to
upgrade the firmware of your
unit(s).*
Package Includes
B040-008-19 1U rackmount
console KVM switch with 19”
LCD
4 ft. HD15 to DB9 firmware
Cleveland, OH 44122
United States
Auto-scan mode automatically sequences through all active ports that are accessible to the user
Large 19” LCD
● Extra-wide display makes multitasking easier
Supports video resolutions up to 1366 x 768
Password Protection
● Single-level password security limits access to authorized users
Two-level log-out allows manual log-out or automatic log-out after a user-defined period of time has
passed
Expandability and Long-Lasting Reliability
● A port is available for connecting an external console or a Tripp Lite B051-000 IP Remote Access Unit
that will let you control your servers from virtually anywhere in the world
Use the B040-008-19 with up to 15 B042-Series KVM switches daisy-chained to have access to up to
248 computers/servers
Compatible with all major operating systems for easy integration into your existing structure
Firmware is easily upgradable with included cable and utility
Heavy-duty steel housing stands up to frequent use
TAA Compliant
● Complies with the Federal Trade Agreements Act for GSA Schedule purchases
Specifications
OVERVIEW
UPC Code
037332140296
Console
Yes
Max CPU
248
Technology
PS/2; VGA/SVGA
VIDEO
Max Supported Video Resolution
1366 x 768 @ 60Hz
Max. Distance (Between any 2
Units)
98ft (30m)
Max Number of Ports (Entire Chain)
248
INPUT
Voltage Compatibility (VAC)
100; 110; 120; 127; 200; 208; 220; 230; 240
Input Frequency
50/60Hz
Input Current
120V (1.4A) / 230V (0.8A)
Built-In Cable Length (in.)
10
2/4
upgrade cable
6 ft. C13 to 5-15P power cord
External VGA port terminator
Rackmount hardware
CD with owner's manual
Quick start guide
Cleveland, OH 44122
United States
Power Input Receptacle
IEC-320-C14
POWER
Power Consumption (Watts)
30
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
Green (CAPS LOCK, SCROLL LOCK, NUM LOCK, SELECTED); Red (LIVE)
PHYSICAL
Color
Black
Material of Construction
Steel (Steel, Electrogalvanized, Cold Rolled, Coil)
LCD Monitor (in.)
19
Rackmountable
Yes
Shipping Dimensions (hwd / in.)
6.10 x 23.40 x 32.68
Shipping Dimensions (hwd / cm)
15.49 x 59.44 x 83.01
Shipping Weight (lbs.)
40.10
Shipping Weight (kg)
18.19
Unit Dimensions (hwd / in.)
1.710 x 17.690 x 28.440
Unit Packaging Type
Box
Unit Weight (lbs.)
31.7
Unit Weight (kg)
14.38
ENVIRONMENTAL
Storage Temperature Range
-4 to 140 F (-20 to 60 C)
Relative Humidity
20% to 90% RH, Non-Condensing
Operating Temperature
32 to 104 F (0 to 40 C)
BTUs
(Line Mode) 102 BTU/Hr / (Standby Mode) 17.1 BTU/Hr
COMMUNICATIONS
IP Remote Access
No
CONNECTIONS
Number of Ports
8
Computer/Server Ports
(x8) HD15 Female
Daisy-Chain Port
HD15 Female
Firmware Upgrade Port
HD15 Male
PC/Server Connections
PS/2; USB; VGA
3/4
Cleveland, OH 44122
United States
Side A - Connector 1
(2) HD15 (FEMALE)
Side A - Connector 2
HD15 (MALE)
Side A - Connector 3
USB A (FEMALE)
Side B - Connector 1
(8) HD15 (FEMALE)
Computer Keyboard and Mouse
Interface
PS/2; USB
Computer Monitor Interface
VGA
PORT EXPANSION
Daisy-chainable or Cascadable
Daisychainable
FEATURES & SPECIFICATIONS
Number of Users
1
NIAP-Certified Secure
No
On-Screen Display (OSD)
Yes
Port Selection
Pushbutton; Hotkey; OSD
USB Specification
USB 1.1 (up to 12 Mbps)
Driver Required
No
Cat5 KVM Switch
No
BUILT-IN CONSOLE
Console Screen Size (inches)
19
Console Screen Aspect Ratio
16:9
STANDARDS & COMPLIANCE
Product Certifications
CAN/CSA C22.2; CAN/CSA-C22.2 No. 60950-1 (Canada); NOM (Mexico); UL 60950-1
Product Compliance
RoHS; CE (Europe); REACH; FCC Part 15 Class A (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“B040-008-19”相匹配的价格&库存,您可以联系我们找货
