B021-000-19
B021-000-19
    TRIPPLITE
    RACKMOUNTCONSOLEWITH19"LCD
B021-000-19 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 1U Rack-Mount Console with 19-in. LCD Highlights ● Control an entire network in just 1U of rack space; includes keyboard, 19" LCD screen and touch pad ● Features a USB 2.0 passthrough port for connection of a USB peripheral, such as a flash drive, CAC card reader, etc. ● Connects to a PS/2 or USB server or KVM switch ● Supports resolutions up to 1366 X 768 ● Rackmountable in 19" system rack (1U), from 27" to 42" deep ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: B021-000-19 System Requirements ● Description Tripp Lite's B021-000-19 1U Rackmount Console features an integrated 19" LCD display, full 88-key keyboard and touch pad, all in a 1U rackmountable housing. The included KVM cable kit allows for connection to a PS/2 computer or KVM, and a PS/2 to USB adapter is included, which can be used to connect to a USB computer or KVM. The unit features a USB 2.0 pass-through port for connection of a USB peripheral, such as a flash drive, CAC card reader, etc.. Your peripheral device connects to the USB type A port on the front of the unit, and your computer connects to the USB type A port on the back of the unit using a Tripp Lite UR020-Series type A M/M cable. Constructed of heavy-duty steel housing. Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. Features ● Features 19-inch LCD TFT active-matrix, color panel ● Space saving 1U 19-inch, rackmount drawer design ● Features a USB 2.0 pass-through port for connection of a USB peripheral, such as a flash drive, CAC card reader, etc. ● Supports resolutions of up to 1366 X 768 ● Included PS/2 to USB adapter allows for connection to a USB computer or KVM ● Sleep mode when the monitor cover is closed ● Input 120/240 VAC ● Constructed of heavy-duty steel housing ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332152657 Technology PS/2; VGA/SVGA 1/3 Computer or KVM with a VGA monitor port and USB or PS/2 keyboard/mouse ports Package Includes ● 1U Rackmount Console w/ 19" LCD ● 1- KVM Cable Kit ( HD15M to HD15M + 2 PS2 Male ) ● 1-PS/2 to USB Adapter ● 1- C13 to 5-15P Power Cord ● 1- User Manual ● Mounting Hardware 1000 Eaton Boulevard Cleveland, OH 44122 United States VIDEO Max Supported Video Resolution 1366 x 768 @ 60Hz INPUT Voltage Compatibility (VAC) 100; 110; 120; 127; 200; 208; 220; 230; 240 Input Frequency 50/60Hz Input Current 120V (1.2A) / 230V (0.7A) Power Input Receptacle IEC-320-C14 POWER Power Consumption (Watts) 30 Power Consumption Detail (Line Mode) 30W / (Standby Mode) 5W USER INTERFACE, ALERTS & CONTROLS LED Indicators Green (CAPS LOCK, SCROLL LOCK, NUM LOCK) PHYSICAL Color Black Material of Construction Steel (Steel, Electrogalvanized, Cold Rolled, Coil) Rackmountable Yes Shipping Dimensions (hwd / in.) 6.00 x 23.70 x 32.50 Shipping Dimensions (hwd / cm) 15.24 x 60.20 x 82.55 Shipping Weight (lbs.) 38.70 Shipping Weight (kg) 17.55 Unit Dimensions (hwd / in.) 1.710 x 17.690 x 28.440 Unit Packaging Type Box Unit Weight (lbs.) 31 Unit Weight (kg) 14.06 ENVIRONMENTAL Operating Temperature Range 32 to 104 F (0 to 40 C) Storage Temperature Range -4 to 140 F (-20 to 60 C) Relative Humidity 20% to 90% RH, Non-Condensing BTUs (Line Mode) 102 BTU/Hr / (Standby Mode) 17.1 BTU/Hr COMMUNICATIONS IP Remote Access No 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States CONNECTIONS Number of Ports 1 PC/Server Connections VGA; USB; PS/2 Side A - Connector 1 USB A (FEMALE) Side A - Connector 2 HD15 (FEMALE) Side B - Connector 1 USB A (FEMALE) Computer Keyboard and Mouse Interface PS/2; USB Computer Monitor Interface VGA FEATURES & SPECIFICATIONS Number of Users 1 NIAP-Certified Secure No USB Specification USB 2.0 (up to 480 Mbps) Driver Required No Cat5 KVM Switch No BUILT-IN CONSOLE Console Screen Size (inches) 19 Console Screen Aspect Ratio 16:9 STANDARDS & COMPLIANCE Product Certifications CAN/CSA C22.2; CAN/CSA-C22.2 No. 60950-1 (Canada); UL 60950-1 Product Compliance RoHS; CE (Europe); REACH; FCC Part 15 Class A (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
B021-000-19 价格&库存
很抱歉,暂时无法提供与“B021-000-19”相匹配的价格&库存,您可以联系我们找货
B021-000-19
