B070-008-19
B070-008-19
    TRIPPLITE
    KVMSWITCH1U19"MON/KYBD/TCHPD
B070-008-19 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States For best results, STP (Shielded Twisted Pair) Cat5e or higher cabling is recommended like Tripp Lite's Highlights N105-Series, N125-Series or N262-Series. ● NetCommander 8-Port Cat5 1U Rack-Mount Console KVM Switch with 19-in. LCD Occupies just 1U of space in a rack-mountable drawer ● Low-cost Cat5 cabling allows longer distances, reduces cable clutter MODEL NUMBER: B070-008-19 ● 19” LCD screen supports video resolutions up to 1366 x 768 ● Simplifies IT tasks with easy switching between all 8 ports ● Expandable - Cascade a second level of KVM switches to control up to 128 servers from a single station using Tripp Lite's B072008-1, B072-008-1A, B072-0161 and/or B072-016-1A to increase the number of ports. ● TAA compliant for GSA Schedule purchases System Requirements Control up to 8 computers with one Cat5 KVM switch with integrated console. This KVM switch is a smart solution for efficient server control that saves rack space and money. Low-cost Cat5 cabling lets you locate servers up to 100 ft. from switch. ● Computer with HD15 port, and USB port or PS/2 keyboard/mouse ports ● User-supplied Cat 5e/6/6a cabling ● B078-101-USB-1 (USB) Server Interface Unit is required for each connected computer/server ● For computers with Displayport or HDMI, change to VGA using Tripp Lite adapters P134-06NVGA-V2 or P131-06N. Maximum video resolutions using adapters may vary. ● Compatible with all major operating systems ● Power consumption: 120V, 60Hz, 30W Description Tripp Lite’s B070-008-19 KVM Switch gives you a rack-mountable full keyboard, LCD and touchpad in a single console that occupies only 1U of rack space. Easy to install and use, it’s the optimal solution for controlling up to 8 computers/servers. The B070-008-19 uses inexpensive, user-supplied Cat5e/6/6a and a Server Interface Unit so you can control computers/servers located up to 100 ft. away from the switch. You can switch easily between the 8 ports using an on-screen display (OSD) or keyboard hot key commands. Multi-level password protection prohibits unauthorized users from accessing the connected computers. The built-in 19” LCD screen supports video resolutions up to 1366 x 768. Add a Tripp Lite B051-000 IP Remote Access Unit and you’ll be able to connect to your servers from anywhere in the world. The B070-008-19 stores neatly in a rack drawer and pulls out when needed. This KVM console is compatible with all major operating systems. Heavy-duty steel housing stands up to frequent use. Complies with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. Package Includes Features ● B070-008-19 1U rackmount console KVM switch with 19” LCD ● C13 to 5-15P power cord Mounts into 19”-wide rack, 27”-42” deep; can be mounted in 2-post rack with Tripp Lite’s B019-000 ● Serial firmware upgrade cable ● Flip-up/fold-down screen keeps console from blocking access to rack equipment when not in use ● ● Eliminates need to buy costly monitors, keyboards and mice for each computer/server Jumper cable to connect KVM console ports to integrated console ports ● Uses inexpensive Cat5e/6/6a Cables ● Rackmount hardware ● Low-cost cables lets you locate servers up to 100 ft. from the switch ● CD with owner's manual ● Use a plug-and-play Server Interface Unit, B078-101-USB-1 (for USB) with each server that will be connected with Cat5 cable ● For computers with Displayport or HDMI, change to VGA using Tripp Lite adapters P134-06N-VGA-V2 or P131-06N. Maximum video resolutions using adapters may vary. Saves Space and Money ● Combines 8-port KVM switch, 19” LCD screen, keyboard and touchpad in a 1U rack-mountable drawer – ideal when rack space is at a premium ● 1/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Simplifies IT Tasks ● Switch easily between the 8 ports via on-screen display or keyboard hot key commands ● Hot pluggable; add or remove USB computers without having to power down the switch ● Auto-scan mode automatically sequences through all active ports accessible to the user Large 19” LCD ● Extra-wide display makes multitasking easier ● Supports video resolutions up to 1366 x 768 ● DDC emulation allows the video settings of each computer to be automatically adjusted for optimal output to the LCD Multi-Level Password Security ● Multi-level password security limits access to authorized users (administrator, supervisor or user) ● Two-level log-out allows manual log-out or automatic log-out after a user-defined period of time has passed Expandability and Long-Lasting Reliability ● Control your servers from anywhere in the world over LAN, WAN or the Internet by adding a Tripp Lite B051-000 IP Remote Access Unit ● Expandable - Cascade a second level of KVM switches to control up to 128 servers from a single station using Tripp Lite's B072-008-1, B072-008-1A, B072-016-1 and/or B072-016-1A to increase the number of ports. ● Compatible with all major operating systems for easy integration into your existing structure ● Firmware is upgradable with included cable and utility ● Heavy-duty steel housing stands up to frequent use TAA Compliant ● Complies with the Federal Trade Agreements Act for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332154927 Console Yes Max CPU 128 Technology Cat5/5e; PS/2; VGA/SVGA VIDEO Max Supported Video Resolution 1366 x 768 @60Hz Max. Distance (Between any 2 Units) 100 ft (30.5m) Max Number of Ports (Entire Chain) 128 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States INPUT Voltage Compatibility (VAC) 100; 110; 120; 127; 200; 208; 220; 230; 240 Input Frequency 50/60Hz Input Current 120V (1.4A) / 230V (0.8A) Power Input Receptacle IEC-320-C14 POWER Power Consumption (Watts) 30 Power Consumption Detail (Line Mode) 30W / (Standby Mode) 5W USER INTERFACE, ALERTS & CONTROLS LED Indicators Green (CAPS LOCK, SCROLL LOCK, NUM LOCK) PHYSICAL Color Black Material of Construction Steel (Steel, Electrogalvanized, Cold Rolled, Coil) LCD Monitor (in.) 19 Rackmountable Yes Shipping Dimensions (hwd / in.) 6.30 x 23.43 x 32.83 Shipping Dimensions (hwd / cm) 16.00 x 59.51 x 83.39 Shipping Weight (lbs.) 40.58 Shipping Weight (kg) 18.41 Unit Dimensions (hwd / in.) 1.710 x 17.690 x 28.440 Unit Packaging Type Box Unit Weight (lbs.) 31.00 Unit Weight (kg) 14.06 ENVIRONMENTAL Storage Temperature Range -40 to 158 F (-40 to 70 C) Relative Humidity 0% to 80% RH, Non-Condensing Operating Temperature 32 to 104 F (0 to 40 C) BTUs (Line Mode) 102 BTU/Hr / (Standby Mode) 17.1 BTU/Hr COMMUNICATIONS IP Remote Access No CONNECTIONS 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Number of Ports 8 PC/Server Connections PS/2; USB; VGA Side A - Connector 1 (8) RJ45 (FEMALE) Side B - Connector 1 (2) HD15 (FEMALE) Side B - Connector 2 (4) MINI DIN-6 (FEMALE) Side B - Connector 3 (1) RJ11 (FEMALE) Computer Keyboard and Mouse Interface PS/2; USB Computer Monitor Interface VGA PORT EXPANSION Daisy-chainable or Cascadable Cascadeable FEATURES & SPECIFICATIONS Autoscan (Y,N) Y Autoscan Duration Variable Number of Users 1 NIAP-Certified Secure No On-Screen Display (OSD) Yes Port Selection Hotkey; OSD Driver Required No Cat5 KVM Switch Yes Recommended Category Cable Cat5e/Cat6/Cat6a Cables BUILT-IN CONSOLE Console Screen Size (inches) 19 Console Screen Aspect Ratio 16:9 STANDARDS & COMPLIANCE Product Certifications CAN/CSA C22.2; CAN/CSA-C22.2 No. 60950-1 (Canada); UL 60950-1 Product Compliance RoHS; CE (Europe); REACH; FCC Part 15 Class A (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
B070-008-19 价格&库存
很抱歉,暂时无法提供与“B070-008-19”相匹配的价格&库存,您可以联系我们找货
