B020-U08-19-K
B020-U08-19-K
    TRIPPLITE
    NETDIRECTOR19'CONSOLEKVM
B020-U08-19-K 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States NetDirector 8-Port 1U Rack-Mount Console KVM Switch with 19-in. LCD + 8 PS2/USB Combo Cables MODEL NUMBER: B020-U08-19-K Highlights ● Occupies just 1U of space in a rack-mountable drawer ● 19” LCD screen supports video resolutions up to 1280 x 1024 ● Simplifies IT tasks with easy switching between all 8 ports ● Provides 2-level password security (administrator and user) ● Combo cables (included) connect to PS/2 or USB servers System Requirements ● Computer with HD15 port, and USB port or PS/2 keyboard/mouse ports ● P778-006 USB/PS2 combo KVM cable kit is required for each connected computer/server ● Compatible with all major operating systems ● Power consumption: 120V, 60Hz, 28.5W; 230V, 50Hz, 29.1W Control up to 8 computers with a single KVM switch with integrated console. This KVM switch is a smart solution for secure and centralized server control that saves rack space and money. Package Includes Features ● B020-U08-19-K 1U rackmount console KVM switch with 19” LCD ● (x8) P778-006 6-ft. (1.83 m) USB/PS2 combo KVM cable kits ● USB/PS2 combo console cable kit ● RJ11 to DB9 firmware upgrade cable ● C13 to 5-15P power cord ● Grounding wire ● Rackmount hardware ● CD with owner's manual ● Quick start guide Saves Space and Money ● Combines an 8-port KVM switch, 19” LCD screen, full keyboard and touchpad in a 1U rack-mountable drawer ● Mounts into 19”-wide rack, 26”-38” deep ● Control up to 8 servers from a single, easily accessible console – ideal when rack space is at a premium ● Includes eight P778-Series cables that support computers with either PS/2 or USB connections ● Flip-up/fold-down screen keeps the console from blocking access to rack equipment when not in use ● Eliminates need to buy costly separate monitors, keyboards and mice for each computer/server Simplifies IT Tasks ● Switch easily between the 16 ports via on-console buttons, on-screen display or hot keys; OSD can be set to English, Spanish, French, German or Japanese ● Hot pluggable; add or remove computers without having to power down the switch ● Auto-scan mode automatically sequences through all active ports that are accessible to the user Large 19” LCD ● Extra-wide display makes multitasking easier ● Supports video resolutions up to 1280 x 1024 ● DDC emulation allows optimal output to the LCD Multi-Level Password Security ● Enhances security by limiting access to an administrator and up to 4 local users ● Two-level log-out allows for manual log-out or automatic log-out after a user-defined period of time has 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States passed Expandability and Long-Lasting Reliability ● Increase the number of connected computers up to 256 by daisy-chaining up to 31 B022-U08 KVM switches ● A console cable kit is included so you can connect the external console port to a keyboard, mouse or monitor, or a Tripp Lite B051-000 IP Remote Access Unit ● An additional USB port on the front of the unit lets you connect an external USB mouse; a USB port is also available to share a peripheral such as a flash drive or external hard drive with all the connected servers ● Compatible with all major operating systems for easy integration into your existing structure ● Firmware is upgradable with included cable and utility ● Heavy-duty steel housing stands up to frequent use Specifications OVERVIEW UPC Code 037332150776 Console Yes Max CPU 8 Technology PS/2; VGA/SVGA VIDEO Max Supported Video Resolution 1280 x 1024 @60Hz INPUT Nominal Input Voltage(s) Supported 100V AC; 110V AC; 115V AC; 120V AC; 127V AC; 140V AC; 200V AC; 208V AC; 220V AC; 230V AC; 240V AC Input Frequency 50/60Hz Input Current 120V (0.8A) / 230V (0.4A) POWER Power Consumption (Watts) 28.50 Power Consumption Detail (28.5W at 120V, 60Hz) / (29.1W at 230V, 50Hz) PHYSICAL Color Black Cable Jacket Color Black Included Mounting Accessories Yes LCD Monitor (cm) 48.26 LCD Monitor (in.) 19 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / in.) 5.00 x 26.10 x 32.50 Shipping Dimensions (hwd / cm) 12.70 x 66.29 x 82.55 Shipping Weight (lbs.) 43.00 Shipping Weight (kg) 19.50 Unit Dimensions (hwd / in.) 1.750 x 19.000 x 27.000 Unit Dimensions (hwd / cm) 4.45 x 43.18 x 68.58 Unit Weight (lbs.) 30.6 Unit Weight (kg) 13.88 ENVIRONMENTAL Storage Temperature Range -4 Degrees F to 140 degrees F (-20 to +60 C) Relative Humidity 0 to 80% RH, Non-condensing Operating Temperature 32 Degrees F to 120 Degrees F (0 to 50 C) BTUs 26.1 BTUs at 120Vac/ 27.2 BTUs at 220Vac COMMUNICATIONS Port Control Push Buttons, Hotkeys, OSD IP Remote Access No CONNECTIONS Number of Ports 8 Computer/Server Ports (x8) HD18 (Female) Firmware Upgrade Port RJ11 PC/Server Connections PS/2; USB; VGA Side A - Connector 1 (8) HD18 (FEMALE) Side B - Connector 1 (1) HD18 (MALE) Side B - Connector 2 (1) DB25 (MALE) Side B - Connector 3 (1) RJ11 (FEMALE) Side B - Connector 4 (2) USB A (FEMALE) FEATURES & SPECIFICATIONS Autoscan (Y,N) Y Autoscan Duration 1-255 Seconds Number of Users 1 NIAP-Certified Secure No USB Specification USB 2.0 (up to 480 Mbps) Cat5 KVM Switch No 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States STANDARDS & COMPLIANCE Product Certifications EN 60950-1; CAN/CSA C22.2; CAN/CSA-C22.2 No. 60950-1 (Canada); cUL Listed; UL 60950-1; UL Listed Product Compliance RoHS; CE (Europe); FCC Part 15 Class A (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B020-U08-19-K 价格&库存
很抱歉,暂时无法提供与“B020-U08-19-K”相匹配的价格&库存,您可以联系我们找货
B020-U08-19-K
    库存:44
