1000 Eaton Boulevard
Cleveland, OH 44122
United States
For best results, STP (Shielded Twisted Pair) Cat5e or higher cabling is recommended like Tripp Lite's
Highlights
N105-Series, N125-Series or N262-Series.
NetCommander 16-Port Cat5 1U Rack-Mount
Console KVM Switch with 19-in. LCD
Occupies just 1U of space in a
rack-mountable drawer
Low-cost Cat5 cabling allows
longer distances, reduces cable
clutter
MODEL NUMBER: B070-016-19
19” LCD screen supports video
resolution up to 1366 x 768
Simplifies IT tasks with easy
switching between all 16 ports
Expandable - Cascade a second
level of KVM switches to control
up to 256 servers from a single
station using Tripp Lite's B072008-1, B072-008-1A, B072-0161 and/or B072-016-1A to
increase the number of ports.
TAA compliant for GSA
Schedule purchases
System Requirements
Control up to 16 computers with one Cat5 KVM switch with integrated console. This KVM switch is a
smart solution for efficient server control that saves rack space and money. Low-cost Cat5 cabling lets
you locate servers up to 100 ft. from switch.
Computer with HD15 port, and
USB port or PS/2
keyboard/mouse ports
User-supplied Cat 5e/6/6a
cabling
B078-101-USB-1 (USB) Server
Interface Unit is required for
each connected
computer/server
For computers with Displayport
or HDMI, change to VGA using
Tripp Lite adapters P134-06NVGA-V2 or P131-06N.
Maximum video resolutions
using adapters may vary.
Compatible with all major
operating systems
Power consumption: 120V,
60Hz, 30W
Description
Tripp Lite’s B070-016-19 KVM Switch gives you a rack-mountable full keyboard, LCD and touchpad in a
single console that occupies only 1U of rack space. Easy to install and use, it’s the optimal solution for
controlling up to 16 computers/servers.
The B070-016-19 uses inexpensive, user-supplied Cat5e/6/6a and a Server Interface Unit so you can
control computers/servers located up to 100 ft. away from the switch. You can switch easily between the
16 ports using an on-screen display (OSD) or keyboard hot key commands. Multi-level password
protection prohibits unauthorized users from accessing the connected computers. The built-in 19” LCD
screen supports video resolutions up to 1366 x 768.
Add a Tripp Lite B051-000 IP Remote Access Unit and you’ll be able to connect to your servers from
anywhere in the world. The B070-016-19 stores neatly in a rack drawer and pulls out when needed. This
KVM console is compatible with all major operating systems. Heavy-duty steel housing stands up to
frequent use. Complies with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases.
Package Includes
Features
B070-016-19 1U rackmount
console KVM switch with 19”
LCD
C13 to 5-15P power cord
Mounts into 19”-wide rack, 27”-42” deep; can be mounted in 2-post rack with Tripp Lite’s B019-000
Serial firmware upgrade cable
Flip-up/fold-down screen keeps console from blocking access to rack equipment when not in use
Eliminates need to buy costly monitors, keyboards and mice for each computer/server
Jumper cable to connect KVM
console ports to integrated
console ports
Rackmount hardware
CD with owner's manual
Saves Space and Money
● Combines 16-port KVM switch, 19” LCD screen, keyboard and touchpad in a 1U rack-mountable drawer
– ideal when rack space is at a premium
Uses inexpensive Cat5e/6/6a Cables
● Low-cost cables lets you locate servers up to 100 ft. from the switch
Use plug-and-play Server Interface Unit B078-101-USB-1 (for USB) with each server that will be
connected with Cat5 cable
For computers with Displayport or HDMI, change to VGA using Tripp Lite adapters P134-06N-VGA-V2
1/5
Cleveland, OH 44122
United States
or P131-06N. Maximum video resolutions using adapters may vary.
Simplifies IT Tasks
● Switch easily between the 16 ports via on-screen display or keyboard hot key commands
Hot pluggable; add or remove USB computers without having to power down the switch
Auto-scan mode automatically sequences through all active ports accessible to the user
Large 19” LCD
● Extra-wide display makes multitasking easier
Supports video resolutions up to 1366 x 768
DDC emulation allows optimal output to the LCD
Multi-Level Password Security
● Multi-level password security limits access to authorized users (administrator, supervisor or user)
Two-level log-out allows manual log-out or automatic log-out after a user-defined period of time has
passed
Expandability and Long-Lasting Reliability
● Control your servers from anywhere in the world over LAN, WAN or the Internet by adding a Tripp Lite
Expandable - Cascade a second level of KVM switches to control up to 256 servers from a single
station using Tripp Lite's B072-008-1, B072-008-1A, B072-016-1 and/or B072-016-1A to increase the
number of ports.
Compatible with all major operating systems for easy integration into your existing structure
Firmware is upgradable with included cable and utility
Heavy-duty steel housing stands up to frequent use
TAA Compliant
● Complies with the Federal Trade Agreements Act for GSA Schedule purchases
Specifications
OVERVIEW
UPC Code
037332137883
Console
Yes
Max CPU
256
Technology
Cat5/5e; PS/2; VGA/SVGA
VIDEO
Max Supported Video Resolution
1366 x 768 @ 60Hz
Max. Distance (Between any 2
Units)
100 ft (30.5m)
Max Number of Ports (Entire Chain)
256
2/5
Cleveland, OH 44122
United States
INPUT
Voltage Compatibility (VAC)
100; 110; 120; 127; 200; 208; 220; 230; 240
Input Frequency
50/60Hz
Input Current
120V (1.4A) / 230V (0.8A)
Power Input Receptacle
IEC-320-C14
POWER
Power Consumption (Watts)
30
Power Consumption Detail
(Line Mode) 30W / (Standby Mode) 5W
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
Green (CAPS LOCK, SCROLL LOCK, NUM LOCK)
PHYSICAL
Color
Black
Material of Construction
Steel (Steel, Electrogalvanized, Cold Rolled, Coil)
LCD Monitor (in.)
19
Rackmountable
Yes
Shipping Dimensions (hwd / in.)
6.00 x 23.40 x 32.68
Shipping Dimensions (hwd / cm)
15.24 x 59.44 x 83.01
Shipping Weight (lbs.)
39.90
Shipping Weight (kg)
18.10
Unit Dimensions (hwd / in.)
1.710 x 17.690 x 28.440
Unit Packaging Type
Box
Unit Weight (lbs.)
31.00
Unit Weight (kg)
14.06
ENVIRONMENTAL
Storage Temperature Range
-40 to 158 F (-40 to 70 C)
Relative Humidity
0% to 80% RH, Non-Condensing
Operating Temperature
32 to 104 F (0 to 40 C)
BTUs
(Line Mode) 102 BTU/Hr / (Standby Mode) 17.1 BTU/Hr
COMMUNICATIONS
IP Remote Access
No
CONNECTIONS
3/5
Cleveland, OH 44122
United States
Number of Ports
16
PC/Server Connections
PS/2; USB; VGA
Side A - Connector 1
(2) HD15 (FEMALE)
Side A - Connector 2
(4) MINI DIN-6 (FEMALE)
Side A - Connector 3
RJ11 (FEMALE)
Side B - Connector 1
(16) RJ45 (FEMALE)
Computer Keyboard and Mouse
Interface
PS/2; USB
Computer Monitor Interface
VGA
PORT EXPANSION
Daisy-chainable or Cascadable
Cascadeable
FEATURES & SPECIFICATIONS
Autoscan (Y,N)
Y
Autoscan Duration
Variable
Number of Users
1
NIAP-Certified Secure
No
On-Screen Display (OSD)
Yes
Port Selection
Hotkey; OSD
Driver Required
No
Cat5 KVM Switch
Yes
Recommended Category Cable
Cat5e/6/6a Cables
BUILT-IN CONSOLE
Console Screen Size (inches)
19
Console Screen Aspect Ratio
16:9
STANDARDS & COMPLIANCE
Product Certifications
CAN/CSA C22.2; CAN/CSA-C22.2 No. 60950-1 (Canada); UL 60950-1
Product Compliance
RoHS; CE (Europe); REACH; FCC Part 15 Class A (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
4/5
Cleveland, OH 44122
United States
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
很抱歉,暂时无法提供与“B070-016-19”相匹配的价格&库存,您可以联系我们找货
