1000 Eaton Boulevard
Cleveland, OH 44122
United States
1U Rack-Mount Console with 17-in. LCD, Dual
Rail
MODEL NUMBER: B021-02R-17
Highlights
17" LCD Console with Dual Rail
- Screen stays up while
Keyboard retracts
Mounts in Racks 22 inches to 34
inches Deep
Supports Video Resolutions up
to 1280 x 1024 @ 75Hz
Plugs into USB or PS2
computer or KVM switch
Features a USB 1.1 peripheral
port on the front of the unit
System Requirements
Connected Computer/KVMA
● VGA (HD15) input
A USB A Female port, or two
PS/2 keyboard/mouse ports
External Console
● A monitor with a VGA (HD15)
input
Description
USB or PS/2 Keyboard and
Mouse
Tripp Lite's B021-02R-17, 1U Dual Rail, Rackmount Console features an integrated 17" LCD panel, full
88-key keyboard, and touch pad, all in a 1U rackmountable housing. This unit allows the screen to remain
open, while the keyboard portion is retracted into the rack. The console also features a USB 1.1 peripheral
Package Includes
B021-02R-17 17-in. USB/PS2
Dual Rail Console
Rackmount Hardware
USB/PS2 Console Cable Kit
RJ11 to DB9 Firmware Upgrade
Cable
C13 to 5-15P Power Cord
Grounding Wire
Owner’s Manual CD
port on the front of the keyboard panel, allowing for the connection of devices such as an external mouse
or flash drive. The included KVM cable kit allows for connection to a PS/2 or USB computer or KVM
switch. Constructed of heavy-duty steel housing.
Features
Integrated 17-in. LCD display, 99-key keyboard and touchpad in a 1U rackmountable housing.
Features a USB 1.1 peripheral port on the front of the unit, allowing for the connection of devices such
as an external mouse or flash drive.
Dual rail configuration allows for the keyboard and LCD panel to slide independently of each other,
which provides the ability to monitor computer activity while stowing keyboard module out of the way.
Can be mounted in racks with a depth ranging from 22-in. to 34-in.
Includes a USB/PS2 Combo KVM Cable Kit, allowing you to connect to a computer or KVM with either
USB or PS/2 connectors.
Compatible with all operating systems, and most KVMs with a VGA and USB or PS/2 ports.
Back panel of the unit includes external VGA, PS/2 (x2) and USB (x2) ports for connecting an external
console.
Supports video resolutions up to 1280 x 1024 @ 75Hz.
DDC, DDC2 and DDC2B emulation allows the video settings of the connected computer to be
automatically adjusted for optimal display on the console monitor.
Firmware upgradeable via the included firmware upgrade cable (RJ11 to DB9).
Features keyboard commands for SUN keyboard emulation.
1/3
Cleveland, OH 44122
United States
Specifications
OVERVIEW
UPC Code
037332159274
Technology
PS/2; VGA/SVGA
INPUT
Nominal Input Voltage(s) Supported
100V AC; 110V AC; 115V AC; 120V AC; 127V AC; 140V AC; 200V AC; 208V AC; 220V AC; 230V AC; 240V AC
Nominal Input Voltage Description
100-240V, 50/60Hz, 1A
Plug Type
C14
Input Frequency
50/60Hz
Input Current
120V (0.8A) / 230V (0.4A)
PHYSICAL
Color
Black
Included Mounting Accessories
Yes
LCD Monitor (cm)
43.18
LCD Monitor (in.)
17
Shipping Dimensions (hwd / in.)
5.50 x 28.30 x 26.50
Shipping Dimensions (hwd / cm)
13.97 x 71.88 x 67.31
Shipping Weight (lbs.)
44.50
Shipping Weight (kg)
20.18
Unit Dimensions (hwd / in.)
1.730 x 19.000 x 22.800
Unit Dimensions (hwd / cm)
4.39 x 48.26 x 57.91
ENVIRONMENTAL
Storage Temperature Range
-20 to 60 C ( -4 to 140 F )
Relative Humidity
0 to 90% RH, Non-Condensing
Operating Temperature
0 to 40 C ( 32 to 104 F )
COMMUNICATIONS
IP Remote Access
No
CONNECTIONS
Number of Ports
PC/Server Connections
VGA; USB; PS/2
2/3
Cleveland, OH 44122
United States
FEATURES & SPECIFICATIONS
Number of Users
1
NIAP-Certified Secure
No
Cat5 KVM Switch
No
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“B021-02R-17”相匹配的价格&库存,您可以联系我们找货
