B072-016-IP2
B072-016-IP2
    TRIPPLITE
    16-PORT CAT5 KVM OVER IP SWITCH
B072-016-IP2 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Free NetCommander-AXS Management Software is available for access and control of all of your Tripp Lite NetCommander IP KVM switches (B070 and B072 series). From a single interface, you can access Highlights ● 16 ports provide control of computers/servers locally or via your network or the Internet KVM settings. This software can be found on the model support page of the B072-016-IP2, or via ● Occupies just 1U of rack space searching NetCommander-AXS on www. Tripplite.com ● NetCommander 16-Port Cat5 KVM over IP Switch - 2 Remote + 1 Local User, 1U Rack-Mount Low-cost Cat5 cabling allows longer distances, reduces cable clutter ● MODEL NUMBER: B072-016-IP2 Simultaneous support for 3 users – 1 local, 2 remote ● Dual Ethernet ports and power supplies assure uninterrupted remote access ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases server ports on any of your KVM switches, power cycle or power on/off outlets of IP PDU's, and manage System Requirements Control up to 16 computers from virtually anywhere with one Cat5 KVM switch. This KVM switch with IP remote access is a smart solution for efficient server control. Low-cost Cat5 cables let you locate servers up to 100 ft. away. ● Computer with HD15 (VGA) port, and USB port or PS/2 keyboard/mouse ports ● User-supplied Cat5e/6/6a cabling ● B078-101-USB-1 or B078-101USB2 (USB) or B078-101-PS2 (PS/2) Server Interface Unit is required for each connected computer/server ● For computers with Displayport or HDMI, change to VGA using Tripp Lite adapters P134-06NVGA-V2 or P131-06N. Maximum video resolutions using adapters may vary. ● Compatible with Windows and Linux operating systems ● Remote access supported using Windows computers ● Remote console computers require minimum Pentium 4 with 2 GB memory Description Tripp Lite’s B072-016-IP2 KVM Switch is the optimal solution for controlling up to 16 computers/servers locally, from across the room, down the street or around the globe on a network or the Internet. This KVM switch can be accessed and controlled remotely, so there’s no need to travel to the server room or network closet. A Java-based application allows access via web browser from any secure IP connection; a non-browser client that can bypass browser-related Java Security prompts is available. The B072-016-IP2 uses inexpensive, user-supplied Cat5e/6/6a cabling with Server Interface Units (sold separately) so you can connect computers/servers located up to 100 ft. away from the switch. This switch features dual Ethernet ports and dual power supplies; if one fails, the other takes over, keeping access uninterrupted. Switch easily between the 16 ports using an on-screen display (OSD), hotkey commands or a remote toolbar. Multi-level password protection prohibits unauthorized users from accessing connected computers, and a local user and up to two remote users can each log on and access different ports simultaneously. Two serial ports allow control of serial-manageable devices such as IP PDUs, firewalls and routers; individual ports can be assigned to an IP PDU port to power on/off the server connected to that port. This KVM switch is compatible with Windows and Linux operating systems, and provides remote access using a Windows computer. It supports VGA video resolutions up to 1920 x 1080 @ 60 Hz. Heavy-duty steel housing stands up to frequent use. Virtual Media allows an .iso file to be mounted to a target server and accessed as if it were stored directly on it. Virtual Media data transfer rates up to 12Mbps are supported when using a B078-101-USB2 Server Interface Unit. Other features include RADIUS and LDAP/S authentication, system-sent SNMP messaging and an event log that tracks logins, reboots and network setting changes. Free NetCommander-AXS Management Software is available to access and control all of your Tripp Lite NetCommander IP KVM switches (B070 and B072 series). From a single interface, you can access server ports on any of your KVM switches, power cycle or power on/off outlets of IP PDUs and manage KVM settings. This software can be downloaded free of charge from the model support page for the B072-016IP2. Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. 1/5 Package Includes ● B072-016-IP2 16-Port Cat5 2+1 User 1U Rack-Mount KVM Switch with IP Remote Access ● C13 to 5-15P Power Cords (x2) ● Rack-Mount Hardware ● CD with Owner's Manual ● Quick Start Guide 1000 Eaton Boulevard Cleveland, OH 44122 United States Features Saves Space and Money ● Mounts in a standard 19 in. rack ● Inexpensive Cat5e/6/6a cabling lets you locate servers up to 100 ft. from the switch ● Use a Server Interface Unit, B078-101-USB-1 or B078-101-USB2 (for USB) or B078-101-PS2 (for PS/2) with each server that will be connected with Cat5 cable ● To convert DisplayPort or HDMI computers to VGA, use Tripp Lite adapters P134-06N-VGA-V2 or P131-06N. Maximum video resolutions using adapters may vary. IP Remote Access for Fewer Trips to the Server Room ● Remote access means there’s no need to travel to the server room or network closet ● Java-based application allows Windows computers to control a target server via web browser from any location over a secured IP connection ● A non-browser client is available that allows Windows computers to remotely access the KVM without the need for a browser and without the need to install Java ● 1 local + 2 remote users can access different ports concurrently; up to 5 users can share a single remote session ● Supports both IPv4 and IPv6 Simplifies IT Tasks ● On-screen display, hot keys and remote toolbar for easy use ● Free NetCommander-AXS Management Software gives you remote access and control over all your Tripp Lite NetCommander IP KVM switches (B070 and B072 series) ● Video resolutions up to 1920 x 1080 @ 60 Hz are supported ● 2 serial ports allow control of serial-manageable devices such as IP PDUs, firewalls and routers; assign individual ports to an IP PDU port to power on/off the server connected to that port ● BIOS-level control of any brand and model server, regardless of the server’s condition and network connectivity ● Virtual Media allows an .iso file to be mounted to a target server and accessed as if it were directly stored on it ● Virtual Media data transfer rates up to 12Mbps are supported when using a B078-101-USB2 Server Interface Unit; a B078-101-USB-1 Server Interface Unit can be used for Virtual Media support, but only at speeds up to 1Mbps ● Fast Virtual Media KVM System patented under Pat. No. US 9,417,720 ● System-sent messages to SNMP server notify you of network failures ● Supports RADIUS and LDAP/S authentication ● Log tracks events such as logins, reboots and network setting changes on your installation Advanced Security Features ● Multi-level password protection: create administrator accounts with full access and user accounts with limited access ● Supports TLS 1.2 security protocol ● You can install SSL certificates to ensure secure transactions between web servers and browsers Built to Last ● Flash-upgradable firmware over the network ● Heavy-duty steel housing stands up to frequent use ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332177278 Technology Cat5/5e; PS/2; VGA/SVGA VIDEO Max Supported Video Resolution Local : 1920 x 1200 @60Hz ; Remote : 1920 x 1080 @60Hz INPUT Voltage Compatibility (VAC) 100; 110; 120; 127; 200; 208; 220; 230; 240 Input Frequency 50/60Hz Input Current 120V (0.7A) / 230V (0.3A) Power Input Receptacle IEC-320-C14 Redundancy - Dual Power Inputs Yes POWER Power Consumption (Watts) 50 USER INTERFACE, ALERTS & CONTROLS LED Indicators Blue (Power) PHYSICAL Color Black Material of Construction Steel (Steel, Electrogalvanized, Cold Rolled, Coil) Rackmountable Yes Shipping Dimensions (hwd / in.) 4.30 x 13.90 x 23.00 Shipping Dimensions (hwd / cm) 10.92 x 35.31 x 58.42 Shipping Weight (lbs.) 10.00 Shipping Weight (kg) 4.54 Unit Dimensions (hwd / in.) 1.710 x 17.280 x 10.990 Unit Packaging Type Box Unit Weight (lbs.) 7.50 Unit Weight (kg) 3.40 ENVIRONMENTAL Storage Temperature Range -40 to 158 F (-40 to 70 C) Relative Humidity 0% to 80% RH, Non-Condensing Operating Temperature 32 to 104 F (0 to 40 C) 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States BTUs 171 BTU/Hr COMMUNICATIONS IP Remote Access Yes Network Compatibility 100 Mbps (Fast Ethernet) CONNECTIONS Number of Ports 16 PC/Server Connections PS/2; USB; VGA Side A - Connector 1 (16) RJ45 (FEMALE) Side B - Connector 1 (1) HD15 (FEMALE) Side B - Connector 2 (4) RJ45 (FEMALE) Side B - Connector 3 (2) USB A (FEMALE) Computer Keyboard and Mouse Interface PS/2; USB Computer Monitor Interface VGA Console Keyboard and Mouse Interface USB Console Monitor Interface VGA FEATURES & SPECIFICATIONS Number of Users 3 NIAP-Certified Secure No On-Screen Display (OSD) Yes Port Selection Hotkey; OSD USB Specification USB 2.0 (up to 480 Mbps) Driver Required No Authentication Supported RADIUS; LDAPS Cat5 KVM Switch Yes Recommended Category Cable Cat5e/6/6a Cables REMOTE ACCESS Virtual Media Speed Up to 12 Mbps (using B078-101-USB2) STANDARDS & COMPLIANCE Product Certifications CAN/CSA C22.2; CAN/CSA-C22.2 No. 60950-1 (Canada); UL 60950-1 Product Compliance RoHS; CE (Europe); REACH; FCC Part 15 Class A (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
B072-016-IP2 价格&库存
很抱歉,暂时无法提供与“B072-016-IP2”相匹配的价格&库存,您可以联系我们找货
