B070-008-19-IP
B070-008-19-IP
    TRIPPLITE
    KVM SWITCH 1U 19" MON/KYBD/TCHPD
B070-008-19-IP 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States For best results, STP (Shielded Twisted Pair) Cat5e or higher cabling is recommended like Tripp Lite's N105-Series, N125-Series or N262-Series. Free NetCommander-AXS Management Software is available for access and control of all of your Tripp Lite NetCommander IP KVM switches (B070 and B072 series). From a single interface, you can access server ports on any of your KVM switches, power cycle or power on/off outlets of IP PDU's, and manage KVM settings. This software can be found on the model support page of the B070-008-19-IP, or via searching NetCommander-AXS on tripplite.com NetCommander 8-Port Cat5 KVM over IP Switch 19 in. LCD, 1 Remote + 1 Local User, 1U RackMount Highlights ● Control computers/servers locally or via LAN, WAN or Internet ● Occupies just 1U of space in a rack-mountable drawer ● Low-cost Cat5 cabling allows longer distances, reduces cable clutter ● 19” LCD screen supports video resolutions up to 1366 x 768 ● Simultaneous support for 2 users – 1 local, 1 remote ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases ● Free Management Software available to Access and Control all of your Tripp Lite NetCommander IP KVM's (B070 and B072 IP series) from a single interface ● Fast Virtual Media KVM System patented under Pat. No. US 9,417,720 MODEL NUMBER: B070-008-19-IP System Requirements Control up to 8 computers from virtually anywhere with one Cat5 KVM switch with integrated console. This KVM switch with IP remote access is a smart solution for efficient server control. Low-cost Cat5 cables let you locate servers up to 100 ft. away. ● Computer with HD15 port, and USB port or PS/2 keyboard/mouse ports ● User-supplied Cat 5e/6/6a cabling ● B078-101-USB-1 (USB) Server Interface Unit is required for each connected computer/server ● For computers with Displayport or HDMI, change to VGA using Tripp Lite adapters P134-06NVGA-V2 or P131-06N. Maximum video resolutions using adapters may vary. ● Compatible with Windows and Linux operating systems ● Remote access supported using Windows computers ● Remote console computers require minimum Pentium 4 with 2 GB memory ● Power consumption: 120V, 60Hz, 30W Description Tripp Lite’s B070-008-19-IP KVM Switch gives you a rack-mountable full keyboard, LCD and touchpad in a single console that occupies only 1U of rack space. Easy to install and use, it’s the optimal solution for controlling up to 8 computers/servers locally, from across the room, down the street or halfway around the globe on a LAN, WAN or Internet. The B070-008-19-IP uses inexpensive, user-supplied Cat5e/6/6a cabling with Server Interface Units so you can control computers/servers located up to 100 ft. away from the switch. This switch features two 10/100 Mbps LAN ports, so if one fails, the other takes over, keeping remote access uninterrupted. Users can switch easily between the 8 ports using an on-screen display (OSD). Multi-level password protection prohibits unauthorized users from accessing the connected computers, and a local user and a remote user can be logged on simultaneously. The built-in 19“ LCD screen supports video resolutions up to 1366 x 768. Two serial ports allow control of serial-manageable devices such as IP PDUs, firewalls and routers; you can assign individual ports to an IP PDU port to power on/off the server connected to that port. The B070008-19-IP stores neatly in a rack drawer and pulls out when needed. This KVM console is compatible with both Windows and Linux operating systems, and provides remote access using a Windows computer. Heavy-duty steel housing stands up to frequent use. Complies with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. Free NetCommander-AXS Management Software is available for access and control of all of your Tripp Lite NetCommander IP KVM switches (B070 and B072 series). From a single interface, you can access server ports on any of your KVM switches, power cycle or power on/off outlets of IP PDU's, and manage KVM settings. This software can be found on the model support page of the B070-008-19-IP, or via searching NetCommander-AXS on tripplite.eaton.com Features 1/5 Package Includes ● B070-008-19-IP 1U rackmount console KVM switch with 19” LCD 1000 Eaton Boulevard Cleveland, OH 44122 United States Saves Space and Money ● Combines 8-port KVM switch, 19” LCD screen, keyboard and touchpad in a single 1U rack-mountable drawer ● Mounts into 19”-wide rack, 27”-42” deep; to mount in a 2-post rack, use Tripp Lite’s B019-000 ● Inexpensive Cat5e/6/6a cabling lets you locate servers up to 100 ft. from the switch ● Use Server Interface Unit B078-101-USB-1 (for USB) with each server that will be connected with Cat5 cable ● For computers with Displayport or HDMI, change to VGA using Tripp Lite adapters P134-06N-VGA-V2 or P131-06N. Maximum video resolutions using adapters may vary. IP Remote Access for Fewer Trips to the Server Room ● Remote access means there’s no need to travel to the server room or network closet ● Java-based application allows Windows computers to control a target server via web browser from any location over a secured IP connection ● A non-browser client is available that allows Windows computers to remotely access the KVM without the need for a browser and without the need to install Java ● 1 local + 1 remote user can access different ports concurrently; up to 5 users can share a single session ● Supports both IPv4 and IPv6 ● Free Management Software available to Access and Control all of your Tripp Lite NetCommander IP KVM's (B070 and B072 IP series) from a single interface Simplifies IT Tasks ● On-screen display, hot keys and remote toolbar for easy use ● 2 serial ports allow control of serial-manageable devices such as IP PDUs, firewalls and routers ● Add IP PDUs as devices that can be controlled by the KVM; assign individual ports to an IP PDU port to power on/off the server connected to that port ● Virtual Media allows a .iso file to be mounted to a target server and accessed as if it were directly stored on it ● Fast Virtual Media KVM System patented under Pat. No. US 9,417,720 ● System-sent messages to SNMP server notify you of LAN failures ● Supports RADIUS and LDAP/S authentication ● Log tracks events on your installation Large 19” LCD ● Supports video resolutions up to 1366 x 768; 1920 x 1080 remotely ● DDC emulation allows for optimal output to LCD Advanced Security Features ● Multi-level password protection: create administrator accounts with full access and user accounts with limited access ● Supports TLS 1.2 security protocol ● You can install SSL certificates to ensure secure transactions between web servers and browsers Expandability and Long-Lasting Reliability ● Flash-upgradeable firmware over the network ● Heavy-duty steel housing stands up to use 2/5 ● C13 to 5-15P power cord ● Rackmount hardware ● CD with owner's manual ● Quick start guide 1000 Eaton Boulevard Cleveland, OH 44122 United States TAA Compliant ● Complies with the Federal Trade Agreements Act for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332181879 Console Yes Technology Cat5/5e; PS/2; VGA/SVGA VIDEO Max Supported Video Resolution Console: 1366 x 768 @60Hz; Remote: 1920 x 1080 @60Hz INPUT Voltage Compatibility (VAC) 100; 110; 120; 127; 200; 208; 220; 230; 240 Input Frequency 50/60Hz Input Current 120V (1.2A) / 230V (0.7A) Power Input Receptacle IEC-320-C14 POWER Power Consumption (Watts) 30 Power Consumption Detail (Line Mode) 30W / (Standby Mode) 5W USER INTERFACE, ALERTS & CONTROLS LED Indicators Green (CAPS LOCK, SCROLL LOCK, NUM LOCK) PHYSICAL Color Black Material of Construction Steel (Steel, Electrogalvanized, Cold Rolled, Coil) Rackmountable Yes Shipping Dimensions (hwd / in.) 6.10 x 23.30 x 32.25 Shipping Dimensions (hwd / cm) 15.49 x 59.18 x 81.92 Shipping Weight (lbs.) 39.90 Shipping Weight (kg) 18.10 Unit Dimensions (hwd / in.) 1.710 x 17.360 x 28.430 Unit Packaging Type Box Unit Weight (lbs.) 29.00 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Weight (kg) 13.15 ENVIRONMENTAL Storage Temperature Range -40 to 158 F (-40 to 70 C) Relative Humidity 0% to 80% RH, Non-Condensing Operating Temperature 32 to 104 F (0 to 40 C) BTUs (Line Mode) 102 BTU/Hr / (Standby Mode) 17.1 BTU/Hr COMMUNICATIONS IP Remote Access Yes Network Compatibility 100 Mbps (Fast Ethernet) CONNECTIONS Number of Ports 8 PC/Server Connections PS/2; USB; VGA Side A - Connector 1 (8) RJ45 (FEMALE) Side B - Connector 1 (4) RJ45 (FEMALE) Side B - Connector 2 (1) USB A (FEMALE) Computer Keyboard and Mouse Interface PS/2; USB Computer Monitor Interface VGA Console Keyboard and Mouse Interface PS/2; USB FEATURES & SPECIFICATIONS Autoscan (Y,N) N Number of Users 2 NIAP-Certified Secure No On-Screen Display (OSD) Yes Port Selection Pushbutton; Hotkey; OSD USB Specification USB 2.0 (up to 480 Mbps) Authentication Supported RADIUS; LDAPS Cat5 KVM Switch Yes Recommended Category Cable Cat5e/6/6a Cables BUILT-IN CONSOLE Console Screen Size (inches) 19 Console Screen Aspect Ratio 16:9 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States REMOTE ACCESS Virtual Media Speed Up to 12 Mbps (using B078-101-USB2) STANDARDS & COMPLIANCE Product Certifications CAN/CSA C22.2; CAN/CSA-C22.2 No. 60950-1 (Canada); UL 60950-1 Product Compliance RoHS; CE (Europe); REACH; FCC Part 15 Class A (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
B070-008-19-IP 价格&库存
很抱歉,暂时无法提供与“B070-008-19-IP”相匹配的价格&库存,您可以联系我们找货
