B064-032-02-IPG
B064-032-02-IPG
    TRIPPLITE
    32-PORT CAT5 KVM OVER IP SWITCH
B064-032-02-IPG 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Free NetDirector-AXS Management Software is available for access and control of select Tripp Lite NetDirector IP KVM switches (B064-IPG series). From a single interface, you can access server ports on Highlights ● Simultaneous support for 3 users (1 local, 2 remote) ● Supports IPv4, Link Local IPv6 Address and IPv6 Stateless Auto configuration protocols ● Includes both DVI and VGA console ports for connection of either a DVI or VGA monitor ● Blade server support ● Virtual Media allows computers connected using a B055-001USB-V2 SIU to access DVD/CD drives, flash drives and other storage media from a user's remote computer as if it were directly connected ● Remote Authentication: RADIUS, LDAP, LDAPS, and Active Directory ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases any of your supported KVM switches and manage the KVM settings. This software may be found on the model support page of the B064-032-02-IPG or by searching for AXS IP KVM Software on this website. NetDirector 32-Port Cat5 KVM over IP Switch Virtual Media, 2 Remote + 1 Local User, 1U RackMount, TAA MODEL NUMBER: B064-032-02-IPG System Requirements ● Remote Console Computers (Web Browser) - To access the KVM switch via web browser, your computer needs to be running Sun's Java Runtime Environment (JRE) v.6, Update 3 or higher, and your browser must support 128-bit SSL encryption. ● Browsers - The NetDirector Cat5 IP KVM switch supports the following browsers; Internet Explorer 6 and higher, Firefox 1.5 and higher, Mozilla 1.7 and higher, Safari 2.0 and higher, Opera 9.0 and higher, and Netscape 8.1 and higher. ● Remote Console Computers (non-Browser Windows or Java Client) - To access the KVM switch using the non-browser based Windows client, your computer/server must be running Windows, and DirectX 7.0 or higher must be installed. To access the non-browser based Java client, your computer must be running Sun's Java Runtime Environment (JRE) v.6, Update 3 or higher. ● Connected Computers/Servers Computers/servers being connected to the KVM switch must have a Displayport, DVI, HDMI or VGA port and USB or Description Tripp Lite's 32-port NetDirector Cat5 IP KVM Switch is the optimal solution for remotely controlling multiple computers (combination of PS/2, USB and Serial) by up to 3 (1 Local and 2 Remote) independent, simultaneous users. Both DVI and VGA console ports are included for connection of either a DVI or VGA monitor. High video resolution: up to 1600 x 1200 @ 60Hz – 32 bit color depth for the local console; up to 1600 x 1200 @ 60Hz with 24 bit color depth for remote sessions at up to 164 ft. (50 m). A full-screen graphical OSD with multi-level authentication (Super Administrator, Administrator and User) allows you to quickly and efficiently manage your installation, and can be displayed in English, German, Russian, Japanese, traditional Chinese and simplified Chinese. Critical events on the installation can be tracked via email notification, SNMP traps, the Windows-based log server or Syslog server. Accessing the connected computers is a breeze; view multiple computers at the same time using panel array mode, automatically sync USB mice, access the on-screen keyboard feature in numerous language formats. Virtual Media allows computers connected using a B055-001-USB-V2 Server Interface Unit to access DVD/CD drives, flash drives and other storage media as if they were directly connected to the computer. In addition, three USB ports are located on the front panel of the unit for use with Virtual Media or an external keyboard and mouse. Also located on the front of the KVM is a USB Mini-B port that allows for direct connection of a laptop for easy console operation of the switch. Other features include FIPS 140-2 level 1 security standards support, dual power supplies that allow the unit to continue running in the event one power supply stops receiving power, temperature sensors that control the speed of the unit's cooling fans, remote authentication support via RADIUS, LDAP, LDAPS and Active Directory, dial-in modem access and non-browser access using Windows and Java applications. Constructed of heavy-duty steel housing. Features ● Up to 3 users (1 Local, 2 Remote) can simultaneously access the connected computers/servers ● Features two RJ45 network ports for redundant or dual-IP operation ● Includes both DVI and VGA console ports for connection of either a DVI or VGA monitor ● High video resolution: up to 1600 x 1200 @ 60Hz – 32 bit color depth for the local console; up to 1600 x 1200 @ 60Hz with 24 bit color depth for remote sessions at up to 164 ft. (50 m) 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Supports IPv4, Link Local IPv6 Address and IPv6 Stateless Auto configuration protocols ● Blade server support ● Multi-level authentication; Super Administrator, Administrator and User ● Advanced encryption technologies - 1024 bit RSA; 56 bit DES; 256 bit AES and 128 bit SSL ● Supports FIPS 140-2 level 1 security standards ● View multiple ports at the same time using the panel array mode feature ● Virtual Media allows computers connected to the KVM using a B055-001-USB-V2 SIU to access DVD/CD drives, flash drives and other storage media from a user's remote computer as if it were directly connected ● An additional three USB ports are located on the front of the KVM for the sharing of USB peripherals. ● Also located on the front of the KVM is a USB Mini-B port that allows for direct connection of a laptop for easy console operation of the switch. ● Remote authentication support; RADIUS, LDAP, LDAPS and Active Directory ● Track critical events on the installation via email notification, SNMP traps, Windows-based Log Server or Syslog server ● Dual power supplies allow the unit to continue running in the event one power supply ceases to receive power ● Built-in sensors increase/decrease the speed of the unit's cooling fans according to the temperature ● Dial-in / Dial-out modem support ● Graphical OSD can be displayed in English, German, Russian, Japanese, traditional Chinese and simplified Chinese ● Features an on-screen keyboard with numerous language formats ● Supports 10Base-T, 100Base-T, 1000Base-T, Auto-Sense, TCP/IP, HTTP, DNS, DHCP, UDP, ARP and Ping ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases ● ● PS/2 Keyboard and Mouse ports. ● Operating Systems - Compatible with all major operating systems ● B055-001-USB, B055-001-USBV2, B055-001-SER, or B055001-PS2 (PS/2) Server Interface Unit is required for each connected computer/server ● Hardware versions: A new hardware version (v2) of the B064-032-02-IPG was released in 2016, and it requires different firmware than was used in the previous version (v1). In the Technical Support page for the B064-032-02-IPG you will find a zip folder for the v1 KVM. In addition to including the applicable firmware, it contains a Word document that will tell you how to determine which hardware version you have, and therefore, which firmware you need to use. If you have a v2 KVM, the latest firmware is that which came pre-installed on the KVM. Package Includes ● B064-032-02-IPG (2+1 User) NetDirector Cat5 IP KVM switch Compatible with all major operating systems ● (x2) C13 to 5-15P power cords Constructed of heavy-duty steel housing ● CD with owner's manual, quick start guide and device files ● Quick start guide ● RJ45 to DB9 adapter for dial-In modem functionality ● Grounding wire ● Set of foot pads ● Rackmount hardware Specifications OVERVIEW UPC Code 037332151537 Max CPU 32 Technology Cat5/5e; DVI; PS/2; VGA/SVGA VIDEO Max Supported Video Resolution 1600 x 1200 @60Hz 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States INPUT Nominal Input Voltage(s) Supported 100V AC; 110V AC; 115V AC; 120V AC; 127V AC; 140V AC; 200V AC; 208V AC; 220V AC; 230V AC; 240V AC Input Frequency 50/60Hz Input Current 120V (0.8A) / 230V (0.4A) Power Input Receptacle IEC-320-C14 PHYSICAL Color Black Shipping Dimensions (hwd / in.) 5.20 x 20.20 x 22.60 Shipping Dimensions (hwd / cm) 13.21 x 51.31 x 57.40 Shipping Weight (lbs.) 16.50 Shipping Weight (kg) 7.48 Unit Dimensions (hwd / in.) 1.720 x 17.060 x 16.270 Unit Dimensions (hwd / cm) 4.45 x 43.18 x 40.64 Unit Weight (lbs.) 12.10 Unit Weight (kg) 5.49 ENVIRONMENTAL Storage Temperature Range -20 to 60 C (-4 to 140 F) Relative Humidity 0 to 80% RH, Non-Condensing Operating Temperature 0 to 40 C (32 to 104 F) COMMUNICATIONS Port Control Push Buttons, Hotkeys, OSD IP Remote Access Yes CONNECTIONS Number of Ports 32 Computer/Server Ports (x32) RJ45 Female PC/Server Connections DVI; Serial; USB; VGA Side A - Connector 1 (32) RJ45 (FEMALE) Side B - Connector 1 (1) DVI-D DUAL LINK (FEMALE) Side B - Connector 2 (1) HD15 (FEMALE) Side B - Connector 3 (5) USB A (FEMALE) Side B - Connector 4 (3) RJ45 (FEMALE) Side B - Connector 5 (2) 3.5MM (FEMALE) 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Local Console Ports - Port 3 (x2) PS/2 Female (via B015-000, sold separately)) FEATURES & SPECIFICATIONS Autoscan (Y,N) Y Autoscan Duration User-definable from 1 to 255 seconds; default of 5 seconds Number of Users 3 NIAP-Certified Secure No Cat5 KVM Switch Yes STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL Listed Product Compliance RoHS; CE (Europe); FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B064-032-02-IPG 价格&库存
很抱歉,暂时无法提供与“B064-032-02-IPG”相匹配的价格&库存,您可以联系我们找货
