0SU52091
0SU52091
    TRIPPLITE
    MINICOMSMARTRACK16-PORTCAT5
0SU52091 数据手册
SmartRack 116 16-Port Console Cat5 KVM with 17-in. LCD MODEL NUMBER: 0SU52091 Highlights ● 16 Port KVM ● 17" TFT LCD Display ● BIOS level access ● Multi-platform – PS/2 and USB support ● Extends distance between servers and switch up to 30 meters/100 feet ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases System Requirements Operating System ● Compatible with Windows, Linux, Unix and all other major operating systems Resolution Description ● Local Access Supports video resolutions up to 1280 x 1024 Package Includes ● SmartRack 116 Cat5 KVM Switch ● RS232 Download Cable ● Rackmount Kit ● Owner's Manual Control More Servers Slim, 1U Solution that Saves Space Features ● 16 Port KVM ● 17" TFT LCD Display ● BIOS level access ● Multi-platform – PS/2 and USB support ● Extends distance between servers and switch up to 30 meters/100 feet ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 654518211344 1/2 Console Yes PHYSICAL Color Black Shipping Weight (kg) 19.00 Shipping Weight (lbs.) 41.89 Unit Dimensions (hwd / in.) 1.7 x 17.6 x 25.2 Unit Dimensions (hwd / cm) 4.4 x 44.75 x 64 Unit Weight (lbs.) 40.1 Unit Weight (kg) 18.19 ENVIRONMENTAL Storage Temperature Range -40 to 70 C / -40 to 158 F Relative Humidity 10 to 90% RH Operating Temperature 0 to 40 C / 32 to 104 F COMMUNICATIONS Port Control Hotkeys, OSD IP Remote Access No CONNECTIONS Number of Ports 16 PC/Server Connections VGA; USB; PS/2 FEATURES & SPECIFICATIONS Number of Users 1 NIAP-Certified Secure No Cat5 KVM Switch Yes WARRANTY Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
0SU52091
PDF文档中提到的物料型号为“0SU52091”,是Tripp Lite品牌的SmartRack 116 16-Port Console Cat5 KVM with 17-in. LCD。
它支持BIOS级别访问,兼容PS/2和USB平台,扩展服务器与交换机之间的距离可达30米/100英尺,符合联邦贸易协议法(TAA)适用于GSA日程购买。
该产品具有以下特点: - 16端口KVM和17英寸TFT LCD显示屏 - 支持视频分辨率高达1280 x 1024 - 节省空间的1U解决方案 - 提供RS232下载电缆、机架安装套件和用户手册
物理规格包括黑色外观、1.7x17.6x25.2英寸的尺寸、4.4x44.75x64厘米的尺寸、40.1磅的单位重量、18.19千克的单位重量。
环境规格包括存储温度范围为-40至70摄氏度/-40至158华氏度,相对湿度为10至90%RH,操作温度为0至40摄氏度/32至104华氏度。
通讯规格包括热键、OSD端口控制,不支持IP远程访问。
连接规格包括16个端口,PC/服务器连接包括VGA、USB、PS/2。
功能和规格包括1个用户数,3年有限保修期。
请注意,Tripp Lite有持续改进的政策,规格如有变更,恕不另行通知。
0SU52091 价格&库存
很抱歉,暂时无法提供与“0SU52091”相匹配的价格&库存,您可以联系我们找货
