B020-016-17-IP
B020-016-17-IP
    TRIPPLITE
    NETDIRECTOR 17" CONSOLE KVM
B020-016-17-IP 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States NetDirector 16-Port 1U Rack-Mount Console KVM Switch with 17-in. LCD and IP Remote Access MODEL NUMBER: B020-016-17-IP Highlights ● Control computers/servers locally or via LAN, WAN or Internet ● Occupies just 1U of space in a rack-mountable, dual-rail drawer ● 17” LCD screen supports video resolutions up to 1280 x 1024 ● Allows up to 64 authorized users and 32 concurrent remote logins ● Compatible with all operating systems System Requirements Control up to 16 computers from anywhere in the world with a single KVM switch with integrated console. ● PS/2 or USB computer with VGA, SVGA or MultiSync video graphics card with HD15 port ● (1) P774-Series (PS/2) or P776Series (USB) KVM Cable Kit is required for each connected computer/server ● Computers that access the KVM remotely should have at least a Pentium III, 1GHz processor, with screen resolution set to 1024 x 768 ● If remote computer is accessing the switch with Windows Client, DirectX 7.0 or higher is needed; if accessing the switch with Java Client, Sun’s Java 2 (1.4.2 or higher) runtime environment must be installed ● Browsers must support 128-bit encryption ● A network transfer speed of 128 Kbps or higher is recommended ● Compatible with all major operating systems ● Power consumption: 120V, 60Hz, 31W; 230V, 50Hz, 39W This KVM switch with IP remote access is a smart solution for secure server control that saves rack space and money. Description Tripp Lite’s B020-016-17-IP KVM Switch gives you a rack-mountable keyboard, LCD and touchpad in a single console that occupies only 1U of rack space. From across the room, down the street or halfway around the globe, the B020-016-17-IP can be accessed from any computer on the LAN, WAN or Internet. Easy to install and use, it’s the optimal solution for controlling up to 16 computers/servers. The B020-016-17-IP has a built-in 17” LCD screen that supports video resolutions up to 1280 x 1024 and remote monitor resolutions up to 1600 x 1200. You can switch easily between the 16 ports using onconsole push buttons, an on-screen display (OSD) or keyboard hot key commands. Up to 64 users can be authorized and 32 remote users can be logged on concurrently when multi-user operation is enabled, with multi-level password security. RADIUS server authentication is supported. This switch controls PS/2 or USB computers/servers using a P774-Series (PS/2) or P776-Series (USB) Package Includes ● B020-016-17-IP 16-Port Console KVM Switch with 17" LCD and built-in IP access ● P774-Series 6 ft. PS/2 KVM Cable Kit GSA Schedule purchases. ● P776-Series 6 ft. USB KVM Cable Kit Features ● C13 to 5-15P power cord ● Owner’s Manual CD KVM Cable Kit (one of each is included). When not in use, the B020-016-17-IP stores neatly in a rack drawer and pulls out when needed. With its dual-rail design, you can slide the keyboard into the rack, while the monitor stays visible. This KVM console is compatible with all major operating systems. Heavyduty steel housing stands up to frequent use. Complies with the Federal Trade Agreements Act (TAA) for Saves Space and Money ● Combines 16-port KVM switch, 17" LCD screen, keyboard and touchpad in a 1U rack-mountable drawer – ideal when rack space is at a premium ● Mounts into 19”-wide rack, 26.5”-30” deep 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Flip-up/fold-down screen keeps the console from blocking access to rack equipment when not in use; dual-rail design lets you push in the keyboard while the LCD stays open IP Remote Access for Fewer Trips to the Server Room ● Remote access offers convenience of controlling servers from anywhere…no need to travel to the server room or network closet ● Supports both IPv4 and IPv6 and network interfaces TCP/IP, HTTP, HTTPS, UDP, RADIUS, DHCP, SSL, ARP, DNS, 10Base-T/100Base-TX, Auto Sense and Ping Simplifies IT Tasks ● Switch easily between the 16 ports via on-console buttons, on-screen display or hot keys ● Panel array mode lets you monitor multiple ports at the same time ● Hot pluggable; add or remove computers without powering down the switch ● Auto-scan mode automatically sequences through all active ports accessible to the user ● Windows-based log server tracks events on your installation Large 17” LCD ● Wide display makes multitasking easier ● Supports video resolutions up to 1280 x 1024; remote monitor resolutions up to 1600 x 1200 ● DDC emulation allows settings of each computer to be automatically adjusted for optimal output to LCD Advanced Security Features ● Includes password protection and advanced encryption: 1024-bit RSA, 256-bit AES, 56-bit DES, and 128-bit SSL ● Supports RADIUS server authentication ● Allows up to 64 user accounts; with multi-user operation enabled, up to 32 users can log on at one time Expandability and Long-Lasting Reliability ● Compatible with all major operating systems for easy integration into your existing structure ● Flash firmware is upgradable over a network connection ● Heavy-duty steel housing stands up to frequent use TAA Compliant ● Complies with Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332146908 Console Yes Max CPU 16 Technology PS/2; VGA/SVGA 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States INPUT Nominal Input Voltage(s) Supported 100V AC; 110V AC; 115V AC; 120V AC; 127V AC; 140V AC; 200V AC; 208V AC; 220V AC; 230V AC; 240V AC Recommended Electrical Service 100-250V Maximum Input Amps 1 Input Frequency 50/60Hz Input Current 120V (0.8A) / 230V (0.4A) PHYSICAL Color Black LCD Monitor (cm) 43.18 LCD Monitor (in.) 17 Shipping Dimensions (hwd / in.) 6.00 x 27.00 x 33.00 Shipping Dimensions (hwd / cm) 15.24 x 68.58 x 83.82 Shipping Weight (lbs.) 46.00 Shipping Weight (kg) 20.87 Unit Dimensions (hwd / in.) 1.750 x 17.000 x 26.500 Unit Dimensions (hwd / cm) 4.45 x 48.26 x 70.61 Unit Weight (lbs.) 38.1 Unit Weight (kg) 17.28 ENVIRONMENTAL Storage Temperature Range -20 to +60 degrees C Relative Humidity 0% to 80% RH, Non-condensing Operating Temperature 0 to 40 degrees C BTUs 100.7 to 102.42 COMMUNICATIONS Port Control Push Buttons, Hotkeys, OSD IP Remote Access Yes CONNECTIONS Number of Ports 16 Computer/Server Ports (x16) HD15 Female PC/Server Connections PS/2; USB; VGA FEATURES & SPECIFICATIONS 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Autoscan (Y,N) Y Autoscan Duration 1 - 255 Seconds Number of Users 1 NIAP-Certified Secure No Cat5 KVM Switch No WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B020-016-17-IP 价格&库存
很抱歉,暂时无法提供与“B020-016-17-IP”相匹配的价格&库存,您可以联系我们找货
