B020-U08-19-IP
B020-U08-19-IP
    TRIPPLITE
    CONSOLE IP KVM SWITCH W/ 19" LCD
B020-U08-19-IP 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States To obtain a copy of the owner’s manual for your B020-U08-19-IP or B020-U16-19-IP KVM, please contact Product/Technical Support – (773) 869-1234. You will need to have the serial number for your product at Highlights ● Control computers/servers locally or via LAN, WAN or Internet ● Occupies just 1U of space in a rack-mountable drawer ● 19” LCD screen supports video resolutions up to 1280 x 1024 ● Allows up to 64 user accounts, with multi-level security ● Compatible with all operating systems the time of the call. Should you experience any inconsistencies in upgrading firmware or lengthy load times, please contact the Product/Tech Support team at Tripp Lite. NetDirector 8-Port 1U Rack-Mount Console KVM Switch with 19-in. LCD and IP Remote Access MODEL NUMBER: B020-U08-19-IP System Requirements ● Servers being connected to the KVM must have a HD15 port, and a USB port or PS/2 Keyboard/Mouse ports; a P778Series combo KVM cable kit is required for each connected computer ● Computers that access the KVM remotely should have at least a Pentium III, 1GHz processor ● If remote computer is accessing the switch with Windows Client, DirectX 7.0 or higher is needed; if accessing the switch with Java Client, Sun’s Java 2 (1.4.2 or higher) runtime environment must be installed ● A network transfer speed of 128Kbps or higher is recommended ● Supports Internet Explorer, Firefox, Mozilla, Safari, Chrome, Opera and Netscape web browsers ● Compatible with all major operating systems ● Power consumption: 120V, 60Hz, 33.5W; 230V, 50Hz, 34W Control up to 8 computers from anywhere in the world with a single KVM switch with integrated console and IP remote access. This KVM switch is a smart solution for secure server control that saves rack space and money. Features Saves Space and Money ● Combines 8-port KVM switch, 19-in. LCD screen, keyboard and touchpad in a 1U rack-mountable drawer – ideal when rack space is at a premium ● Mounts into 19”-wide rack, 26”-38” deep ● Flip-up/fold-down screen keeps console from blocking access to rack equipment when not in use IP Remote Access for Fewer Trips to the Server Room ● Remote access offers convenience of controlling servers from anywhere…no need to travel to the server room or network closet ● Supports both IPv4 and IPv6 and network interfaces TCP/IP, HTTP, HTTPS, RADIUS, DHCP, SSL, ARP, DNS, 10Base-T/100Base-TX, Auto Sense and Ping Simplifies IT Tasks ● Switch easily between the 8 ports via on-console buttons, on-screen display or hot keys; OSD can be set to English, Spanish, French, German or Japanese Package Includes ● B020-U08-19-IP 8-Port console KVM switch with 19” LCD and built-in IP access ● (x2) P778-Series 6-ft. (1.83 m) USB/PS2 combo KVM Cable Kits ● USB/PS2 combo external console Cable Kit ● Panel array mode lets you monitor multiple ports at same time ● Supports RADIUS and LDAP/S authentication ● Grounding wire ● Auto-scan mode automatically sequences through all active ports accessible to the user ● ● Includes USB port for an external mouse and a USB 1.1 port for sharing a peripheral across the installation RJ11 to DB9 firmware upgrade cable ● Log server tracks events on your installation 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Large 19” LCD ● Extra-wide display makes multitasking easier ● Supports video resolutions up to 1280 x 1024; remote monitor resolutions up to 1600 x 1200 ● DDC emulation allows for optimal output to the LCD Advanced Security Features ● Includes password protection and advanced encryption: 512-bit RSA, 256-bit AES, 56-bit DES, 168-bit 3DES, 128-bit RC4 and 128-bit SSL ● Allows up to 64 user accounts, with 3 levels of access Expandability and Long-Lasting Reliability ● Increase the number of connected computers up to 256 by daisy-chaining up to 31 B022-U08 KVM switches ● Compatible with all major operating systems for easy integration into existing structure ● Firmware is upgradable so your software remains up-to-date ● Heavy-duty steel housing stands up to frequent use Specifications OVERVIEW UPC Code 037332152886 Max CPU 8 Technology PS/2; VGA/SVGA VIDEO Max Supported Video Resolution 1280 x 1024 @75HZ, DDC2B and 1920 x 1080 @ 60 Hz (remote console). INPUT Maximum Input Amps 1 Voltage Compatibility (VAC) 100; 110; 120; 125; 220; 230; 240 Input Cord Details C13 to 5-15P Input Current 120V (0.8A) / 230V (0.4A) PHYSICAL Color Black LCD Monitor (cm) 48.26 LCD Monitor (in.) 19 Shipping Dimensions (hwd / in.) 5.12 x 26.18 x 32.68 Shipping Dimensions (hwd / cm) 13.00 x 66.50 x 83.01 2/4 ● Rackmount hardware ● C13 to 5-15P power cord ● CD with owner's manual, quick start guide, and device files 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Weight (lbs.) 40.00 Shipping Weight (kg) 18.14 Unit Dimensions (hwd / in.) 1.750 x 17.000 x 27.000 Unit Dimensions (hwd / cm) 4.39 x 48.00 x 68.58 Unit Weight (lbs.) 31 Unit Weight (kg) 14.06 ENVIRONMENTAL Storage Temperature Range -20 to 60 C (-4 to 140 F) Relative Humidity 0 to 80% RH, Non-Condensing Operating Temperature 0 to 50 C (32 to 122 F) COMMUNICATIONS Port Control Push Buttons, Hotkeys, OSD IP Remote Access Yes CONNECTIONS Number of Ports 8 PC/Server Connections PS/2; USB; VGA Side A - Connector 1 (8) HD18 (FEMALE) Side B - Connector 1 (1) HD18 (MALE) Side B - Connector 2 (1) DB25 (MALE) Side B - Connector 3 (1) RJ11 (FEMALE) Side B - Connector 4 (1) RJ45 (FEMALE) Side B - Connector 5 (2) USB A (FEMALE) Computer Keyboard and Mouse Interface PS/2; USB Computer Monitor Interface VGA Console Keyboard and Mouse Interface PS/2 Console Monitor Interface VGA FEATURES & SPECIFICATIONS Autoscan (Y,N) Y Autoscan Duration 1 - 255 seconds Number of Users 1 NIAP-Certified Secure No Cat5 KVM Switch No 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States STANDARDS & COMPLIANCE Product Certifications EN 60950-1; CAN/CSA C22.2; UL 60950-1 Product Compliance RoHS; CE (Europe); FCC Part 15 Class A (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B020-U08-19-IP 价格&库存
很抱歉,暂时无法提供与“B020-U08-19-IP”相匹配的价格&库存,您可以联系我们找货
