B006-004-R
B006-004-R
    TRIPPLITE
    SWITCH KVM USB 4 PORT W/O CABLES
B006-004-R 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States KVM Switch - 4-Port Desktop KVM Switch (USB) Highlights ● USB Connections on both Console and Server side ● P758-Series KVM Cable kit required to connect to a computer ● Push Button switching on the front of the unit ● Built-in 2-Port USB hub shares two USB peripherals between attached systems ● OS independent operation - use with PCs or MACs MODEL NUMBER: B006-004-R Package Includes Description Tripp Lite's 4-port Desktop USB KVM Switch is the optimal solution for controlling up to 4 USB computers from one keyboard, mouse, and monitor. It features keyboard and mouse emulation for error-free bootups and works on all operating systems. This device also supports 180MHz video resolutions up to 1920 x 1440 pixels without any noticeable degradation. It features a compact design that does not require external power, software, or complicated set-up procedures. Features ● Control up to 4 USB computers from a single keyboard, mouse and monitor ● Console Ports: HD15 Female (Monitor) and 2 USB A Female (Keyboard/Mouse) ● Computer Ports: 4 HD15 Male (Monitor) and 4 USB B Female (Dual Keyboard/Mouse) ● Includes 2 USB A Female ports for sharing of USB peripherals between connected computers ● 2 LEDs per port; one indicates when the computer is connected & on, the other indicates when the computer has been selected ● Supports 180MHz video resolutions up to 1920 x 1440 ● Supports VGA, SVGA, or Multisync monitors ● Does not require external power, software, or complicated set-up procedures ● Select a computer via front panel push-buttons ● Includes autoscan feature ● Keyboard and mouse emulation for dependable computer boot-up ● Compatible with all operating systems ● Compatibile with most mice; including scroll mice Specifications OVERVIEW UPC Code 037332014962 1/2 ● B006-004-R 4-port USB KVM Switch ● Instruction manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States Console No Max CPU 4 Product Rear View B006-004-R-rear.pdf PHYSICAL LCD Monitor (cm) Not Applicable LCD Monitor (in.) Not Applicable Shipping Dimensions (hwd / in.) 4.00 x 13.00 x 8.50 Shipping Dimensions (hwd / cm) 10.16 x 33.02 x 21.59 Shipping Weight (lbs.) 3.50 Shipping Weight (kg) 1.59 Unit Dimensions (hwd / in.) 2.250 x 9.000 x 6.250 Unit Weight (lbs.) 3 Unit Weight (kg) 1.36 ENVIRONMENTAL BTUs 50Hz, 2.7 / 60Hz, 2.4 COMMUNICATIONS Port Control Push Buttons IP Remote Access No CONNECTIONS Number of Ports 4 Computer/Server Ports - Port 1 HD15 (Male) Computer/Server Ports - Port 2 USB B (Female) PC/Server Connections USB FEATURES & SPECIFICATIONS Number of Users 1 Cat5 KVM Switch No © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
B006-004-R 价格&库存
很抱歉,暂时无法提供与“B006-004-R”相匹配的价格&库存,您可以联系我们找货
