B005-004-R
B005-004-R
    TRIPPLITE
    SWITCH KVM PS/2-4PORT W/O CABLES
B005-004-R 数据手册
Tripp Lite 1111 West 35th Street Chicago, IL 60609 USA Telephone: +(773) 869 1234 E-mail: saleshelp@tripplite.com Model #: B004-004-R Switch - 4-Port Desktop KVM Switch (PS/2) Highlights KVM Switches control multiple computers with 1 keyboard, monitor and mouse console. Simple plug-and-play setup. Full compatibility will all major operating systems and support for most keyboards and mice Adapters allow you to control Mac or SUN computers through any Tripp Lite PS/2 KVM Switch Console Extender Kits keep a keyboard/monitor/mouse console highly accessible and a KVM Switch and connected computers highly secure, located up to 500 ft. away. Accepts two consoles: local (primary) and remote (secondary) Simple to use switches and adapters require no software or system configurations See "KVM Switch Cable Kits" for required cables Retail Packaging Description Tripp Lite's 4-port KVM Switch is the optimal solution for controlling up to 4 computers from one keyboard, mouse and monitor. Switch between computers simply by entering an easy hot key combination on the keyboard or by pushing the selector switch on the unit itself. The compact desktop design allows you to put the switch within easy view so that you can see the status LEDs. Installation is a snap - just connect the PCs to the switch using KVM cables. No software or complicated set-up procedures are required. The switch will function without external power in most cases, however an AC power supply has been provided in case additional power is needed (may be needed with a laptop PC). This PS/2 switch can be use to control a USB, Sun or Mac computer when adding the appropriate adapter. Retail Box. System Requirements PS/2 mouse (or a USB mouse with USB-to-PS/2 adapter) PS/2 keyboard (or a USB or AT keyboard with a PS/2 adapter) PS/2 computer (or a Mac, Sun or USB computer with appropriate adapter). 1 x P753-006, P753-010, P754-006, P754-010, or P754-015 KVM cable kit per port. Package Includes B004-002-R 4-Port KVM Switch AC Power Adapter Manual Features Control up to 4 computers (combination of PS/2, Mac, Sun, & USB) from a single keyboard, mouse, and monitor Compact desktop design Monitor connectors (HD15); Keyboard/Mouse ports (MiniDIN6) Supports VGA, SVGA, or Multisync monitor Does not require software or complicated set-up procedures AC power supply provided for the few installations where external power is needed (usually when being used with a notebook computer). Select computer directly from keyboard or by selector switch on the unit Offers autoscan feature Offers compatibility with most mice; including scrolling mice and wireless mice/keyboards LEDs per port indicate which computer has been selected Supports all current video resolutions. Macintosh, SUN, and USB compatibility by connecting appropriate Tripp Lite console converter or adapter Specifications OVERVIEW Product Rear View B004-004-R-rear.pdf PHYSICAL Color Black CONNECTIONS Ports 4 More information, including related products, owner's manuals, and additional technical specifications, can be found online at www.tripplite.com/en/products/model.cfm?txtModelID=2442. Copyright © 2011 Tripp Lite. All rights reserved. All trademarks are the sole property of their respective owners. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Photos may differ slightly from final products.
B005-004-R 价格&库存
很抱歉,暂时无法提供与“B005-004-R”相匹配的价格&库存,您可以联系我们找货
